Old 05-05-2005, 09:21 AM   #1
andmoon
Member#: 37278
03 wrx
Default why are tokico struts not as popular as kyb
I'm looking to get springs and struts for my 03 wagon. I see a lot of good reviews for agx and sti takeoffs. Not many but the reviews of the Tokicos are good but they don't seem too popular. Why?
andmoon is offline   Reply With Quote
Old 05-05-2005, 09:26 AM   #2
Davenow
Member#: 23676
No idea, I ran tokico adjustables on my VW and I loved them. Dirct cheap (comparatively) and handled very well.
Old 05-05-2005, 11:37 AM   #3
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
KYBs AGXs have been around since at least since before 2001 for the GC* platform and then after a 2 year delay they finally showed up for the GD* platform. So basically, they've been around for Subarus quite a bit longer and folks have been quite used to them and like them. There isn't necessarily anything wrong with the Tokicos other than their Subaru availability has only come as of the past 12 months perhaps.
Most folks go with what they know.
-Biggly
DrBiggly is offline   Reply With Quote
Old 05-05-2005, 12:23 PM   #4
thesmokingman
Member#: 17751
KYB is the OEM supplier of Subie struts. Call it comfort level.
thesmokingman is offline   Reply With Quote
Old 05-05-2005, 12:25 PM   #5
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
The late D-Spec Tokico struts have gotten great reviews. The only thing is that they're usually $200-300 more than a set of KYB AGX struts.
Old 05-05-2005, 12:31 PM   #6
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
For $100 over the AGXs you can snag some Konis typically. I'd rock those long before the Tokicos...but to each their own.
Old 05-05-2005, 04:16 PM   #7
knotty_dread
Member#: 71557
2004 STI
blueberry
^ arent konis more expensive than the d-specs. Also, whats the washer deeal about? Does anyone manufacture a strut for sti's that dont need washers to fit properly (dont mean to hi-jack your thread bro.) Thanks
knotty_dread is offline   Reply With Quote
Old 05-05-2005, 08:46 PM   #8
Mark Avery
Member#: 10313
2002 WRX wagon
Originally Posted by knotty_dread
whats the washer deal about? Does anyone manufacture a strut for sti's that dont need washers to fit properly
Subaru changed the rear spring/strut top design in 04. Older style struts and the newer style strut tops don't mate perfectly. There's a little play even when the net is tightened completely. The washer is to take up the play. The only 04 style struts are OE Subaru. Use those and no washer needed. Aftermarket strut makers (Koni, KYB, Tokiko) have not developed an 04 style offering. No word on when or if that will happen.
Mark Avery is offline   Reply With Quote
Old 05-05-2005, 09:36 PM   #9
knotty_dread
Member#: 71557
2004 STI
blueberry
^ thanks that explains that. Do the majority of coilovers available for 04+ need the washers as well, or are they just bolt and drive? Thanks again.
Old 05-05-2005, 10:35 PM   #10
Psydotek
Member#: 44168
2003 Yellow WRX
Most (all?) coilovers come with camber plates so you don't need to reuse the OEM tophats. They just bolt right in.
Why are my "images" now coming up as "urls"? BIGSKYWRX Newbies & FAQs 5 07-27-2004 12:06 PM
04 STI, are the strut tops the same as a WRX? Davenow Brakes, Steering & Suspension 2 01-12-2004 12:40 AM
Why are rear strut bars so much more expensive that front strut bars? mdot Brakes, Steering & Suspension 8 10-15-2002 01:45 PM
Why are inverted struts called that? edkwon Brakes, Steering & Suspension 2 03-17-2002 06:31 PM
If the Japanese spec WRX is 280 hp, why are those trannies not breaking? ARG Transmission (AT/MT) & Driveline 35 08-17-2001 02:46 PM
