Old 05-05-2005, 02:42 PM   #1
subiDriver
Member#: 79214
2004 Stg II wRx
pSm
Default cobb vs utec
Going for the turbo upgrade soon probably the vf34, was wondering which engine managament to go for cobb or turboxs, cobb seems a little in my league money wise was wondering who has them and what do they think of it and is there really any difference with the 2?
subiDriver is offline   Reply With Quote
Old 05-05-2005, 02:48 PM   #2
SubyDuz
Member#: 80432
69 IchhateinAudi
Blutrot
UTEC, all the way, I have one tuner friendly and easy to use, they have base maps they can send you for a base map to get started. COBB havent' had any experiance but mroe for mild bolt on cars not turbo upgrades, maybe if you get their new Street Tuner but haven't heard on that.
SubyDuz is offline   Reply With Quote
Old 05-05-2005, 03:21 PM   #3
breathinez
Member#: 79859
2002 06 STi lb, meth
3" 8cm Green Hydra
You can upgrade your turbo with Cobb. They have a map for the VF34. And down the road if you max out your performance level you can upgrade to the Street tuner and go from there. I chose Cobb, mainly because I wanted to be able to run stage 2 and be able to do all the work myself. I don't know of a dyno/tuner close to me ( all wheel drive anyway) that can tune my car. So the Cobb AP is perfecrt for me. I don't have it installed yet but it will be here this afternoon...2nd day air. So stage 2 this weekend!
My 2 cents.
breathinez is offline   Reply With Quote
Old 05-05-2005, 05:07 PM   #4
03WREX
Member#: 38932
2003 WRX
WRB - Cobb Stg2
I have Cobb and I found it to be very good for someone who does not know much about tuning but still wants added power. I've gone through stage 1, currently at stage 2, and plan to move to 2.5 very soon.
UTEC is more for people looking to get every last bit of power from their specific setup. Of course it will cost more but you get more. The street tuner should give you more flexibility but will cost similar in price to a UTEC.
03WREX is offline   Reply With Quote
Old 05-05-2005, 06:16 PM   #5
84SubaruDL
Member#: 42179
SON! F 22's i roll
on 33" 12 fity SON!!!
i have had both EMS and both systems are really good the thing is, if you want big power use the UTEC, and if you want safety and good power go with COBB.
84SubaruDL is offline   Reply With Quote
Old 05-05-2005, 07:32 PM   #6
shinsain
Member#: 51745
LIKE A
BOSS
The AP/Street Tuner will be a better combo in the long run.
The UTEC still uses the stock ECU for some functions and is therefore not totally tunable in as many aspects as I believe the Street Tuner will let you.
With the UTEC you can make big power sooner, but you aren't able to control *every* single aspect like with something like AP/Street Tuner combo which will let you customize as much if not more than the UTEC and then let you reflash the stock ECU which is "smarter" at handling all aspects of our cars than the ECU/UTEC combo.
You aren't able to replicate the stock ECU's tunability/capability with aftermarket ECU's until you get up into the 3000 dollar and up range.
I'm not saying the UTEC sucks by any stretch of the imagination!!0 But in the long run, the AP/ST combo is becoming a better choice. And with the advent of Pro Tuner from Cobb, this will make it even more enticing to stay with Cobb.
Hope this helps,
Aaron
shinsain is offline   Reply With Quote
Old 05-05-2005, 08:03 PM   #7
Stellar1
Member#: 73251
2002 Impreza WRX
So with the Street tuner software the AP is as/more tunable than the UTEC? How about the ease of tuning for the AP, should most tuner shops be able to tune a AP with the street tuner software? I'm trying to make the same decision. From reading it looks like the AP is limited without the street tuner software once you start getting more mods.
Stellar1 is offline   Reply With Quote
Old 05-05-2005, 08:07 PM   #8
shinsain
Member#: 51745
LIKE A
BOSS
I'm not sure about the relation between tuning shops and the Street Tuner software. I know that it is as flexible as anything else, plus you can reflash it w/ the AP once you make your map, so its simple as well.
The AP is *sort of* limited. It all depends on what mods you want to do. If you want to vary from their list, yes, its limited. But they have maps for VF30/34's and all supporting mods, so its not too limited. And the ECU can tune for things like I/C hoses, uppipes, etc. So you're not limited to *exactly* what they say with the AP, but changing things like the intake or intercooler is not recommended.
But with ST, you can do whatever you want. And when Pro Tuner comes out, you can take it to a shop and they'll do it for you.
I know a few shops work w/ ST, but you'd have to call and find out who's had experience w/ it.
Aaron
Old 05-05-2005, 08:16 PM   #9
Stellar1
Member#: 73251
2002 Impreza WRX
I know this sounds stupid, but is street tuner something you can tune by just running on the road? Is it pretty simple/easy to use for someone with no experience tuning? Is there a way for someone to upload there map onto like Nasioc or something, so where if someone had the street tuner, and went and tuned it with an upgraded intercooler or something, could they upload it somewhere so other people could d/l it?
Edit: Right now I have a TXS shorty intake and a TBE. I was lookin at gettin some sort of engine management next, and then maybe a bigger TMIC, like APS.
