Old 05-07-2005, 09:12 PM   #1
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Default for al you ej20G guys
so i finnaly swapped out my vf-10 for a td05 ..
it had been sitting on my work bench for almost a year (or more i forget)
whoa much more fun
simmilar lag charteristics .. lots of top end
and i am only running .8 bar a the moment
http://www.kineteria.com/share/MVC02348.JPG
http://www.kineteria.com/share/td05vf10.JPG
http://www.kineteria.com/share/MVC02349.JPG
Old 05-07-2005, 10:26 PM   #2
Boxologist
Member#: 21118
the vf10 was the LegT turbo, right? ur saying that a td05-16g has the same spool up charachteristics? a little shocking.
Boxologist is offline   Reply With Quote
Old 05-07-2005, 10:54 PM   #3
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
Did you make changes to your fuel/ign maps?
Scoobie Steve is offline   Reply With Quote
Old 05-08-2005, 01:16 AM   #4
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
Did you notice a change in intake temps? Are you using an MBC for boost? or is the TEC 2 running boost?
subiekid is offline   Reply With Quote
Old 05-08-2005, 02:28 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
not identical spool but still pretty good
i made some changes i still haven't opened her up all the way still at .8 bar on the way to 1.2
i have to change the map sensor to a 3 bar and start all over again
i suspect that the narrow tec o2 sensor isn't telling me what i need to know .. (4th gear 5.5k rpm, 175kpa, 13.0 to 1, zero knock, 700C egts) i can't seem to get it lower than 13 to one ..
i have never really looked at the intake temps the tec corrects for them any way
still using a mbc .. need a EBC badly
Old 05-08-2005, 05:56 PM   #6
snowjob
Member#: 59357
2009 Forester XT
Hey Jaxx, what coils are you using for your ej20g? I'm going to have to go the replacement coil way before I upgrade the turbo.
Thanks
Frazer
snowjob is offline   Reply With Quote
Old 05-08-2005, 08:17 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
tec coils
Old 05-09-2005, 11:04 AM   #8
snowjob
Member#: 59357
2009 Forester XT
Hmm, so you converted the 4 coil setup to this two coil set up right? Where did you get them? Cost, how hard were they to set up?
Old 05-09-2005, 12:23 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Jaxx,
Nice to see the car move forward. That turbo should do you quite nicely. Your garage sounds like mine. My Vf-29 has been sitting for a year and a half, and is still six months from going in a car. But I finally acquired an engine worthy of it, so I am getting there...
Old 05-09-2005, 02:22 PM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the tec 2 is a standalon that date back to the RST(2000ish) days its is a full standalone.. vishnu mades kits for subaru adaption
the newest version the tec3r is very cool .. but expensive
the systems uses wasted spark and closed port injector pulse (2 coils 2 injector channels) used alot by domestic guys
i am at 85% idc so i guess its time to put the 550cc injectors in :P
Old 05-09-2005, 03:17 PM   #11
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Lightbulb
I put a TD05-16G (ported from Deadbolt) on my Legacy turbo motor last month. It is only running the 7psi wastegate right now, don't want to overwhelm my fuel system. It seems to spool simular to the old turbo and yes, has lots of top end power.
The car is not tuned and is running rich (for safety), I hope to do a little tuning now that I have a wideband.
Scoobyslack1 is offline   Reply With Quote
Old 05-09-2005, 06:16 PM   #12
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
hey alan you intersted in some 425cc injectors ?
Old 05-10-2005, 11:29 AM   #13
Scoobyslack1
Member#: 2780
junk yards rule!
Lightbulb
I have STi 550's sitting in a box next to my heads/cams that need to go in
but thanks any way
Old 05-10-2005, 01:04 PM   #14
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yeah i need to put mine in too i tried real hard to blow up my engine last night
car was fine at 180 kpa.. not fine at 190 but dam fast i was logging at the time ill post the graph tomight
for all you midwest guys camz911 Mid West Subaru Owners Club Forum -- MWSOC 12 10-24-2003 05:13 PM
For all you FMIC guys..... Tats Normally Aspirated with bolt-on Forced Induction Powertrain 17 10-14-2003 01:26 AM
A few questions for all you Forester guys jaybird Forester Forum 23 10-31-2002 11:08 AM
Question for all you tech guys/gals out there (kinda long, sorry) crxtls2 New England Impreza Club Forum -- NESIC 5 09-11-2001 10:13 AM
