Old 05-03-2005, 10:20 AM   #1
Mancini
Member#: 20726
Default Another UTEC "I need help with knock" Thread
But seriously....please help.
STi UTEC with TBE + Intake. 93 Octane. I have intermittent "knock" between 5800-6000.
Initially, I had to turn up the knock sensativity because it wasn't picking knock events up. Now I'm not sure if it's overly sensative or if this is legitimate knock.
I've pulled lots of timing around the 5750 timing zone to try to help and it's still intermittent. I've throw 94 and 100 octane in and have still seen it occassionally. The odd thing is I've even set timing to 25 degrees at that site to try to induce knock and it resulted in no knock. But at 21 degrees it'll show up.
So I've set the knock count threshold for 2 counts so it ignores these single counts.
Here are the logs. What's going on here?
UTEC picks something up, ECU doesn't:
Code:
4796	18.2	4.3	102	90	0	16.7	87.7	19.5	-0.2	387.5	4.3	10.93
4894	17.9	4.3	102	90	0	16.9	89.6	19.5	-0.5	387.5	4.3	10.96
5096	17.3	4.4	102	90	0	16.9	87.7	19.5	-0.4	350	4.3	11.01
5151	16.9	4.4	102	90	0	17.3	93.3	19.5	-0.4	350	4.3	11.01
5175	16.9	4.4	102	90	0	17.5	93.4	19.5	-0.3	350	4.4	11.01
5367	16.5	4.4	102	90	0	18.1	95	19.5	-0.3	350	4.4	11.02
5482	17.3	4.4	102	100	0	18.4	94.1	20.9	-0.2	325	4.4	10.96
5678	17.3	4.4	102	90	0	18.8	96.1	19.6	-0.2	325	4.4	10.96
5688	16.9	4.4	102	90	0	19	96.1	19.9	-0.2	325	4.4	10.96
5787	16.7	4.4	102	80	0	19.2	97.5	21.2	-0.1	300	4.4	10.95
5899	15.9	4.5	102	80	1	19.5	94.6	21.4	-0.1	300	4.4	10.87
5973	15.5	4.5	102	80	0	19.5	94.6	21.8	-0.2	300	4.4	10.78
5995	15.9	4.5	102	90	0	20.4	98.9	21.5	-0.1	275	4.5	10.76
6105	15.7	4.4	102	90	0	21.2	96.5	22.2	-0.3	275	4.4	10.73
6253	15.5	4.5	102	80	0	22.1	97.1	24	-0.6	275	4.4	10.71
6397	15.1	4.5	102	80	0	23	95	24.6	-0.6	250	4.4	10.71
6447	14.3	4.5	102	70	0	23.7	99.1	25.7	-0.3	250	4.4	10.68
Code:
4323	8.4	4.1	102	80	0	17.7	73.1	18.3	1.9	387.5	4.2	12.06
4547	13.1	4.2	102	90	0	20.9	76.7	19.1	1	387.5	4.2	11.49
4755	15.3	4.3	102	90	0	21.9	83.2	19.5	-0.2	387.5	4.2	11.14
4859	16.7	4.3	102	90	0	23.2	85.2	19.5	-0.4	350	4.3	11.06
5175	16.7	4.3	102	90	0	23.8	88.1	19.5	-0.4	350	4.3	11.14
5224	16.3	4.4	102	90	0	23.5	92.5	19.5	-0.3	350	4.4	11.14
5464	16.3	4.4	102	80	0	23.1	94.1	20.6	-0.3	325	4.4	11.11
5707	15.7	4.4	102	80	0	23.4	95.1	21.2	-0.2	325	4.4	11.05
5807	15.1	4.4	102	80	0	23.4	95.9	21.9	-0.1	300	4.4	11.05
6006	14.3	4.4	102	70	1	23.8	92.8	22.5	-1	300	4.4	10.96
