Old 05-08-2005, 07:16 AM   #1
old_duwel
Top Scoob 015
Member#: 18175
99 STI RA Ltd #450
WRB blue
Default GDB STI 2.0lt motors?
My rod bearing in my engine turned. I check the oil and found metal shaving in it. now i am wondering if the JDM STI ver. 7 2.0lt motor we fit onto a Ver. 3 wiring harness. I had it in mind that i could change the sensors on the ver. 7 to ver. 3. does anyone know that this can be done? I heard rumors that the ver. 7 has variable valve timing. is this true? i just don't want to get another Power FC.
old_duwel is offline   Reply With Quote
Old 05-08-2005, 04:14 PM   #2
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
yeah, your best bet would probably be to just get a shortblock. most should bolt up, you could probably even do the ej257 block, or the ej22, or just find another 2 liter block
Hurley 2.5 WRS is offline   Reply With Quote
Old 05-08-2005, 06:48 PM   #3
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Without some serious modification the harness will NOT work and the power FC will not be able to control the AVCS. If the ver 3 manifold will mount up to the ver 7 motor you will have a better chance of getting it to work. I did the swap prior to my current build and modding the harness and getting the power FC to work properly were a true pain.
DuoMaxwell is offline   Reply With Quote
Old 05-09-2005, 08:34 AM   #4
old_duwel
Top Scoob 015
Member#: 18175
99 STI RA Ltd #450
WRB blue
so i have to use my ver 3 manifold is there some way that i could take the AVCS out or off the engine to use the Ver. 7? by the way, i am not very techincal but what is a AVCS? i never really worked with them. could it be "Advance Valve Cam System"? if that is the case then why would i need to use my Ver 3 manifold instead of the Ver. 7?
Old 05-09-2005, 09:01 AM   #5
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
V3 intake will not fit on V7 heads. Best bet is to replace just the block only.
Ver.III is offline   Reply With Quote
Old 05-09-2005, 04:01 PM   #6
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
I replaced my ver. III shortblock w/an EJ257.
I just swapped over my heads and intake manifold. I'm running a Power FC as well.
PM me if you want oid_duwel.
-mykr.
mykrrrr is offline   Reply With Quote
Old 05-09-2005, 06:31 PM   #7
old_duwel
Top Scoob 015
Member#: 18175
99 STI RA Ltd #450
WRB blue
-mykr.
well i won't beable to find a EJ25 block around here. japan didn't really come out with a 2.5 STI motor. I know that the EJ20K heads will not fit on the EJ20G block. I could find EJ20G and EJ207 motors everywhere but could not find a EJ20K. so i am trying to figure out if i could make the EJ207 work. i am sure that i could pull out the AVCS. can i use the EJ20K heads on a Ej207 block?
mykr i'll PM later i got to get to work!
Old 05-09-2005, 09:08 PM   #8
mykrrrr
Member#: 733
'16 Fiesta ST
You should be able to fit the K heads on the EJ207.
-mykr.
Old 05-10-2005, 07:29 AM   #9
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Yea if the heads fit then your in business. As far as AVCS is concerned yea its cam timing so to speak, but if you use the block only you will be in business.
Old 05-10-2005, 08:02 AM   #10
old_duwel
Top Scoob 015
Member#: 18175
99 STI RA Ltd #450
WRB blue
got it, but one thing does someone have a picture of the EJ207 engine without the heads? if someone does that would help me alot, i could compare the pictures that i have for the EJ20k to the EJ207.
whats better v5 sti 2.0 motor or 04 sti 2.5 sti motor? drift king Pre-2002 Factory Turbo Powertrain 19 08-07-2007 07:19 PM
STI 2.0Lt with T-67 25G from Greece Findas Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 01-05-2005 02:00 AM
Built JDM STI 2.0 motor wRxbeater11 Private 'For Sale' Classifieds 16 06-19-2004 12:02 AM
Tri state deal - STI 2.0 motor installed alfriedesq Tri-State Area Forum 5 02-05-2003 01:12 PM
'04 STI 2.5 motor problems??? alfriedesq STi Forum Archive 5 01-19-2003 02:18 AM
