Old 05-07-2005, 01:22 AM   #1
airspeed
Member#: 47919
2002 wrx
blue
Question Humming Noise when clutch pedal is not depressed
Guys, I have RA GEARS with a clutch masters stage 3 kevlar. I have a humming noise when the car is idling, however when I depress the clutch pedal the noise disappears. Any suggestions as to what this might be.
airspeed is offline   Reply With Quote
Old 05-07-2005, 02:58 AM   #2
majmun
Member#: 18298
2004 STi
Sounds normal.
majmun is offline   Reply With Quote
Old 05-07-2005, 12:25 PM   #3
Hayes
Member#: 11808
I wonder if the throwout bearing is fully retracting. Could be the bearing is touching the presure plate lightly causing the bearing to spin but not causing a problem shifting.
Hayes is offline   Reply With Quote
Old 05-08-2005, 01:45 AM   #4
99Lcoupe
Member#: 75789
i have a simular problem with my car a light sounding noise then i barely touch the clutch pedal and it goes away ... do i have a serious problem or, .....do i need to fix anything right away....
99Lcoupe is offline   Reply With Quote
Old 08-11-2008, 12:39 PM   #5
abosworth
Member#: 53856
2012 Speed3
Red Mica
I hear the same on my car. When I have it idling with the clutch pedal engaged it makes a noise. Then when I push the pedal in, the noise goes away. It's just a little whining noise. Not loud or really that noticeable. Any ideas?
I figured I'd bump this instead of making a new thread.
abosworth is offline   Reply With Quote
Old 08-11-2008, 01:26 PM   #6
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
Sounds normal.
With the car in neutral but the clutch engaged the input shaft spins at engine speed. So the input shaft and 1st and 2nd are all spinning and some noise results. Depress the clutch and the shaft stops spinning and the noise goes away.
Phil
AndrewtechAutomotive is online now   Reply With Quote
Old 08-11-2008, 01:52 PM   #7
abosworth
Member#: 53856
2012 Speed3
Red Mica
Originally Posted by AndrewtechAutomotive View Post
Sounds normal.
Phil
Thanks,,
Old 08-11-2008, 02:40 PM   #8
GHK
Member#: 103886
2005 WRX
Have the same noise in my car since about 10k miles. my car now has about 60K now and it still drives great!!
GHK is offline   Reply With Quote
Weird jingling noise when clutch is depressed... DoodieHead Transmission (AT/MT) & Driveline 9 01-14-2008 03:23 PM
Weird bubbling noise when clutch pedal is pressed in? tobylazur Transmission (AT/MT) & Driveline 1 07-28-2007 01:58 AM
Bad noise when clutch is depressed, dealer says tranny going out... AnthonyA182 Transmission (AT/MT) & Driveline 5 06-04-2007 02:45 PM
Metallic Clicking sound when clutch pedal depressed Craig W Transmission (AT/MT) & Driveline 4 07-31-2005 11:14 PM
Squeaking noies when clutch pedal is fully released help!! Boom Transmission (AT/MT) & Driveline 4 12-26-2001 01:01 AM