6161	14.3	4.5	102	70	0	24.7	96.6	23.7	-0.7	300	4.4	11.01
6277	13.9	4.5	102	80	0	25.6	98.6	25.3	-0.6	250	4.4	11.08
6510	13.9	4.5	102	70	0	26.9	96.6	25.9	0.4	200	4.5	11.01
Code:
3894	8.4	4	102	70	0	16.4	67.3	17.9	1.6	387.5	4	11.84
4140	12.5	4	102	90	0	19.7	70	17.5	1.7	387.5	4.1	11.23
4334	15.3	4.1	102	90	0	19.6	72.5	18.1	1.6	387.5	4.2	11.27
4510	17.1	4.2	102	90	0	20.4	77	19	0.9	387.5	4.2	11.37
4734	17.3	4.2	102	90	0	22	79.4	19.4	-0.2	387.5	4.2	11.12
4916	17.3	4.3	102	90	0	23	85.2	19.5	-0.6	387.5	4.3	10.95
5112	17.1	4.3	102	90	0	23.1	91.6	19.5	-0.6	350	4.3	11.01
5316	17.1	4.4	102	90	0	22.8	93.5	19.5	-0.3	350	4.4	11.02
5527	17.3	4.4	102	90	0	22.7	95.2	19.5	-0.2	325	4.4	10.96
5678	16.5	4.4	102	90	0	23.1	94.8	19.9	-0.2	325	4.4	10.89
5889	16.1	4.4	102	80	0	23.2	95.4	21.8	-0.1	300	4.4	10.89
5952	15.3	4.4	102	80	1	23.2	97.7	21.9	-0.1	300	4.4	10.89
6127	14.1	4.5	102	70	0	24.1	94.6	23.2	-0.8	275	4.4	10.83
6277	14.1	4.5	103	70	0	25.3	95	24.9	-0.5	250	4.4	10.83
6472	14.3	4.4	102	80	0	26.5	97	24.8	-0.6	250	4.4	10.86
6600	14.5	4.4	100	80	0	28.3	92.9	27.2	-0.5	200	4.4	10.78
This time the ECU picks something up:
Code:
5527	5.2	3.4	32	10	0	39.9	43.4	24.5	-1.4	135	3.5	10.74
5564	2.7	4.1	54	10	0	29.4	72.7	24.5	-1.4	200	4.1	11.06
5592	3.5	4.3	60	40	0	25.3	90.1	24.7	-0.2	200	4.3	11.53
5602	6.6	4.4	101	60	0	23.8	91.2	23	-0.3	325	4.3	11.42
5688	10.6	4.4	101	80	0	23.5	93.1	20.9	-0.2	325	4.4	11.23
5717	13.7	4.5	98	80	0	23.2	98.4	20.9	-0.1	175	4.4	11.11
5767	15.1	4.5	97	80	0	23.2	95.1	21.1	-0.1	175	4.4	10.93
5878	15.9	4.5	93	90	0	23.5	95.6	20.1	-0.1	175	4.4	10.74
5878	15.7	4.5	79	80	0	23.5	97.5	21.6	-0.1	150	4.4	10.73
5868	15.9	4.4	75	80	1	23.6	96.6	21.5	-0.1	150	4.4	10.65
5984	15.7	4.4	87	80	0	23.4	96.5	21.9	-0.1	167.5	4.4	10.59
6016	15.3	4.5	101	80	0	20.5	98.1	21.8	-0.1	300	4.4	10.58
5984	15.1	4.4	101	80	1	20.7	97.1	21.8	-0.2	275	4.4	10.58
6016	14.5	4.5	99	80	0	20.5	97.6	22.2	-0.1	175	4.5	10.64
6038	14.3	4.5	88	80	0	20.8	97.5	22.6	-0.2	165	4.5	10.56
6127	14.1	4.5	76	80	0	21.1	97.6	23	-0.3	125	4.4	10.49
6127	14.3	4.5	70	80	0	21.5	97	23	-0.3	125	4.4	10.49
6172	14.5	4.5	66	80	0	21.8	98.4	23.2	-0.4	125	4.4	10.48
6242	14.9	4.5	99	80	0	21.9	97.1	24	-0.6	175	4.5	10.48
6242	14.7	4.5	101	80	0	22.4	95.8	23.6	-0.6	250	4.4	10.53
6289	15.1	4.5	102	80	0	22.8	97	24.2	-0.6	250	4.4	10.56
And one where everthing is ok...though I have to smooth the 90-80 timing at that point.
