Old 05-03-2005, 01:33 PM   #1
prestiowner
Member#: 48117
2002 Imperza WRX
blue
Default apexi tt with a autometer front 02 sensor
hey does any one know if i can hook this up to the apexi tt.
http://www.autometer.com/cat_accesso...l.aspx?vid=162
and if so will it produce an accurate reading on the tt. even accurate enough to tune to?
prestiowner is offline   Reply With Quote
Old 05-03-2005, 06:03 PM   #2
SchnorrCS
Member#: 66383
Tom@ Kartboy is my
Daddy!
There is a thread going on about this started by KrazyK1371 that is talking about autometer AFR gauges. I know for a FACT that the autometer gauges can't go off the signal a WRX O2 sensor sends out, but I don't see why using an autometer O2 sensor, That is totally separate from any other system in the car would produce anything that wasn't accurate enough to use. I might not tune with it, but it will definatly tell you if your having a problem. I mean, if this sensor didn't produce the right, accurate signal for the gauge (or turbo timer) to use, kinda seems like false advertising, right?
cS
SchnorrCS is offline   Reply With Quote
Front 02 Sensor,Rear 02 Sensor,MAF Sensor,Blox Shift Knob,SPT Oil Cap, bunch of stuff TopEndPull Engine/Power/Exhaust 11 08-14-2009 06:48 PM
Need help with front 02 sensor (A/F) wiring shawnsubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-19-2009 10:42 AM
FS Apexi TT with harness bulldog2277 TXIC Private Classifieds 5 02-25-2008 02:26 AM
WTB front 02 sensor for 02-03 wrx vale2489 Private 'Wanted' Classifieds 2 12-17-2006 10:28 AM
NC: Apexi TT & Wiring Harness for 02+ Rex saab-on-the-cobb Suspension/Brakes/Handling 0 11-07-2006 01:52 AM
