Old 05-08-2005, 12:30 PM   #1
BIGSKYWRX
Member#: 7958
09 GH B+
Default ECU reset-> 16 IAM = "aggressive" knock correction
I did a log w/ a oe ecu (3rd gear pull ~1800-redline) and found the IAM to stay right at 16, knock correction started in the 5ish range-> 9ish range @ ~3000 rpms-> to a high of a 10.5 @~ 4800 rpms -this is on a ECU that had not been reset in a couple of months.
I then put in my reflashed ECU (Ecutek), I advanced the IAM to 16 in matter of seconds (Shiv's "trick") and then immediately did another 3rd gear pull- the knock correction quickly advanced to 10 by ~ 2700 rpms, then dropped and hovered between 5 and 3 throughout the rest of the pull. The IAM stayed at 16 until ~ 3100 rpms and then started dropping- reaching a low of 6 @ ~3600 rpms and gaining one back to 7 @ ~ 4200.
Could this be a function of "fine learning"? Is knock correction more aggressive immediately following a reset?
If (I will ) repeat this in a couple of weeks of driving- is it possible (likely?) to see different results ie IAM remaing the same, knock correction "less aggressive"?
<----- knows suspensions pretty well, has long way to go w/ EM
Danka
Old 05-08-2005, 11:08 PM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....try the same thing with 100 octane in the tank and see what happens
Old 05-08-2005, 11:17 PM   #3
BIGSKYWRX
Member#: 7958
09 GH B+
I hear you, would be better even w/ 93
I have read a couple of threads that hint at the knock correction being a little "agressive" w/ a clean slate- I guess I'll find out.
Old 05-08-2005, 11:20 PM   #4
thesmokingman
Member#: 17751
2002 WRX Wagon
944 Turbo track
Sounds plausible, especially given the OEM safey concerns.
thesmokingman is offline   Reply With Quote
Old 05-09-2005, 02:29 AM   #5
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
....what I meant was that you could 'see' the difference and that would make it all the clearer to you.....
Old 05-09-2005, 08:38 AM   #6
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
When my got my ECU reflashed my tuner put my IAM at 16 as the base number. It learned very quickly, and agressively.
mbiker97 is offline   Reply With Quote
Old 05-09-2005, 09:28 AM   #7
BIGSKYWRX
Member#: 7958
09 GH B+
Here's a quote from Vaus in another thread "I've noticed that immediately after a reset, the ECU is "eager" to adjust the IAM based on any knock sensor feedback within the specified learning range. After driving the car for a while, however, the IAM becomes more or less static unless a lot of knock is detected. Once the IAM has settled, the fine ignition learning can adjust a good deal without effecting the IAM"
My thought is if true, then a map that has a "little time under it's belt" might easier to deal w/ ?
Scotty- I'm running crappy 91 pump gas- the best we are "blessed" w/- I would guess that w/ higher octane I would see less knock correction (w/ a corresponding less likelyhood of seeing a drop in IAM).
Old 05-10-2005, 09:41 AM   #8
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
With higher octane, I'd expect you to see HIGHER "knock correction" (more timing).
jblaine is offline   Reply With Quote
Old 05-10-2005, 09:45 AM   #9
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I don't know what Ed was basing this on, but it's pretty empty without data. IAM becomes more or less static-SEEMING because it has settled, IMO. Go fill up on 87 octane, without an ECU reset, and you'll see how quickly IAM drops.
Old 05-10-2005, 09:56 AM   #10
BIGSKYWRX
Member#: 7958
09 GH B+
Correct- I mistated- meant a lower drop in correction.
If there is no difference in a ecu that is freshly reset and one that isn't- curious why deltadash "warns" you that you will lose all fine learning, etc.
What role does all of the fine learning play in the scheme of things?
Big Sky
Old 05-10-2005, 10:05 AM   #11
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
It's nothing different than (in concept) long-term fuel trim.
Who knows why DD "warns" you. Just a notice that your car might run like ass for a few days and not to panic, I'd guess.
Old 05-10-2005, 10:12 AM   #12
BIGSKYWRX
Member#: 7958
09 GH B+
The car does run better then (everything being equal- octane etc) after it has some "learning" under it's belt?
Is it possible knock correction is "learning" more eagerly w/ a reset vs a month w/o a reset?
Thanks
Old 05-10-2005, 10:12 AM   #13
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
If you want more details, read these http://forums.nasioc.com/forums/show...3&page=1&pp=25
That's about the best info some of us were able to gather.
Old 05-10-2005, 10:18 AM   #14
BIGSKYWRX
Member#: 7958
09 GH B+
Danka
How come I Can't see feedback knock correction, fine learning knock correction? AraSh Open Source Reflashes 13 05-12-2013 11:06 PM
negative knock correction but IAM @ 1 ? foresterated AccessPort 5 10-17-2008 11:37 AM
Correlations between Knock Lite and negative knock correction xFactor Engine Management & Tuning 1 01-12-2006 07:36 PM
RS ECU wow - Knock Correction Hitokiri Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-08-2005 03:23 PM
IAM = 16, Knock Correction learning turns off. jblaine Engine Management & Tuning 41 09-12-2004 10:49 AM
Message Board Statistics All times are GMT -4. The time now is 02:46 AM.
