Old 05-06-2005, 03:40 AM   #1
cerelius
Member#: 85802
2005 WRX sedan, 5-sp
WR Blue
Exclamation Another question -- Whining noises from engine at low rpm = good/bad?
Hi, after getting more comfortable with the clutch in my newly acquired '05 WRX, I am now noticing that my engine whines. This is when the gear is fully engaged on 1st, 2nd, or 3rd gear, and I step on the gas slightly. I have driven a turbo before, but I am not so sure this whining noise is normal: it's like a scream, really (a la Airwolf, except much higher pitched). Now, does anyone know if I should be concerned about this high-pitched scream?
I get the same noise whether I put in 87, 89, or 91 octane fuel. (87o is bad, bad, bad... my car gets wretched sick on that stuff so I will not put that in again)
cerelius is offline   Reply With Quote
Old 05-06-2005, 07:48 AM   #2
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
*bows head in shame at the mention of using the wrong fuel YET again*
Screaming? Make sure your parking brake is not on.
conker69 is offline   Reply With Quote
Old 05-06-2005, 08:11 AM   #3
peddlerex
Member#: 77432
i tend to get the same thing (i believe) from what i get out of it, it seems to be the tranny winding down, possibly tranny strain, but im not tooo sure. i anyone could be some help to cerelius and im sure wed both be grateful. thanks!
peddlerex is offline   Reply With Quote
Old 05-06-2005, 08:46 AM   #4
coldfire22x
Member#: 77328
2005 WRX Wagon
you sure it's not just the turbo spooling up?
coldfire22x is offline   Reply With Quote
Old 05-06-2005, 09:29 AM   #5
drrice
Member#: 82595
let me see ur feetz
yea dont put 87 or 89 back in and youneed a new fuel filter sir.... 87 and 89 is bad for it
drrice is offline   Reply With Quote
Old 05-06-2005, 09:43 AM   #6
Davenow
Member#: 23676
There is absolutely no reason to replace the filter
Its not like 87 is dirtier than 91. Just drive it easy till the 87 is gone and fill up with 91 minimum and resume beating it.
Sounds like an up pipe leak to me, which would be odd on an 05...
Old 05-06-2005, 02:20 PM   #7
etrnlderek
Member#: 85961
2005 WRX
Crystal Grey Metallic
I just recently purchased a 05 WRX and have the same sound. I think its just coming from the transmission. Never driven a Subaru so I have no idea if this is bad or not. Seems fine so far.
etrnlderek is offline   Reply With Quote
Old 05-06-2005, 03:56 PM   #8
KingOfSiam
Member#: 84636
2005 WRX (automatic)
Crystal Gray
I get some noise too from 2000-2500 rpm's. It's not really a whine but almost like a *whoosh* sound of air escaping.
Bone stock, btw.
KingOfSiam is offline   Reply With Quote
Old 05-06-2005, 04:10 PM   #9
WRXTuan
Member#: 61294
04' WRX
4eAT San Remo Red
It just means step on the gas a little longer until you don't hear it anymore. BTW, i believe it's the turbo spooling at low RPMs.
T.Vo
WRXTuan is offline   Reply With Quote
Old 05-07-2005, 04:59 AM   #10
cerelius
Member#: 85802
WR Blue
Impreza WRX
Hi guys, "Turbo spooling up"? At 1500-2500 rpm... sounds kind of strange, I thought the turbo only kicks in after 3000. Mainly concerned about the intensity and high-pitched tone of the whine / whoosh; I've driven a turbo before ('89 LeBaron GTS), and the whining noise is much lower pitched and much less noticeable. If this is a factor of the engine's energy output, I suppose a screaming whoosh could be expected.
If it's not, then I'd be interested in a way to adjust the intensity and pitch of the whine without having to step on the accelerator. Call me picky, but I like my car to sound right.
Old 05-07-2005, 05:21 AM   #11
TurboReXx007
Member#: 84148
2005 Wrx
black
i dont think that sound is bad...maybe your brakes are rubbing?
TurboReXx007 is offline   Reply With Quote
Old 05-07-2005, 06:10 PM   #12
SpaldingSpeed
Member#: 83640
World Rally Blue Pearl
I know in the STi I get lots of different noises if I'm in a low gear and let the engine brake the car down (differential sound) I assume that what you're hearing is simply tranny noise......wouldnt worry about it, these things make noise...welcome to Subies
SpaldingSpeed is offline   Reply With Quote
Old 05-07-2005, 06:14 PM   #13
KingOfSiam
Member#: 84636
Crystal Gray
Ya if these things weren't so darn reliable I'd be concerned.