Code:
5359	15.9	4.4	103	80	0	22.3	95.4	20.2	-0.4	350	4.4	10.86
5482	16.5	4.4	102	90	0	22.1	94.4	19.5	-0.3	350	4.4	10.89
5455	16.1	4.4	102	90	0	22.7	93.7	19.5	-0.3	350	4.4	10.86
5602	16.3	4.4	102	90	0	22.6	93.3	19.5	-0.2	325	4.4	10.81
5518	16.7	4.4	102	90	0	22.8	96.5	19.6	-0.2	325	4.4	10.86
5583	16.3	4.4	102	90	0	22.8	97.2	19.6	-0.2	325	4.4	10.86
5621	16.5	4.4	102	90	0	23.1	97	19.7	-0.2	325	4.4	10.78
5659	16.7	4.4	102	90	0	23	95.5	19.8	-0.2	325	4.4	10.78
5757	16.9	4.4	102	90	0	22.9	96.1	20	-0.2	325	4.4	10.81
5767	16.5	4.4	102	80	0	23.1	99	21.1	-0.1	300	4.4	10.8
5827	15.7	4.4	102	80	0	23.1	97.8	21.3	-0.1	300	4.4	10.78
5837	15.1	4.4	102	80	0	23.3	93.8	21.3	-0.1	300	4.4	10.73
5777	14.9	4.4	102	80	0	23.1	97.3	21.1	-0.1	300	4.4	10.68
5827	15.3	4.4	102	90	0	23.1	97.2	20.3	-0.1	300	4.4	10.68
5952	15.5	4.4	102	80	0	23.1	96.7	21.7	-0.1	300	4.4	10.65
6006	16.1	4.4	102	90	0	23.2	97.6	20.8	-0.1	300	4.4	10.64
5941	15.5	4.5	102	80	0	23.2	97.4	21.7	-0.1	275	4.4	10.64
5931	15.5	4.4	102	80	0	23.6	98	22	-0.5	275	4.4	10.67
6060	15.7	4.4	102	90	0	23.4	96.6	21	-0.1	275	4.4	10.71
6071	15.3	4.4	102	80	0	23.9	96.7	22.4	-0.1	275	4.4	10.68
6093	15.7	4.4	102	80	0	23.9	94.3	22.6	-0.3	275	4.4	10.64
6116	15.3	4.4	102	80	0	24.2	94.9	23	-0.3	275	4.4	10.59
6207	14.7	4.4	103	80	0	24.5	94	23	-0.3	275	4.4	10.58
Any ideas if that's legit?
Thanks,
Brian
Mancini is offline   Reply With Quote
Old 05-03-2005, 11:41 AM   #2
wrex03
Member#: 29963
04 sti
Your utec isn't pulling timing during these events.
wrex03 is offline   Reply With Quote
Old 05-03-2005, 11:43 AM   #3
Mancini
Member#: 20726
I set the knock count threshold for 2 counts so it ignores these single counts.
Also, it's very sporadic. I'll see it maybe 1 out of 8-10 runs and almost never back to back. The ECU almost never has dips in timing at that point and I never see more than a single count.
Brian
Old 05-03-2005, 12:12 PM   #4
happasaiyan
Member#: 37731
welcome to my life.
happasaiyan is offline   Reply With Quote
Old 05-03-2005, 10:34 PM   #5
Mancini
Member#: 20726
Bah!
After playing with it for another hour...I tried lowering boost and different timing.
I settled on lowering the boost between 5k and 6k and turned the sensativity down.
Guess we'll see how it goes tomorrow.
Old 05-04-2005, 12:40 AM   #6
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
At every one of those knock sites, I'd pull a degree of timing and lean it out a tiny bit. Might actually pick up more torque...
cdvma is offline   Reply With Quote
Need help with something truenosan Vancouver Impreza Club Forum -- VIC 7 06-02-2010 09:05 PM
the "i need help with xmas shopping" thread burnera Off-Topic 25 12-20-2006 06:17 PM
Unofficial "I need help with a creative xmas gift idea for _________"? Ripper Off-Topic 10 11-19-2005 05:53 PM
I need help with utec logs. PLEASE HELP! dman918 Engine Management & Tuning 3 05-04-2003 02:54 PM
Need help with Utec newbie timing topgrinder Engine Management & Tuning 2 02-10-2003 11:07 AM