Old 05-05-2005, 08:31 PM   #10
shinsain
Member#: 51745
LIKE A
BOSS
You would have to ask Cobb. It is software to make the AP maps. I myself have only seen, and not messed with it too much.
Old 05-05-2005, 08:35 PM   #11
Surgical22
Member#: 76730
2005 STi
Aspen White BEEYOTCH
Ive been tryiing to make the same decision lately (UTEC/AP)
I have come to this conclusion.
I do NOT have big plans immediately, talking maybe 3-4 years down the road. I'll run cobb stage 2 untill then.
The resale value on the AP is incredible, mainly because they are sold at a fixed price (new) you can pretty much bank on losing maybe $100 tops on an AP....so I'll go AP and should I need the tune-ability ill go with the software, or sell the AP and go UTEC...(Ive seen them sell used for STi's for 600)
Surgical22 is offline   Reply With Quote
Old 05-05-2005, 08:46 PM   #12
shinsain
Member#: 51745
LIKE A
BOSS
That's another good point, the resale of the AP.
Old 05-05-2005, 09:12 PM   #13
mnavarro
Member#: 51537
2004 WRB WRX STI
62 Corvette/11 Cherokee L
I think the AP is a good architecture, but not everything is in place to create quality maps. I've heard a few comments from some tuners about the ST and say it's a PIA to tune. UTEC is fairly ubiquitous. You will always find somebody who will know how to tune your car. Cobb has a good product, but I know of some people who were detonating on cobb maps. AP != absolute safety. I honestly think Ecutek is a good solution for most people, similar to AP, but not hardware based. You can mod to your hearts content and have nice driveability. Cobb is not there yet, but will be there eventually. I would get Ecutek over utec, and cobb right now, if I was modding my car and had to make my decision today. If I wasn't modding I would get the AP and go with one of their stage setups. I'm currently running Ecutek, but I'm going to be running Utec over it so that I can have multiple maps, valet maps, security, etc.
mnavarro is offline   Reply With Quote
Old 05-05-2005, 09:18 PM   #14
Surgical22
Member#: 76730
2005 STi
Some of us dont have an ecutek or utec tuner nearby though, so that makes it hard to go that route. I dont want to drive 300 miles every time I get a new mod, and not to mention fork over $200+ each time to have it tuned.
I actually just talked to a shop here who is in the process of getting an AWD dyno, (they have a dynojet 2wd upgradable to awd now) and they said they do street tuning on the utec, and it runs $85 per hour....
Thats not bad, but I'm sticking with cobb for now.
Old 05-05-2005, 09:27 PM   #15
mnavarro
Member#: 51537
2004 WRB WRX STI
For the most part, any quality tune is > than stage map. If you're just going to stick with the stages, pick the ap and you will have a nice upgrade path in the future. If you want the most out of your setup and want to learn about engine management, get the utec or AP+ST. If you want to get the most out of your setup right now and have great driveability get the Ecutek, even if your tuner is 300 miles away.
Old 05-05-2005, 09:33 PM   #16
Surgical22
Member#: 76730
2005 STi
Yeah I agree with that, and in reality like I said im going with EM and a TBE, for now so it would only be one drive, which is no big deal.....but in all honesty with the price difference between the AP and the UTEC+paying for a tune+the drive, the extra $600-700 total it would cost me wound not be worth the 5-10 WHP I MAY or may not get from using the utec with the custom tune.
I'm no stranger to tuning, Ive tuned a couple cars with the LM-1 and an SAFC (Nissans) but a $32k car is not something I really want to mess with right now...LOL
Old 05-05-2005, 10:18 PM   #17
Evil STI
Member#: 36792
2012 TuRD
Special Edition
How does Xede/Vishnu rate among what has been spoken of so far?
Evil STI is offline   Reply With Quote
Old 05-06-2005, 12:23 AM   #18
mnavarro
Member#: 51537
2004 WRB WRX STI
Xede has the potential to be good, as far as driveability it's supposed to be smoother than utec. The problem, it's kind of hard to tune, and not too many people know how to tune the xede. Shiv is a good tuner, but I would want to have the option to use somebody else. I sold mine
Old 05-07-2005, 10:45 AM   #19
subiDriver
Member#: 79214
2004 Stg II wRx
pSm
thanks for all of your feedback
Old 05-07-2005, 10:46 AM   #20
subiDriver
Member#: 79214
2004 Stg II wRx
pSm
thanks for all of your feedback and comments
cobb vs utec vs ecutek ridexstraight AccessPort 5 11-07-2008 02:54 PM
Cobb vs. Utec pro's con's? MarkRacerX Engine Management & Tuning 10 04-03-2007 06:38 PM
COBB vs UTEC tblackgt350 AccessPort 1 01-23-2007 05:48 PM
Cobb vs utec vs ecutec Lopez75 Engine Management & Tuning 0 05-17-2005 03:00 PM
Cobb vs Utec STUDAndring Newbies & FAQs 5 06-15-2004 09:29 PM
Message Board Statistics All times are GMT -4. The time now is 12:38 PM.
