Old 05-05-2005, 02:18 AM   #1
Gigabelova
Member#: 81409
2004 Impreza WRX STi
Platinum Silver Metallic
Default HELP! My UTEC doesn't do anything...
Hi,
I'm kind of a noobie here so don't shoot out at me if I asked something stupid... I bought a Utec for my 03 WRX recently and I had a tuner installed it for me and he tried tuning it. He told me that the data logger and stuff are working fine, but for whatever reason, the changes he makes does not take effect.
He said he stopped the car, changed some fuel settings and started it up again. When he drives the car, he feels that nothing changed. Although the Hyperterminal is showing the changes, nothing happens. He said the car was running too rich. So he tried leaning out the afr mixture but nothing happened. Then just to give himself some clues, he made the mixture as rich as possible, still no changes.
He called TurboXS customer service and all they told him is that he doesn't know how to use it. He has been tuning ecus and all that kind of stuff for so long now, I do not believe him incapable of tuning a user friendly utec. He's really fustrated with the Utec and he switched me back to my Safc so that my car can run while I look for an alternative ecu.
Is he missing something here? We tried looking for the dipswithces but all we found were just 2 switches instead of 8 dipswitches. My tuner said it was probably a newer version of Utec. CAn anyone figure this one out?
Just for reference, my car's mechanical modifications are: Sti fuel injectors, custom uppipe, downpipe and full catless turboback, CAI intake, 255lph fuel pump, fuel regulator, avcr, safc, egt, vf-34 turbine, 24x3x12 fmic with custom charge pipes and that is all I can think about for the time being other modifications shouldn't be an issue I think. Oh yeah... maybe a rerouted battery to the boot of the car, but I don't think that'll cause anything...
Thank you in advance to all who have responded to my desperate cry for help...
Gigabelova is offline   Reply With Quote
Old 05-05-2005, 05:17 AM   #2
hippy
Member#: 36528
2002 Impreza Wrx
On the back of the utec, there's a little dial that switches between map positions. If the dial is on 0(stock mode), you can do all you want to the maps in the utec, and nothing will change. Make sure the dial is set to something like 1, which would make the utec use the map in slot one. I think the problem is that the switch is either on stock mode, or your tuner is adjusting the map which is not in the slot which is being used. If your tuner is charging you what other tuners charge, you should probably switch to a tuner who has a lot of experience with utecs and wrx's. If you're not payin him much and are set on using him as your tuner, you might wanna ask him to read the utec manual.
I don't like safc's on wrx's. Imo, you'd be better off letting the stock ecu do its thing. As always, this is just my opinion, and I'm no expert.
peace
Old 05-05-2005, 07:26 AM   #3
wrex03
Member#: 29963
04 sti
Sounds like a link to Mick's tuning guide is what your tuner needs
wrex03 is offline   Reply With Quote
Old 05-05-2005, 08:17 AM   #4
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
peace
What he said...
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 05-05-2005, 10:16 AM   #5
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
RTFM please!
bikerboy is offline   Reply With Quote
Old 05-05-2005, 10:35 AM   #6
Gigabelova
Member#: 81409
hippy,
My tuner has read the instructions over and over but he can't find out what was wrong... I checked myself and I saw the switch set to the 1 position and there was a map there.
Wrex,
Could you get me a link or something for this guide? I'd like to look at it...
Thanks for your time guys.
Old 05-05-2005, 11:20 AM   #7
TheMadScientist
Member#: 23717
2005 Big red
Originally Posted by bikerboy
RTFM please!
And keep reading it over and over.
TMS
TheMadScientist is offline   Reply With Quote
Old 05-05-2005, 11:31 AM   #8
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
I hope you didn’t give this guy any money for these services…
Get it tuned by a professional shop who has experience with UTEC.
$.02
xcntrk75 is offline   Reply With Quote
Old 05-05-2005, 11:42 AM   #9
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
www.wrxhackers.com
You have to register to gain entry to the downloads forums. There is a UTEC section in there that has the tuning guide.
