Old 05-05-2005, 09:13 AM   #1
WRexxer
Member#: 48527
2004 Subaru WRX WRB
COBB VF30
Default Cobb AP: Anyone running HWG just for extra performance?
I'm hitting good boost with the regular Stage2 map when I run HWG map I seem to hit the same boost but faster and more violent!!
I was wondering if anyone else thought the same!
WRexxer is offline   Reply With Quote
Old 05-05-2005, 12:27 PM   #2
FM Scooby
Member#: 77979
2006 GSXR750
Black & Yellow
I have an 05 STI with TBE, intake, BOV, and AP stg2 93 oct. I ran the stg2 hwg and was hitting 18.3psi in 3rd all the way to red line. I dont know what the true psi was because the AP will only read up to 18.3psi. It was cool, but kind of scary, went back to stg2 93oct. I would like to know if running the hwg map is safe or not?
FM Scooby is offline   Reply With Quote
Old 05-05-2005, 12:48 PM   #3
phantomsr
Member#: 69071
2002 Stg2-WRX Wagon
WRB & Dust
Bad mojo I'd say. Cobb suggests not running the HWG maps unless you are completly unable to hit target boost with the regular map. I'd suspect you are overboosting or spiking with the HWG map. If not then you may be fine. I'm haven't run the HWG map and I'm not sure if the map will deal with the extra boost sooner. Actual values would help.
phantomsr is offline   Reply With Quote
Old 05-05-2005, 12:51 PM   #4
ptaaty
Member#: 73196
2002 WRX Cobb Stg2
2003 Sil/Blk R1
cobb set the target boost at 15.8 for a reason...because there is only so far the stock turbo is good for. They didn't do it to limit just for fun!
you are just blowing more hot air...
ptaaty is offline   Reply With Quote
Old 05-05-2005, 12:55 PM   #5
WRexxer
Member#: 48527
2004 Subaru WRX WRB
COBB VF30
yeah I agree with everything said but I'm not spiking and I'm running about the same boos tit just seems to hit quicker!! hehe...maybe it's be being crazy!
Old 05-05-2005, 12:58 PM   #6
phamster
Member#: 59291
i am doing it, but i don't know how safe it is.. i have water injection though.. for some safty..
http://forums.nasioc.com/forums/show...ater+injection
phamster is offline   Reply With Quote
Old 05-05-2005, 02:23 PM   #7
subieworx
Member#: 47769
I think Cobb says something to the effect of if you are using the HWG just to increase boost don't do it because it could result in spiking. But if you are not spiking or running excessive boost it should be fine as the fuel should be mapped to the boost.
subieworx is offline   Reply With Quote
Old 05-05-2005, 02:29 PM   #8
shinsain
Member#: 51745
LIKE A
BOSS
Right, but what if one is not spiking? What if its only spooling better?
shinsain is offline   Reply With Quote
Old 05-05-2005, 05:02 PM   #9
hondaeater69
Member#: 60324
I think you should be fine, it's spooling faster because the wastegate is staying closed longer. If no spiking, and you're hitting target boost levels, and no PTFB, no worries
Old 05-05-2005, 05:48 PM   #10
BIG GUN
Member#: 49825
2002 WRX WAGON
SILVER
02 wagon w/4EAT. I am running stg.2, 1.20 93 oct. base. Switched from same realtime to HWG 3 wks. ago. Car pulls stronger, boost around 16.5-17 lbs. No sighn of Knock. I had tightened w/g rod 1 full turn last year, and that helped to. I run Shell 93.
BIG GUN is offline   Reply With Quote
Old 05-07-2005, 06:58 PM   #11
shinsain
Member#: 51745
LIKE A
BOSS
Yeah, I recently decided to give it a go and its hitting target boost (no higher) faster and seems to be running very well. I'm using the Stg 2 91 Oct as the base with the HWG Stg. 2 01 Oct over as a realtime map.
Old 05-08-2005, 06:48 PM   #12
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
I have the same impression.
silver arrow is offline   Reply With Quote
Old 05-08-2005, 06:55 PM   #13
2hip
Member#: 58987
2004 WRX Prem. Pkg.
Platinum Silver
Does anyone know if you can load the HWG v1.13 maps that are currently on the Cobb download site with the v1.4 map manager or do you need to upgrade the map manager to v1.5 or v1.6?
Thnx - 2Hip
2hip is offline   Reply With Quote
Old 05-09-2005, 12:41 AM   #14
shinsain
Member#: 51745
LIKE A
BOSS
Pretty sure Cobb said you had to update the manager.
Update: today I ditched the HWG map, I noticed I was making closer to 17 psi at WOT....it was spooling very well and running well, especially with that extra 1psi of boost, but its not supposed to boost to that, so in the interest of safety, I switched back to the Stg 2 V1.22 91 oct.
Oh well.
Old 05-09-2005, 05:24 PM   #15
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
I have been running the HWTG Stage 2 91 octane map for about a month now and love it!!!!
17.5 psi of fun
My car breathes very easy tho:
Injen Up pipe, x over pipe, Short ram
Spearco IC, Cobb TBE
i was thinking of running the Injen intake base map and then the real time HWTG map, any thoughts????
markuswelby is offline   Reply With Quote
Old 05-09-2005, 08:37 PM   #16
shinsain
Member#: 51745
LIKE A
BOSS
Well, the first that comes to mind is that you shouldn't be overboosting, you're running an intake with the wrong map (while overboosting) which means your A/F's are surely off. I would suggest ditching the HWG map as I did because I was overboosting as well. And certianly if you're keeping the intake, ditch the map and use the right one.
A: 17.5psi is for all intents and purposes out of the efficiency range of the stock turbo.
Originally Posted by cobb
If this map causes overboosting and you continue to use it, you must accept the risk of engine damage
B: 17.5psi is higher than the map is written for
Target boost pressure is 15.8psi +/- 0.5psi depending on vehicle and conditions.
C: If you must use an intake w/ AP, you should definitely be using the Injen map. The other maps are NOT certified for use with an intake.
Regarding the Injen map:
This map is not an official endorsement of the Injen brand intake. It has been created purely from customer demand. COBB does not currently recommend the use of this, or any intake on the WRX.
Regarding any other map using an intake:
MUST USE FACTORY INTAKE. NO AFTERMARKET INTAKES ARE CERTIFIED COMPATIBLE WITH THIS MAPPING.
I mean, you're balls-deep in your 05 and not even giving it a reach-around man!!
Give it a fighting chance and at least check out what you're doing before you blow the thing up!
Aaron
Can anyone run a Carfax for me? Jason02WRXCT New England Impreza Club Forum -- NESIC 1 09-19-2005 01:57 PM
Need Help quickly:: CarFax: Can anyone run a VIN for me? dowroa South East Region Forum 13 01-09-2005 01:15 PM