Old 05-07-2005, 10:33 PM   #14
scooby888
Member#: 64226
2004 Impreza WRX
World Rally Blue
Mine makes weird humming noises decelerating second gear...that wonderful boxer engine and its many wonderful sounds...it is completely normal I think.
scooby888 is offline   Reply With Quote
Old 05-07-2005, 11:07 PM   #15
VSG
Member#: 19435
The turbo doesn't suddenly start spinning at 3000 RPMs. It's spinning at lower RPMs just not enough to make a noticeable difference in power.
I have a somewhat quiet high pitched whine at around those RPMs. It definitely changes depending on how much I'm on the gas. If I'm off the gas, there's nothing. Once I give it more gas the sound is drowned out by engine and road noise. Sound familiar? If so you've got nothing to worry about.
VSG is offline   Reply With Quote
Old 05-08-2005, 12:35 AM   #16
scoobyzip
Member#: 82496
2004 WRX
platinum silver
what VSG said...when you press the gas the turbo starts to spool, the "kick in" you refer to is when you are making full boost...if the noise is during accel. then its the turbo spooling (normal) and on decel. the tranny seems to have a whine to it (seems to be a normal thing from everything i've read)...either way you have nothing to worry about imo
scoobyzip is offline   Reply With Quote
Old 05-08-2005, 04:11 AM   #17
hystikal
Member#: 83294
2011 E90 M3
2011 Prius
you guys are describing the turbo spool. it's not a disconcerting sound...it's sexual.
hystikal is offline   Reply With Quote
Old 05-08-2005, 01:15 PM   #18
yergi
Member#: 65303
nope nope
"dooby specialist"
but seriously... have you modded anything with the car? could be a pre-turbo exhaust leak if it happens above 3K rpm's
yergi is offline   Reply With Quote
Old 05-08-2005, 06:06 PM   #19
cerelius
Member#: 85802
WR Blue
OMGHi2U
Hi, thanks for all the input, everyone. No, my car has not been modified yet -- embellished, yes; actually modified, no! I have to figure out its personality first!
But, from what everyone is saying, it sounds as if the screaming / whining / whooshing noise is most probably the turbo getting an early start at around 1500 rpm. If the turbo is so prevalent at lower rpm's, I wonder if it's actually able to go full capacity at higher rpms in my steed. Oh, and the screaming isn't a sexy noise to me -- purring, now that's sexy.
Old 05-08-2005, 07:37 PM   #20
WRXakaBooSTi
Member#: 61119
2004 Stock WRX
apparently this sound is normal on wrx's. when i first got my 04 i was worried about it too but got used to it. and after searching posts it seems most everyone has this problem, if it even is a problem. still, people cant figure out wat the noise is. with the music up youll never hear it again.
WRXakaBooSTi is offline   Reply With Quote
Old 05-08-2005, 07:41 PM   #21
intence
Member#: 58477
. Member #1 of
the witty MS Crew
i get this "whirring" sound like something is winding up in the 1st 3 gears when i give it a little gas. at first i was worried but it hasnt caused my car any problems. could it possibly the synchros making the sound?
intence is offline   Reply With Quote
Old 05-08-2005, 07:48 PM   #22
KingOfSiam
Member#: 84636
Crystal Gray
That's exactly what I get, but I got the 4EAT. So I don't think it's the transmission.
Old 05-08-2005, 10:08 PM   #23
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
it's the turbo,synchros don't whine. they grind (if you **** up)
vtecTHIS is offline   Reply With Quote
Old 05-08-2005, 10:58 PM   #24
intence
Member#: 58477
. Member #1 of
the witty MS Crew
i know what my turbo sounds like as i have the intake silencer off. im positive this sound is not coming from my turbo. sounds like its from my tranny to me.
Old 05-09-2005, 03:41 AM   #25
dubrXSti
Member#: 49541
Trapped in a
glass box of emotion
how ever bad this sounds it is totally correct
dubrXSti is offline   Reply With Quote
Bad Noises at Low RPMs golf97 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 02-06-2008 11:59 PM
Odd noise from engine at times Teksi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 01-20-2007 10:33 PM
Whining sound at low RPM trickniner Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-09-2006 11:28 AM
another question about noise from the rear! daprez Brakes, Steering & Suspension 2 04-02-2006 11:37 AM
Weird on and off whining noise from the engine bay WITH THE CAR OFF. JM530 Car Audio, Video & Security 6 03-21-2006 08:29 AM
