Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 05-04-2005, 01:44 AM   #1
erice1984
Member#: 11778
1980 VWRabbit Diesel
w/AAZ Swap
Default 02 wrx into 00 rs, fuel pump question
I look at the wiring diagram for both 00 rs (pg 36) and 02 wrx (pg 67), about the fuel pump controller (R122) the wrx has but rs does not. I have been unable to come to a decision on how to address this. I don't know if it affects the wrx ecu or not but I would assume it does. Anyways I am looking for some ideas on how people have dealt with it.
In fact I just noticed the RS has a "Fuel Pump Relay Control" (B134 - 16) pin out on the ecu that the WRX does not have, instead it has the "Fuel Pump Controller" (B134 - 13, B136 - 15)
Thanks
-Eric
erice1984 is offline   Reply With Quote
Old 05-04-2005, 02:02 AM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
you need to research some more, the wrx uses a fuel pump controller because it has a variable fuel pressure. for diff situations the fuel is different pressures. you need this for the wrx ecu to work properly and delivery the right amount of fuel.
i would assume there is info already on the boards.
Ben
Old 05-04-2005, 04:03 AM   #3
erice1984
Member#: 11778
w/AAZ Swap
yea, but every thread and bit of info i can find no one mentions this part. My questions would then be is this an actual encased control module like the ecm is? I dont want to have to buy this thing because as long as the fuel pump is providing flow the regulator will controll how much fuel based on vacuum/boost the car is putting out. If it were that way where the fuel pump flow is variable that would defeat the purpose of the regulator.
Old 05-04-2005, 08:09 AM   #4
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
Are you talking about the “Fuel Pump Relay” itself? If so both WRX and your platform will obviously have this component. You need to wire the “Fuel Pump Controller (WRX)” into your existing setup which takes a feed from the fuel pump relay and provides a variable output to the actual pump.
The controller is easy to wire, 1 wire supplies power from the relay, x2 wires for the ECU interface, and x2 wires to control the pump, plus x1 ground. That’s all there is to it…
Good luck…
xcntrk75 is offline   Reply With Quote
Old 05-04-2005, 11:13 AM   #5
Randoramma
Member#: 60649
00RS EJ205 swap
Lightbulb
Thank you yamarocket630 for detailed pics. This pic found in FAQ, throught this thread:
http://forums.nasioc.com/forums/show...hreadid=289335
It is my understanding that this IS the regulator. W/o it, say good bye to gas milage and or may result in lean conditions. In EJ25 setup, this is incorperated in to the main ECM.
Randy
Randoramma is offline   Reply With Quote
Old 05-04-2005, 11:54 AM   #6
PHATsuby
Member#: 13617
2001 Legacy GT back
^^^Randoramma has it.
You are varying the duty cycle to the FPC which in turn varies the fuel pump output, so it is like an electronic FPR in a way on top of the mechanical. The ecu is designed for the two to work in conjunction with one another so if one component is missing it is not going to be able to calculate proper fueling, at least thats how i would think of it.
Ben
Old 05-04-2005, 10:41 PM   #7
erice1984
Member#: 11778
w/AAZ Swap
yea i jus did a google search and found all kinds of stuff. man junk yards are almost rip-off pricing. 120 bucks for a controller... its like 75 from 1stsubaru.com
-Eric
02 WRX OEM DP, TMIC, Fuel Pump, Samco Y-Pipe SacksLax Engine/Power/Exhaust 8 08-13-2009 02:30 PM
93 EG20G into 00 RS accessory installation questions SeveredPerformance Subaru Conversions 5 02-25-2008 12:42 PM
'05 WRX into '96 L.....fuel pump controller? Numbchux Subaru Conversions 3 09-26-2007 07:17 PM
FS: 02 wrx utec, modded injectors, fuel pump godfather2112 Private 'For Sale' Classifieds 5 05-13-2005 04:04 AM
MY04 WRX into MY00 RS.. fuel tank sensor CEL? mpaone Subaru Conversions 15 09-17-2004 04:56 PM
