Old 05-02-2005, 10:24 PM   #1
kellie00
Member#: 80965
2012 STI
Default AccessPort: Can you change maps with Someone elses AP?
Over the weekend I picked up a Turbo Back that I'm planning on installing in the next couple of days, but unfortunately there's something wrong with my AP, so I sent it back to Cobb to have them look at it. I'm running a stage one map, and I was thinking that maybe I could borrow a friends AP to change to a real-time stage 2 map until my AP comes back? Does anyone know if this is possible? I'll give Cobb a call and ask later, but I thought if anyone knew here I would save them the trouble and maybe they can get my AP back to me faster. Thanks
Kellie
kellie00 is offline   Reply With Quote
Old 05-02-2005, 10:34 PM   #2
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
unless your friend unmarries his accessport from his car, you will not be able to flash your car at all, real time or base time. the accessport will only work on one car at a time.
anthonyrb98 is offline   Reply With Quote
Old 05-02-2005, 10:42 PM   #3
kellie00
Member#: 80965
2012 STI
My car is already flashed with a stage one map from my AP. I wasn't sure if the AP knew which ECU it was updating with a real-time or not. Thanks.
Old 05-02-2005, 10:58 PM   #4
crazymikie
Member#: 56321
2006 Honda El Camino
Green
I'm not sure how good of an idea that would be- changing realtime maps is probably fine, but I'd be hesitant to change base maps since the AP remembers which base map was flashed last. If it relies on this information when flashing, it would get out of sync with what is on the car, so it might cause problems.
Mike
crazymikie is offline   Reply With Quote
Old 05-02-2005, 11:01 PM   #5
kellie00
Member#: 80965
2012 STI
I was really only planning on changing the realtime map since the base map requires a reflash. Thanks for the imput. It sounds like I'll just have to call Cobb and ask.
Old 05-03-2005, 12:03 AM   #6
anthonyrb98
Member#: 48307
02 bugeye
i'm pretty sure the accessport will only work on the original ecu it's been married to.
Can you use ecuexplorer with ap maps? bigolrig AccessPort 1 06-04-2009 03:43 PM
Can you change timing with greddy emanage? tabrad Other Engine Management 8 06-05-2008 09:58 AM
Boost Spiking Using After Changing Maps with Cobb AP (kind of long) Gray_Scale AccessPort 2 07-03-2006 01:08 PM
Boost Spiking After Changing Maps with Cobb AP (kind of long) Gray_Scale Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-03-2006 01:04 PM
Unable to change Maps with AP Scoob_13 Engine Management & Tuning 8 01-24-2005 12:43 AM
