Old 05-04-2005, 05:04 AM   #1
eakins
Member#: 61917
Default Redline 75w-90 or 75w-90ns in the rear.
my car is a 00 outback with (i think) a LSD rear.
some use 75w-90 & some use 75w-90ns. which is correct?
is ther lsd rear viscous? any other better options?
thanks!
bill
eakins is offline   Reply With Quote
Old 05-04-2005, 08:15 AM   #2
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
IIRC the read LSD is viscous, I would use redline 75w-90.
LyveWRX is offline   Reply With Quote
Old 05-04-2005, 05:01 PM   #3
1984
Member#: 16461
WRB w/paintchip flake
I've got a question about Redline gear oil as well. I'm reading the label on a bottle of Redline 75w90ns and it says that the fluid should not be used in the diff of a rwd car unless friction modifier is added. Does it matter if I put this oil in the rear diff of my WRX? I've searched and haven't found a straight answer. It seems that it's okay to use Mobil 1 in the rear diff.
1984 is offline   Reply With Quote
Old 05-04-2005, 05:19 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The WRX rear diff is a sealed viscous coupling type LSD. Since it's sealed and has no contact with the fluid, it doesn't matter what oil you use as long as it meets the spec for rating and viscosity. The instructions on the Redline bottle refer to "wet" clutch type LSDs that are not sealed and are exposed to the fluid, for those the friction modifier additives are required for them to operate correctly. Since the NS fluid doesn't contain those additives they must be added separately if it is used with a wet LSD.
The LSDs in the earlier cars may be wet, I don't know for certain. To be sure of having the proper lubrication and additives just use the 75W90 in the rear (not the NS). If there is a wet LSD the additives are required, if it's a sealed unit the additives are still beneficial unlike in the trans where they can cause problems.
Old 05-04-2005, 05:29 PM   #5
subarurabbit
Member#: 4083
2011 OB 3.6R
iirc, I thought 80w90 was the spec on the rear diff.
subarurabbit is offline   Reply With Quote
Old 05-04-2005, 05:36 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
For the newer models the spec is GL-5 75W90 for the trans and rear, with other grades also acceptable according to the chart in the manual.
Older cars, refer to your manual or the Subaru site for specs.
80W-90 or 75W-90 f/r diffs Brock31 Service & Maintenance 9 09-12-2009 08:42 AM
Amsoil: SVG 75W-90 or normal 75W-90 Tranny Fluid? SausageOfPower Service & Maintenance 10 08-27-2007 10:54 AM
Brake fade in the rear or just the front? chimchimm5 Brakes, Steering & Suspension 7 05-24-2007 02:48 PM
205/55/16 in the front and 225/50/16 in the rears ok? Or vice versa? SinhCredible Tire & Wheel 31 11-16-2004 04:48 PM
4" or 5 1/4" speakers in the rear with no amp? barosborough Car Audio, Video & Security 9 11-22-2003 11:01 AM
