Old 05-06-2005, 08:43 PM   #1
west
Member#: 45828
2004 impreza wrx sti
black/gold
Default [EGT,OIL]Where is the best place to install the sensors to my gauges in the engine?
I own a 2004 sti and have resisted major mods till now. I am planning for my future project so I thought it would be a good Idea to start off with some important guages.
I just recently purchased an oil temp,oil pressure,exhaust gas temp. and boost gauge but have little clue on where to find the info on where to place the sensors so I am asking for help.
I have heard there is a place already taped in the up pipe on the sti, is this true all I can see is the factory sensor.
On my wifes car the oil drain plug is tapped and the oil temp sensor is placed there. It seems like a stupid spot but thats how it came from the factory.
I want to thank everyone in advance for your help.
Once this is done a deadbolt superzilla will go in along with aps deletes etc....
WEST
west is offline   Reply With Quote
Old 05-06-2005, 09:02 PM   #2
Axan
Member#: 17569
2011 Impreza WRX STI
boost gauge - tap the smaller hose comming off the bov
egt - uppipe and downpipe are crappy spots to put it, for most accurate readings tap the exhaust manifold on passenger or driver side.
http://www.scoobymods.com/forums/showthread.php?t=3367
oil temp and pressure - you have few choices here you can get an oil filter sandwich adapter and install the gauges there( something like this http://www.wrxtra.com/cat_7.html) or you can use the oil ports next to ic and alternator.
http://www.scoobymods.com/forums/sho...=&threadid=360
http://www.scoobymods.com/forums/showthread.php?t=612 oil port next to ic
there is one exactly like it near alternator but the factory dummy oil light is hooked up there(its useless and its ok to replace it with a proper gauge)
Axan is offline   Reply With Quote
Old 05-06-2005, 10:04 PM   #3
west
Member#: 45828
black/gold
Thanks axan! The egt is then only watching one bank?
Not like the old air cooled setups then but I suppose this will work. I will end up most likly going to the passenger side till I find a better solution.
Which is the cylinder that always goes in the subaru? iIs it the #3 or is it #4?
man that sandwitch is pricy I think i have an old bugpack one lying around. Beter yet I may check on the other spots.
WEST
Where is the best place to mount an external map sensor? jigga Built Motor Discussion 21 04-01-2015 12:39 PM
Where is the best place in my 08's firewall to route my 4GA power cable? montyleew Car Audio, Video & Security 6 01-03-2010 01:15 PM
Rare opportunity to take some pics of my car in the rain.... Calitri-Boost Member's Car Gallery 94 12-09-2007 11:44 PM
Where is the best place to get an Up Pipe installed in East TN? tblackgt350 South East Region Forum 8 01-06-2007 12:16 AM
I would like to post a pic of my Scooby in the blue thread runner19 Newbies & FAQs 3 10-27-2004 10:09 AM
