Old 05-02-2005, 09:27 PM   #1
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Default What is EJ22T oil pressure?
I was doing a little research trying to determine how much more pressure the oil pump for the ej22t puts out compared to the wrx. I found some numbers for the wrx, but haven't turned anything up for the 2.2. I'm assuming someone with an ej22t has an oil pressure gauge (and I hope to soon).
The wrx shows around 25-35psi at idle (after warm up) and around 80-90 give or take 10 psi when driving. Just wondering what the 2.2 looks like.
TyranosaurusWRX is offline   Reply With Quote
Old 05-03-2005, 03:27 PM   #2
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
surprisingly, this has not been easy info to come up with...bump
Old 05-03-2005, 04:10 PM   #3
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
For anyone else interested, I found a FSM for the '92 Legacy. It shows 14 psi at 600 rpms and 43 psi at 5000 rpms. This is the same for the N/A as it is for the turbo, the only difference is that the turbo oil pump flows more units per minute (or gal/hour or whatever).
This seems to go against the notion that you need the EJ22T oil pump when you swap from the EJ205 to the EJ22T because of the fact that it is higher pressure..... It may be the same but just flows more.
Old 05-09-2005, 03:58 PM   #4
subarurabbit
Member#: 4083
2011 OB 3.6R
ej22t oil pump is the same as 2.5 DOHC oil pump.
subarurabbit is offline   Reply With Quote
Old 05-09-2005, 04:23 PM   #5
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
So it has the shim in it, unlike the other pumps?
Old 05-09-2005, 08:25 PM   #6
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Take a look at this thread
http://www.bbs.legacycentral.org/viewtopic.php?t=18697
The factory manuals say the oil pressure is roughly similar between the turbo legacy ej22t and wrx ej20t.
Legacy777 is offline   Reply With Quote
Old 05-10-2005, 12:07 AM   #7
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
you can have too much pressure.
it flows more to keep the same pressure as an NA motor, while having enough flow to support the engine, turbo, and oil squirters.
Hurley 2.5 WRS is offline   Reply With Quote
Old 05-10-2005, 10:19 PM   #8
Legacy777
Member#: 4800
You can have too much pressure. Too much pressure will blow out oil seals.
Old 05-10-2005, 10:26 PM   #9
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
Pressure wont blow out seals. The only seal that might see any oil pressure is the rear main. It has an oil return path in the block, if this get plugged with silicon during assembly then it is possible to blow out the seal. Other then that the seals are just keeping the oil in with no pressure on them.
Scoobie Steve is offline   Reply With Quote
Old 05-11-2005, 03:15 AM   #10
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
sorry^ meant can, i suck at zee irnetnetz
well, it sorta makes sense - you cant (dont want) too much pressure"
im just stupid
What are your oil pressure and temperature readings, what do you like to see? 02R6 Built Motor Discussion 4 10-23-2006 07:10 PM
What is the oil pressure psi on the sti's? StiGoddess Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-08-2004 09:22 AM
What should my oil pressure be? RS_NW Normally Aspirated with bolt-on Forced Induction Powertrain 5 11-28-2002 11:48 PM
What is everyones fuel pressure at idle and what pump/FPR are you using? Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 20 05-30-2002 02:32 AM
What is the oil pressure level? JNaubur Normally Aspirated Powertrain 2 01-11-2002 09:54 AM
