Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 05-02-2005, 06:38 PM   #1
flyKen74
Member#: 82092
04 very slow WRX
Dirty PSM
Default need NPT fitting for EGT and subiegal gauge pod
I need 1/8 npt fitting for Defi egt gauge and single corner gauge pod from subie gal. I'm located at Glenview IL. I need this part asap. thanks
flyKen74 is offline   Reply With Quote
Old 05-02-2005, 09:04 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
You drilling and tapping? A good hardware store should have them. Try napa,carquest,auto zone,checkers,blah,blah,etc...
Tim Sanderson is offline   Reply With Quote
Old 05-03-2005, 12:32 AM   #3
STiGMA
Member#: 68054
2004 WRX STi
Java Black Pearl / Gold
flyKen74,
When you say 1/8" NPT fitting for an EGT, which part are you referring to? Most thermocouples (EGT probes) make use of some sort of compression fitting that allows you to adjust the probe depth in your exhaust. This portion usually also makes up the male threaded portion of the 1/8" NPT. The female threaded portion that would coordinate with this is either made by drilling and tapping a sufficiently thick piece (i.e. cast iron exhaust manifold) or by using a female 1/8" NPT weld-in bung. If it's the bung you're looking for, I'd check with a local parts store and ask them for an Auto Meter #2260. If it's the compression fitting, you're probably going to have to find a Defi dealer. The only two that I know of are Genesis Racing Development, and AMS in Arlington Heights.
STiGMA is offline   Reply With Quote
Old 05-03-2005, 01:18 PM   #4
flyKen74
Member#: 82092
04 very slow WRX
Dirty PSM
thanks a lot for ur help. I'll check napa or autozone tonight.. and I'm trying drilling and tapping to manifold. will do it at same time when I put back my gutted uppipe. thanks
Old 05-03-2005, 03:29 PM   #5
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
If you are drilling and tapping the manifold you don't need a fitting. Screw the Defi sensor directly into the manifold.
mbiker97 is offline   Reply With Quote
Old 05-03-2005, 10:29 PM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Don't bury the 1/8" tap either. It's taperred, tap in a couple threads then blow it out and try your fitting. If it needs to go in deeper then tap it a bit more. If you bury the tap your fitting will be loose and you will have a leak. Should'nt need any sealant if you do it right but you might try high temp thread locker if you want.
Old 05-03-2005, 11:35 PM   #7
flyKen74
Member#: 82092
04 very slow WRX
Dirty PSM
thanks tim.. just bought high temp tread. will pick up fitting tomorrow morning, I'll put this tomorrow ( gutted uppipe, with all new gasket, new bosal downpipe w/3rd cat eliminate pipe.) I have all day tomorrow. . I'm still looking for subiegal gauge pos. anyone have one ? thanks everyone.
Need Suggestions: Subiegal Gauge Pod mounting jester696 Interior & Exterior Modification 0 10-24-2008 07:08 PM
WTB: 1/8 NPT fitting for defi/greddy egt illmatic Private 'Wanted' Classifieds 0 03-01-2006 01:40 PM
FS: Autometer carbon fiber boost gauge, subiegal gauge pod, boost install kit phlegmon Private 'For Sale' Classifieds 5 12-28-2005 10:27 AM
WTB: 1/8" NPT fitting for Autometer EGT probe. Wagon Joe Private 'Wanted' Classifieds 4 09-29-2004 09:18 AM
where can I find an NPT fitting for an Autometer EGT probe? Anyone have an extra? Wagon Joe Electrical & Lighting 0 09-20-2004 05:02 PM