Old 05-05-2005, 11:49 AM   #10
hippy
Member#: 36528
2002 Impreza Wrx
Here's a link to micks guide. I dunno how much it will help though since most of what's in it is in the utec manual, and the rest your tuner might already know. I dunno what to say if the switch is on 1, and you're using the map in slot 1(the map on top). Maybe you should check the parameters and make sure everything's ok? Some of the parameters(the temp compensation stuff mostly) can do weird things to fueling and timing.......
peace
Old 05-05-2005, 12:05 PM   #11
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Start off by going to the dashboard and confirming that it's on switch 1 map 1.
Then make sure the map he's editing is actually map one.
If it's an OLF map, make sure you even have OLF turned on.
Because if OLF isn't turned on, he'd need to put in > -5 in the fuel map all together to even get it close to a 550 map in OLF, which at that point becomes +- tenths.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 05-05-2005, 01:59 PM   #12
TurbojonLS
Member#: 38772
2 Cars, No Bling
Is he actually saving the maps? You mentioned making changes, turning off the car, and then turning it back on, but nothing RE: saving the changes. Also, you don't need to turn off the UTEC between changes.
TurbojonLS is offline   Reply With Quote
Old 05-05-2005, 07:01 PM   #13
nmyeti
Member#: 4980
Or better still is he tuning in the 100% load column thinking its 100% TPS?
nmyeti is offline   Reply With Quote
Old 05-06-2005, 08:54 AM   #14
samh22a
Member#: 30710
04 STI
if your tuner doesn't want to take the time to read the manual..I would stay away from him.
TXS has all the rights to tell him to RTFM.
samh22a is offline   Reply With Quote
Old 05-06-2005, 12:02 PM   #15
Gigabelova
Member#: 81409
TurbojonLS,
He said the maps were saving fine, but it simply weren't making any changes. Like when he was trying to lean out some areas, it just simply wasn't making any difference...
nmyeti,
Can ou tell me more about the 100% TPS thing? As far as I understand 100% TPS is full throttle right? Those are adjusted by the ecu itself right?
Thanks for all this feedback guys!
Old 05-06-2005, 12:05 PM   #16
Gigabelova
Member#: 81409
RiftsWRX,
I am quite sure the maps aren't the problem, but about the OLF... I'm not too sure how that works. How do you swith it off? If it's off, why -5? I'm quite sure my car isn't an OLF type. Only the 04-05 are.
Old 05-06-2005, 12:54 PM   #17
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
You really have to read the manual. You have pretty much no knowledge of the product, so it's pointless for us to answer your questions one at a time. Read the TXS manual, and read the tuning guide. Understand the product before you put it on your car and blow it up.
serendipity is offline   Reply With Quote
Old 05-06-2005, 01:12 PM   #18
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
Originally Posted by Gigabelova
RiftsWRX,
I hate to have to even say this...
Have your tuner take screen captures of the the dash board, the parameters->tuner constands, parameters->special constants, parameters->open loop fueling, the map he's editing (fuel map page 1 and page 2).
Post those up here, or have him email me the screen captures ([email protected]), and let's go from there.
Jorge (RiftsWRX)
www.ProjectWRX.com
Old 05-06-2005, 04:03 PM   #19
hippy
Member#: 36528
2002 Impreza Wrx
RiftsWRX,
With your mods, it would probably be best to be running with the utecs olf mode on.
.....nmyeti,
What nathan was saying is that your tuner might have been adjusting the wrong areas of the maps, and that's why he didn't see anything happen when he made changes to them. You need to make changes in the timing and fueling maps according to load. The logs will show the load site and rpm range changes should be made in.
peace
Will I need to roll my fenders or do anything with these wheels??? wrx2003turbo Tire & Wheel 4 10-27-2008 10:59 PM
HELP!! My accessport doesn't work!! aakrusen Engine Management & Tuning 22 03-25-2006 12:12 AM
Who else's "quickquote" button doesn't do anything? DrDRum Off-Topic 27 01-12-2005 12:15 PM
Help My STi won't do more than 150 mph txjunglist Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 60 12-12-2004 12:10 PM
My UTEC doesn't work BlueWRX Engine Management & Tuning 6 02-15-2003 09:18 PM
