Old 05-05-2005, 12:18 AM   #1
gsteclipse33
Member#: 72859
Default got car tuned but boggs on shifts
ok any one have an idea if i got wot in 2nd then shift and mash it again in 3rd it jerks or boggs out 2 or 3 times then pulles hard again anyone know what this is would showing a log help out thanks
gsteclipse33 is offline   Reply With Quote
Old 05-05-2005, 01:03 AM   #2
hippy
Member#: 36528
2002 Impreza Wrx
Your bov might not be closing. Do you have a stock one? If not, what type?
peace
Old 05-05-2005, 10:05 AM   #3
methinkadoo
Member#: 37419
letting the clutch out to fast to make it jerk?
methinkadoo is offline   Reply With Quote
Old 05-05-2005, 11:15 AM   #4
gsteclipse33
Member#: 72859
have and hks seq and its not me bogging it out with the clutch
Old 05-05-2005, 11:26 AM   #5
YourMother'sLover
Member#: 76565
CLXX Stricta Parata
Neci!
Maybe it's switching between open/closed fuel loop.....sometimes you could get a slight stutter if you're not shifting fast enough and keeping the RPM's up. I get a stuttttttttttter when I give it gas right after a shift (I'll admit, sometimes it's because I beef up on letting the clutch out...but I'm trying to burn it up to justify a new one ) and around 2800 - 3000 rpm.
YourMother'sLover is offline   Reply With Quote
Old 05-05-2005, 05:08 PM   #6
gsteclipse33
Member#: 72859
thats not like my problem well if i go full throttle in 2nd till like 6800-7000 then shift to 3rd
the car will hit full boost again but buck foward and back like for a second or 2 before it moves again.
Could this be my clutch slipping or sounds more like the tune
Old 05-05-2005, 05:25 PM   #7
hippy
Member#: 36528
2002 Impreza Wrx
Try tightenning the screw on your bov.
Old 05-05-2005, 05:49 PM   #8
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Sounds like you ar slamming the shift, and possibly causing shify knock, which will make the car pull timing to cure it, then feed it back.
Don't slam the shift.
mcowger is offline   Reply With Quote
Old 05-05-2005, 06:33 PM   #9
wrex03
Member#: 29963
04 sti
could be shift knock, or possoble going very rich right after the shift. what
EM?
wrex03 is offline   Reply With Quote
Old 05-05-2005, 06:51 PM   #10
gsteclipse33
Member#: 72859
im useing a utec its not shift knock and its not me slaming the shift ik how to drive a awd car and i make sure it is in gear all the way it just bogs out i will try tightening the screw on the bov to see what it does keep teh ideas coming
anyone think a small uppipe leak could cause this
Old 05-05-2005, 07:10 PM   #11
wrex03
Member#: 29963
04 sti
post a log. Do you have a wide ban?
Old 05-06-2005, 06:23 PM   #12
gsteclipse33
Member#: 72859
i dont hvae a wide band but im trying to get my laptop back so i can get soem logs
Finally got my FSTi bumper/grille on...thanks Mario/Amir/Gillman :) Geoff Texas Impreza Club Forum -- TXIC 16 06-03-2010 12:32 PM
got car tuned...misfire codes spoolinred UTEC 6 10-27-2008 10:20 PM
got cobb Ap but have opensource tune. do i need stock map? saulgoodyo AccessPort 0 12-06-2007 02:33 PM
I finally got my car back!! but.... Strider Tri-State Area Forum 2 05-11-2002 08:03 AM
