Old 05-05-2005, 10:36 PM   #1
Blizwinter
Member#: 46147
WR BLUE
Default Anybody running an intake with cobb stage 2
Just wondering if anybody is running an intake with there cobb stage 2 and have noticed anything from it(like better throttle response)
Blizwinter is offline   Reply With Quote
Old 05-06-2005, 05:45 AM   #2
wrxer12
Member#: 50259
2004 WRX
Just installed the new Typhoon tonight and everything is running fine. No real throttle response but pulls easier and with a little more top end. Research before you buy and you'll be fine.
wrxer12 is offline   Reply With Quote
Old 05-06-2005, 05:54 AM   #3
mikey_750
Member#: 36081
2005 STI
I'm running a ARC induction box. Throttle response is better, with more high end pull. I have not had any problems yet.
On a related note, is anyone running a different top mount intercooler with their AP stage 2?
mikey_750 is offline   Reply With Quote
Old 05-06-2005, 09:41 AM   #4
Blizwinter
Member#: 46147
WR BLUE
I'm not, but on clubwrx I have heard of guys running even a frontmount and are doing fine. They said to buy an egt gauge to monitor levels, but they said really until stage 3 comes out you won't unleash the full potential. Hope this helps.
Old 05-06-2005, 09:33 PM   #5
GotHP?
Member#: 51138
2015 LE STI
Lots of people have intakes with AP stage 2, haven't seen any real data yet (or any failures) that suggests there is an issue. Seems a bit ironic that Cobb says not to use ANY intakes, yet they're about to release one that will work fine....
GotHP? is offline   Reply With Quote
Old 05-06-2005, 11:38 PM   #6
MeetMrGlock
Member#: 50885
04 CUTN EDG STi
neanderthal blackout
hey, when youre faced with a competitor who's able to get a great product out more than a year before you can, you do what you gotta do to keep people hanging on...lie.
typhoon
MeetMrGlock is offline   Reply With Quote
Old 05-07-2005, 12:07 AM   #7
Blizwinter
Member#: 46147
WR BLUE
so what intake is good to get, the typhoon?
Old 05-07-2005, 12:09 AM   #8
Blizwinter
Member#: 46147
WR BLUE
another question, who here runs a cold air intake, and if you do how do you keep the filter from getting wet?
Old 05-07-2005, 12:28 AM   #9
KitchenerWRX
Member#: 79934
02 WRX
MBP
avoid driving in the rain, avoid puddles, dont go to the car wash
and remember to clean it every once in a while
KitchenerWRX is offline   Reply With Quote
Old 05-09-2005, 05:15 PM   #10
wrxer12
Member#: 50259
2004 WRX
After running for a few 100km, the intake is fine and causes no problems at all. The added sound is very addicting.
Old 05-09-2005, 05:19 PM   #11
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
I doubt that the intake added much in the way of HP, but the combating sound of air sucking in through the intake and then blowing out of the BOV is crazzzzy!!!
i have a short ram, btw.
markuswelby is offline   Reply With Quote
Old 05-10-2005, 10:10 AM   #12
Cadaver
Member#: 59015
2004 WRX
I have the Injen CAI and haven't had any problems with it. When I got my AP, I did have a problem getting the boost levels that I wanted but don't think it was related to the CAI. Also, I've read alot about a CAI making someone run lean, but I was actually running real rich... ???
Cadaver is offline   Reply With Quote
Old 05-14-2005, 11:30 AM   #13
Darryl
Member#: 1626
'02 RevLab 11.5:1
Platinum Silver
I've got the old APS/Cobb Club Spec kit which has the APS intake. I'm running the stage2 reflash for 93-oct. The only problem I have is my belief that the map runs too rich, hence my little gas guzzler. I also believe it's due to the added fuel needed for the intake's greater capacity. I wish there was some way to lean the car out in open-loop mode, but Cobb no longer supports this old setup. Anyone got any ideas? Partially block the maf (a wag, to be sure).
thanks,
Darryl
Darryl is offline   Reply With Quote
Old 05-14-2005, 11:33 AM   #14
Darryl
Member#: 1626
'02 RevLab 11.5:1
Platinum Silver
Oh yeah,
Safe is safe, but I think Cobb is a bit too conservative in it's mapping. What vendor can achieve a more efficient tune with the stock fuel system?
me again
Old 05-14-2005, 11:54 AM   #15
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
ha ha ha
anthonyrb98 is offline   Reply With Quote
Anyone using TurboXS Shorty intake with Cobb Stage 2? xstuning AccessPort 0 03-18-2010 09:10 PM
Intakes and Cobb Stage 2 PolePosition08 Engine Management & Tuning 4 06-06-2005 11:47 AM
Anyone ran 1/4 mile with Cobb stage 2 and stage 2 HWG map? txl146 Engine Management & Tuning 2 05-15-2005 08:08 AM
Who is Running a Ext. BOV with Cobb Stage 2??? ScottPWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-14-2004 02:00 AM
Anyone with Cobb stage 2.5 running w/o Fuel pump? WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-07-2004 06:52 PM
