Old 05-07-2005, 09:00 PM   #1
dingo dave
Member#: 33177
2000 Impreza RS coup
white
Default Exceeded RPM redline in 2nd gear...did i goof anything up?
I was entering an on ramp last night and had it in 2nd gear. The music was kinda loud and it was late on a friday night and i ended up exceeding the redline. I hit bettween 64 & 6500 rpm. I think the redline on '00 RSs is 6200, right. I noticed this when i felt my engine skipping, i guess it was the pistons giving way. Anyway, i immediately let off thr gas. It only lasted for about 2 seconds(the skipping part), at the most. It seems to be driving fine today and it drove fine immediately afterwards. Is there anything i permanately may have messed up?
thanks for continued help.
dingo dave is offline   Reply With Quote
Old 05-07-2005, 09:02 PM   #2
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
-Brett
ExecNav is offline   Reply With Quote
Old 05-07-2005, 09:03 PM   #3
FNR32
Member#: 84147
03 WRX
I don't THINK so... Thats what the rev limiter is for to prevent you from ****ing up something... I think if there was any damage it would prolly be with the trannie if any. Ive done this a few times didnt seem to hurt anything, just don't make a habbit out of it.
FNR32 is offline   Reply With Quote
Old 05-07-2005, 09:05 PM   #4
Bort
Member#: 27075
09 WRX, 03 WRX,
98 OBS
Originally Posted by ScoobaruRS
-Brett
at the
Yeah, welcome to the rev limiter.
Bort is offline   Reply With Quote
Old 05-07-2005, 09:05 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....hit the rev-limiter.....no problem.....that's why it's there
...just don't downshift and over-rev...the rev-limiter won't help ya there
Old 05-07-2005, 09:08 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yep the "skipping" you felt was the rev limiter doing its job. It's there just for this purpose, to prevent you from over-reving the engine and doing damage. So you didn't break anything.
You can, however, over-rev on a misplaced downshift. The ECU can't do anything about that because it's a mechanical condition, so if you go from 5th to 4th and get 2nd by mistake you can break things.
edit- Scotty said it in fewer words while I was still typing-
Old 05-07-2005, 09:27 PM   #7
Miggidy
Member#: 71343
2000 Impreza WRX GC8
I thought the rev limiter still worked if you double-clutch downshift. Or does it simply work in shifting up the gears?
Miggidy is offline   Reply With Quote
Old 05-07-2005, 09:31 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The rev limiter works by cutting fuel if you accelerate beyond the permissible RPM. It can't do anything if you downshift into the wrong (too low) gear in which case the drivetrain will be pulling the engine and forcing it to spin at a speed determined by the gear ratios. If this happens you can turn the key off and it will still be over-reving, so the ECU has no say in the matter. The only thing that may save you here is to step on the clutch immediately.
Old 05-07-2005, 09:38 PM   #9
dingo dave
Member#: 33177
white
Thanks for the quick responses. I was a littel concerned but feel better now. Now i can focus my attention on the Mavs hopefull victory tonight and the tivo'ed coralles-castillo fight afterwards. Good night to be a b-ball, fight fan.
Old 05-07-2005, 09:39 PM   #10
sam caldwell
Member#: 85020
02 wrx
blue/orange a must c
yep thats the o'l rev limiter........ thats when i shift.... i dont get out of 4th very often lol
sam caldwell is offline   Reply With Quote
Old 05-07-2005, 09:54 PM   #11
allsubaru83
Member#: 60122
1986 911 Turbo
Guards Red
nothing is wrong with you car, i have done that a couple of times my self, and nothing is wrong with mine. i t is all in a part of haveing a stick, sometimes it happens.
allsubaru83 is offline   Reply With Quote
Old 05-07-2005, 10:06 PM   #12
Miggidy
Member#: 71343
i'm with you, that makes more sense.
Cheers
20mph in 2nd gear at 6k rpm Feign Transmission (AT/MT) & Driveline 6 04-16-2006 03:22 AM
Grinding in 2nd gear, 4th gear, and reverse Blizwinter Transmission (AT/MT) & Driveline 5 06-08-2004 04:12 PM
hesitation during start up and in 2nd gear x12oyx316x Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-17-2004 08:21 PM
80MPH in 2nd Gear in an Auto Mk750 Transmission (AT/MT) & Driveline 5 02-17-2002 11:42 AM
2.5 RS 7000 rpm redline in australia! xfrickx Normally Aspirated Powertrain 19 10-25-2001 01:21 AM
