05-05-2005, 03:01 PM | #1 |
Member#: 81234
Which gauges do I need? Help!
Hello,
I just bought a boost and oil temp combo gauge, and was wondering what other gauges I really need and why? Oil Pressure, EGT, Air/Fuel, ETC. Trying to keep the my total # of gauges to four. Any input appreciated. Thanks
05-05-2005, 03:34 PM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Depends on how modded your car is and how you drive it.
Right off the bat you can forget about the A/F gauge unless it's a real one with a wideband 02 sensor. The "tapped in" ones are worthless. EGT is useful if you have power mods and run more than stock boost. |
05-05-2005, 03:37 PM | #3 |
Member#: 77483
NWIC
Vehicle:2009 Audi A3 2.0T q Lava Grey |
Where'd you get the combo guage?
05-05-2005, 05:50 PM | #4 |
Member#: 81234
I am getting the combo from a gentleman on subaruforester-com, I think that they are only made for the forester though.
As far as mods, I am just thinking of putting a vf39 on the Fxt. |
05-05-2005, 06:20 PM | #5 |
Trust no one
You can't "just" swap the turbo, you need proper engine management and supporting mods to go with it. But if you're going in that direction, an EGT gauge is definitely a good idea.
Which brake calipers are these? Which pads do I need? | oldhat | Brakes, Steering & Suspension | 13 | 08-16-2006 03:54 AM |
Blew out first gear, which parts do I need? | CBoldman | Transmission (AT/MT) & Driveline | 4 | 02-19-2004 10:47 AM |
Which clutch do i need, WRX or RS? | edkwon | Transmission (AT/MT) & Driveline | 1 | 03-28-2003 08:48 AM |
which gauge do you use EGT or Pyrometer? | AndyM | Interior & Exterior Modification | 2 | 09-19-2002 07:40 PM |
Which DP do I need for the HKS catback? | Subi-fied | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 04-11-2002 10:28 PM |
