Old 05-06-2005, 01:34 PM   #1
manman99
Member#: 51343
Smile UTEC TPS Cross Over Point
HI,
what is the default TPS cross over point?
I come across 60% and 25%, which is the correct values?
Can I change it to 10%?
Thks
Cheers
lam
manman99 is offline   Reply With Quote
Old 05-06-2005, 01:42 PM   #2
serendipity
Member#: 54597
08 'Busa, 08 ML63
10 Multistrada, 996 Targa
If you're using the Open Loop Fueling feature of the newer UTECs, the parameter in the Open Loop Fueling parameters section applies, with a default of 25%. If you're not using Open Loop Fueling, the other parameter (Tuner Constants? I forget where it lives) applies, with a default of 60%.
If you're using OLF, you can pick any value you want, although it's kinda pointless to go into open loop at 10%. I find somewhere in the 25-35% range works well for me, to keep it in closed loop for normal driving.
If you're not using OLF, it won't do you any good, from a fueling perspective, to set it lower than 60% - it could in fact be dangerous, since you're applying fueling corrections to values the ECU is using in closed-loop mode. It's best to just leave it at 60% so it takes over when the stock ECU does.
If you have a choice, I would definitely run OLF though.
serendipity is offline   Reply With Quote
Old 05-06-2005, 02:03 PM   #3
manman99
Member#: 51343
Smile
Thks for the reply
can you explain when we use OLF and CLF?
THks
Old 05-06-2005, 04:01 PM   #4
hippy
Member#: 36528
2002 Impreza Wrx
Originally Posted by serendipity
....If you're using OLF, you can pick any value you want, although it's kinda pointless to go into open loop at 10%......
No you can't. There's a minimum amount you can set the tps crossover to(I forget it's either 20 or 25%). You can manipulate the way the utec see's throttle position to get a lower crossover point, but noone really does that as far as I know.
A 25-35% tps isn't the best crossover for everyone. If you're running a wrx with a stock turbo, injectors, and intake, the tps could be set a bit higher(upto 60%) as long as the boost is kept low below the tps crossover.
peace
Old 05-07-2005, 12:20 AM   #5
manman99
Member#: 51343
Thks Guys.
big turbo+utec+TPS= :( culmination Engine Management & Tuning 3 10-12-2005 06:11 PM
TPS minimum mapping point change to 25%?? eightballrj Engine Management & Tuning 0 09-28-2003 04:20 AM
UTEC - TPS threshold point - question please ndw1138 Engine Management & Tuning 2 03-24-2003 10:40 PM
Impreza legacy cross over question slide Legacy Forum 5 03-05-2001 04:56 PM
Chevy Borrego - Cross-over concept uses Subaru engine and AWD drivetrain macrac General Forum Archive 4 12-07-2000 12:05 AM
