Old 05-05-2005, 07:30 PM   #1
Uncle Ben
Member#: 28628
2003 WRX Sedan
World Rally Blue Pearl
Default JDM Headlight Adjustment
I was in the garage this afternoon trying to adjust the highbeam/lowbeam on my JDM headlights, and wasn't sure if I was going about it correctly. Does the top adjuster control the vertical movement of the highbeam and the bottom adjuster the vertical movement of the lowbeam? I inserted a flathead screwdriver between the "teeth" of the adjusters and just turned them either clockwise or counter... the bottom adjuster seemed to make the lowbeam move up and down but the top one didn't affect anything. Right now I have the driver's side highbeam way up there and the passenger side staying very low.
There also seems to be two sets of teeth on the adjusters, the outer metal teeth and the inner white plastic ones. They didn't seem to be interlocking either, they moved independently? Which ones should I be turning?
Uncle Ben is offline   Reply With Quote
Old 05-06-2005, 04:12 AM   #2
vinceGC8
Member#: 72263
2008 Impreza STi
Dark Grey Metallic
i beleive the one u have highlighted as "highbeam" is the horizontal adjustment and the "lowbeam" is vertical adjustment. (correct me if i am wrong)
i am not completely sure about the high beam adjustment.
vinceGC8 is offline   Reply With Quote
Old 05-06-2005, 04:23 AM   #3
hey1
Member#: 72106
2002 Impreza WRXagon
Platinum Silver Metallic
no no no
one is height adjustment.. (up down) the other is (left right).. the position for both high and low beam are fixed.. so when you adjust low beam.. you're adjusting high beam as well
hey1 is offline   Reply With Quote
Old 05-06-2005, 04:27 AM   #4
hey1
Member#: 72106
http://jdmpartstx.com/hid_install/
the wiring is pretty much the same.. except we don't have to worry about grounding the ballast..
the "T" right besides one of the screws on the low beam needs to be connected to HB3 negative.. forming a common negative. the low beam positive and the high beam positive connects separately/independently..
stripped jdm headlight adjustment screw! ASpec818 Electrical & Lighting 9 05-04-2007 11:36 AM
JDM Headlight Adjustment ? 4npower Electrical & Lighting 0 09-03-2006 12:49 AM
JDM headlight adjustment??? apemanwrx Electrical & Lighting 2 10-12-2003 12:42 PM
JDM Headlight adjustments? wolfman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-23-2003 11:51 PM
JDM Non-HID Headlight adjustement zacek Interior & Exterior Modification 1 06-04-2002 09:38 PM
