Old 05-07-2005, 07:57 PM   #1
Guru Imakuni
Member#: 58773
Default Need some computer building help.
I'm trying to build my my mom a new computer for Mother's Day. I put everything in (mobo, hard drive, cd drive, ram) and plug it in. When I turn it on...nothing. The fan will jolt a little bit so it's get power for a fraction of a second. Then nothing. It seems like a short and I've put plastic under the mobo so the only connection between the mobo and the metal case is the screws.
Could placing the power, LEd, hdd LED connectors on improperly cause this? I don't havethe original manual and I can't figure out what ACPI one is for.
Could it be anything else that's causing this other than a short somewhere else in the system?
Guru Imakuni is offline   Reply With Quote
Old 05-07-2005, 08:04 PM   #2
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
Assuming the components are good, and the PS is hooked up right....I'd get on the web and get the manual for the motherboard and figure out where the connectors go. Flipping those can make it fail to power up.
good luck.
mexicanpizza is offline   Reply With Quote
Old 05-07-2005, 08:09 PM   #3
Guru Imakuni
Member#: 58773
I was thinking it could be the PSU but I doubt it. I've never had one go on me so I don't know why this one would just do it when I've used the computer before. Last time I used it I transfered cases and left it alone for awhile.
I found the manual online but the document is all screwed up. I'm opening it up in MS Worse and all these little boxes were jumbled together. This is the best I got out of it, which is pretty much the same thing printed in mico sized letters on the mobo. I can't find a + or - anywhere. http://img.photobucket.com/albums/v2...asioc/mobo.gif
Old 05-07-2005, 08:19 PM   #4
catass
Member#: 31976
2004 WRX STi
World Rally Blue
sounds like bad psu. i had the same exact symptoms recently.
catass is offline   Reply With Quote
Old 05-07-2005, 08:32 PM   #5
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
What motherboard is it?
Old 05-07-2005, 09:41 PM   #6
Guru Imakuni
Member#: 58773
I'll try another PSU...
It's an M935 from PC Chips. I've never heard of them before and the single sided leaflet I got with the mobo didn't even have their name on it. I don't even know how I found their site. You can try viewing the manual by clicking "manual". It's all distorted for me though.
I had originally got it as a barebone off of eBay for like $100. I was slowly upgrading components on it until I eventually had enough to make a full fledged computer so I took it out. It didn't run games very well but for an office PC it would be fine. My mom's work won't give her a new (or decent) computer - it's still running Win95.
Old 05-07-2005, 09:43 PM   #7
Fuzz541
Member#: 4739
Why don't you just spend another 30 bucks and buy her a Dell?
Fuzz541 is offline   Reply With Quote
Old 05-07-2005, 09:48 PM   #8
Guru Imakuni
Member#: 58773
Because then it would be a Dell.
Old 05-07-2005, 10:36 PM   #9
wagman01
Member#: 3894
2002 WRX Wagon
Battlewagon Black
Is the CPU fan hooked up to the "CPU FAN" port on the mobo? Some motherboards won't boot unless they feel a fan connected to teh CPU FAN port.
EDIT: Also, start with basic troubleshooting. Unplug EVERYTHING that's not needed for the computer to POST (cd drive, soundcard, floppy, etc.) Start from there.
wagman01 is offline   Reply With Quote
Old 05-07-2005, 10:39 PM   #10
Davenow
Member#: 23676
Wasted effort. If you shorted the mb to the chassis the MB would be dead, as in fried.
Sounds like a dead power supply to me
Old 05-07-2005, 10:44 PM   #11
Bottom Feeder
Member#: 2808
I've put plastic under the mobo...
Please elaborate.
Bottom Feeder is offline   Reply With Quote
Old 05-08-2005, 01:04 AM   #12
Guru Imakuni
Member#: 58773
Well I always short something when I build computers. Fan does that really really short spin up. The blades will just jolt a bit. No more power until the plug is removed. Always thought it was a short but I guess not. I do know it's happened on my different computers though. I was thinking it was my 9800 Pro being lame but I know that's not the case as this little junker has no AGP slot and is displaying doing this "occurance".
I put plastic wrap under the mobo between the case. Never thought you needed to but I tend to put the plastic foam that comes with mobo under it to prevent any electrical connections. Didn't have that foam so I used Saran Wrap (generic brand).
Old 05-08-2005, 01:33 AM   #13
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Um... Saran Wrap is a bad idea. You know.. STATIC cling. Try going to Radio Shack and buying some rubber mounts to put under the board.
Also try this trick... unplug the PSU from the wall, click the PC power switch a few times, unplug the ATX connector to the motherboard...plug ATX connector back in, plug PSU back into the wall, try turning it on.
Make sure the PSU is set to 115 and not 230 also. That can cause some weird stuff and is often overlooked.
WRX_02_227 is offline   Reply With Quote
Old 05-08-2005, 02:24 AM   #14
svek
Member#: 82259
1999 impreza 2.2L
Brilliant Red <4EAT Club>
make sure you have the heatsink seated properly. i remember a p4 build i did and if the heatsink wasnt competely tightened down it wouldnt post. also make sure "clear cmos" jumper is set to 1-2 instead of 2-3. if this doesnt work physically apply pressure to the heatsink. (towards cpu)
svek is offline   Reply With Quote
Old 05-08-2005, 02:24 AM   #15
trehlo
Member#: 16700
I had a similiar problem with a PSU that came with a brand new case from NewEgg. When I finally narrowed it down to the PSU I yanked it out of the case and this huge chunk of metal fell out of it. It could have shorted and taken out everything attached to it. Glad I paid for the two day air shipping too... Thanks NewEgg!
Anyway, assuming you didn't fry anything already, it sounds like the power supply, but the board not even coming with stand offs makes me call into question the quality of the mb as well. Just buy a cheap PSU from a computer store and see if that's the problem, if it isn't just return it and tell them it's the wrong wattage or something.
trehlo is offline   Reply With Quote
Old 05-08-2005, 03:40 AM   #16
thejaredhuang
Member#: 86206
2006 WRX Wagon
Or just take the mobo out of the case and see if it works.
thejaredhuang is offline   Reply With Quote
I need realtime computer building help! Capt Crunch Off-Topic 23 06-08-2009 10:17 PM
Need some computer network help... e11ys Off-Topic 12 08-31-2005 03:37 PM
Need some computer guru help....... CheezeWeezle Off-Topic 14 10-18-2004 07:52 PM
Need Some Computer Help ASAP Piecode314 Off-Topic 12 09-05-2003 07:27 PM
quick, need some computer help!!! IgotWRXed Off-Topic 8 08-22-2003 02:04 PM
