Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 05-04-2005, 06:09 PM   #1
Yellow_turbo
Member#: 5937
2005 Legacy GT
Satin White Pearl
Default Boost Creep Problem
Hi!
I have a STi V5 RA Setup in my car. (Brighton 1999)
Sometimes, in 4-5th gear, i have boost creep...(between 17-19psi)
My car is 99.9% stock Version 5 JDM
- TurboSMart BOV
- STi Usdm Muffler
- Straight through mid-pipe (custom)
- Stock air box
- Stock V5 Catalytic converter
What i think...it's maybe that my catalystic converter is plugged !?!?
Can somebody help me with that !?
Thank you!
Martin
Yellow_turbo is offline   Reply With Quote
Old 05-06-2005, 09:06 AM   #2
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
All go and no show...
You might have more luck in the conversion forum. Most of the guys here have USDM turbo motors. More people are probably familiar with the JDM setups over there.
What is your stock boost level? Do you run an after market DP?
legacy92ej22t is offline   Reply With Quote
Old 05-07-2005, 04:28 PM   #3
Yellow_turbo
Member#: 5937
2005 Legacy GT
Satin White Pearl
Thank you!!!
My DP is the stock V5 one!!!
I think that my BOV can be the problem.... It's a TurboSmart V-port ....
I tried to put more tension on the spring (it's adjustable) and i think that it solved the problem... (My problem is Intermittent)
Do you think it's possible...
Thanks
Martin
Particularly Strong Stage I 06 STI AP - Boost Creep Problems Dyno Flash Proven Power Bragging 42 01-13-2007 09:51 PM
Boost Creep Problem... Yellow_turbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-04-2005 02:48 PM
boost creep problem, where to port wastegate? SilverCWestWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-02-2005 12:34 PM
Boost creep problem Lo0mis Normally Aspirated with bolt-on Forced Induction Powertrain 11 11-30-2003 02:41 PM
Boost creep problem..... Red Rocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-01-2002 04:34 AM
