Old 05-03-2005, 08:32 PM   #1
Bird61780
Member#: 58967
Default Which basemap should I start with?
Mod list,
Ver 7 shortblock
WRX heads
Perrin Big Maf
Modded stock injectors
catless turbo back
Deadbolt SZ49
Tial 38mm external wastegate
Crower stage 2s and valvetrain upgrade
I have a UTEC tuning appointment in a couple of weeks and need to get my car running well enough to make it there. I am wondering what map I should start with to do this. I know I will have to scale the injectors with the UTEC to get it idleing normal but how will I have to adjust the map right away in terms of fuel and timing to compensate for the External wastegate/Big Maf combo? I do not have a wideband, only an EGT gauge.
thanks
Rob
Bird61780 is offline   Reply With Quote
Old 05-03-2005, 10:47 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...ask TXS....
Old 05-03-2005, 10:55 PM   #3
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Man basemaps aren’t going to do you crap but get you back and forth to the tuner. I’m running the classic Stage-II and using the TXS “generic” map and the tune is way off with numbers which are far too conservative. The base maps are nothing more than a good reference point to start from…
Good luck…
xcntrk75 is offline   Reply With Quote
Old 05-04-2005, 08:17 AM   #4
Bird61780
Member#: 58967
Good luck…
That is all I really want the base map to do, get me to TurboXS.
Old 05-04-2005, 12:23 PM   #5
hippy
Member#: 36528
2002 Impreza Wrx
Load the stage 4 timing map and leave 0's in your whole fuel map. Stock injectors at 420, and raise the modded value 20 at a time til your car runs at an a/f ratio of around 14.7 to 1. Don't go to hard throttle(stay under 25% throttle). At least that's what I'd do, course I'm no expert.
peace
Old 05-04-2005, 04:33 PM   #6
Bird61780
Member#: 58967
Thank you for the advice, I was thinking along the same lines but i too am no expert. Any other advice?
Which is better to start with L or RS? mafiosetto Newbies & FAQs 3 06-12-2007 01:38 PM
Where should I start with the birthdays today? BacDoc Off-Topic 17 06-06-2007 10:36 PM
What should i start with For my 05 STI? power performance STiUnit Newbies & FAQs 21 01-12-2007 04:12 PM
What Should I Start With??? nradeni Newbies & FAQs 7 05-07-2004 03:19 PM
I have a rear sway bar, which endlinks should I go with, should I get front too? Schleppy Brakes, Steering & Suspension 2 08-20-2002 11:52 AM
