Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 05-03-2005, 10:18 PM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default how do i increase max psi on the link plus?
i got my car tuned at like 30' now its at 1500' and its not as fast
ive got a half tank of 110 leaded in there...and i wanna know what settings i can hit to just bump it up 1 or 2 psi
alex
Old 05-03-2005, 10:30 PM   #2
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Where do you need that extra 1-2psi though? I assume you're not talking about MAP fuel cut?
kgb is offline   Reply With Quote
Old 05-03-2005, 10:35 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
i just want it to boost to like 250ish kph
and no map fuel cut is scary stuff when that kicks in
Old 05-04-2005, 01:24 AM   #4
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Isn't it all in the EBC settings and MAP fuel cut though? Unless you're hitting the limit with your current EBC, you boost as quickly as your motor can supply air, or am I mis-understanding your question? Agreed about MAP fuel cut - it's nasty, thought for a while mine didn't work until it worked, man was the car bucked like the engine is going to fall off. If you have that high of an octane, might be better off tuning your timing instead of boost
Old 05-04-2005, 01:43 AM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
the link is telling my ebc to close the solenoid, directing the air to the WG and not to atmosphere at too low of a PSI hehe do u get it now?
i wanna just boost more because its programmed for a lower sealevel where timing is the same but down there theres more air
do u know what i mean tho
thanks for the responses
alex
Old 05-04-2005, 01:48 PM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
you need to read the manual on my ecu it is just a value(Kpa) that you want the solenoid to control, but it is an equation to get the number, so it might not be 250, even if you want it set at 250kpa.
call up PDX and ask jeff if he thinks it is safe to turn it up and if so how to do it. you should be tuned above your max boost i would hope, if that is the case you can just tell the solenoid to control a bit higher.
Ben
Old 05-04-2005, 02:18 PM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
yeah its a bunch of variable numbers
confusing stuff i tells ya what
How do you post your logs on the forum? plus plus plus UTEC 9 08-27-2009 12:26 PM
How do I find this flight on the intarwebs? Sharkbait Off-Topic 13 07-21-2005 05:35 PM
How do U stop spray going on the back window? toerag Forester Forum 6 12-06-2001 07:52 AM
how do i post decent pix on the forum? kneedragger Bay Area Impreza Club Forum -- BAIC 2 06-03-2001 04:07 PM
How do you raise boost levels on the WRX? mastervic27 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-02-2001 07:04 AM
