Welcome to the North American Subaru Impreza Owners Club Friday August 29, 2014
Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 05-02-2005, 05:06 PM   #1
005sti
Member#: 78293
DP stockcatbckpro-
tune301wtq 289.7whp 93oct
Default is stock o2 sensor on 05 sti wideband?
went to speedshop today to get autometer narrowband a/f gauge for my 05 sti...would not work...call to autometer to find out (i didn't actually talk to the autometer rep) that it will not work because the 05 sti has a wideband O2 sensor stock, as opposed to the narrowband unit used in previous years. anyone know anything re: this...and what is my least expensive option for monitoring my afr
005sti is offline   Reply With Quote
Old 05-02-2005, 07:04 PM   #2
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
It is an AFR sensor, and not just an O2 sensor. I hesitate to call it a wideband, because its effective range is not as good as a true wideband, but it does indicate an actual AFR, unlike O2 sensors which just tell you which side of stoich you're on. It is not particularly straightforward to tap into the sensor and do anything useful with the readings. Your best bet is to get a wideband O2 sensor, like the TurboXS Tuner, which has a much wider effective range.
serendipity is offline   Reply With Quote
Old 05-02-2005, 08:03 PM   #3
MattSTi
Member#: 54885
2004 PSM STi
2006 Mazda MX-5 Race Car
The readings from the stock o2 sensor are not accurate enough to tune safely. There are numerous options for widebands including the innovate lm series and the turboxs tuners. I personally have a tuner pro which also offers knock detection. I had the sensor bung welded into my turboxs downpipe. If you have a UTEC your best bet would be either the tuner or tuner pro, although they are a bit expensive they allow you to integrate accurate AFRs into your logs. If you simply want to monitor your afrs, and not so much log them for tuning purposes you could try a setup like this:
Gauge:
http://www.egauges.com/vdo_mult.asp?...Z-Series&Cart=
Sensor:
http://www.egauges.com/vdo_send.asp?...n_Sensor&Cart=
hope this helps
-Matt
MattSTi is offline   Reply With Quote
Old 05-03-2005, 08:24 AM   #4
005sti
Member#: 78293
DP stockcatbckpro-
Thanks much for your info
-Trey
Swapped O2 sensor on 04 STi...car runs like crap wo^tron Factory 2.5L Turbo Powertrain 12 03-25-2010 10:11 PM
WTB: Front O2 Sensor for 05 STi leonbmx Private 'Wanted' Classifieds 3 10-28-2008 09:54 PM
pressure sensors on 05 sti grundle Tire & Wheel 2 01-23-2007 08:37 AM
rear o2 sensor on 04 sti powerleak Southern California Impreza Club Forum -- SCIC 2 12-17-2004 05:44 PM
Where is the shock sensor on the STi? nasprouse STi Forum Archive 5 07-13-2003 11:16 PM
