Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 05-08-2005, 03:35 PM   #1
crazysti05
Member#: 82527
2005 STI/TRY2SEE 700
aspen white
Default Hydra Vs Utec
Okay Guys I Want To Installed A Gt35 R Kit And I Am Runing Ecuteck Right Now On My Car And If I Go The 35r Route I Will Need A Different Managment System Like utec Well I Just Want To Know If Should I Buy UTEC Or Save More And Buy Hydra From Element I Really Need Help I Don't Want To Buy Utec And Them Find Out Hydra Is Better or i could always run utec and ecuteck
crazysti05 is offline   Reply With Quote
Old 05-08-2005, 05:51 PM   #2
zaxrex
Member#: 9898
Water Injected Blue
My first thought is do you want OBD-II scanning, or are you going to switch out the Hydra for inspections? How many parameters do you want total control over, and what is the upgrade path after the turbo kit?
zaxrex is offline   Reply With Quote
Old 05-08-2005, 06:32 PM   #3
crazysti05
Member#: 82527
aspen white
first i don't mind take off obd-2 scaning and switch of to hydra i just want something that i don't have to replace later and save my self from switching over and over my plans are have a 2.6 sti putting at least 600whp right now im putting down 400 whp with ecuteck
Old 05-08-2005, 10:24 PM   #4
erggy
Member#: 51202
personal opinion is to go for the Hydra, with my limited knowledge on UTEC i'm not sure how efficient they are in controlling large injectors and cams.
anyone? please share
erggy is offline   Reply With Quote
Old 05-09-2005, 11:08 AM   #5
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
from what I know, Ultimate Racing uses ECutek even with their GT35r kits on the STi... Not sure where you got the info about not being able to use it with that kind of kit from......Unless the one you have does away with the MAF for some reason?
jigga is offline   Reply With Quote
Old 05-09-2005, 12:05 PM   #6
offset
Member#: 32636
2004 Impreza STi
Silver/Silver
I think with 600whp you will start bumping against MAF overload. The best way around that is go MAP based with the Hydra. This is all based on my limited knowledge of tuning though, so I may be a little off here.
offset
offset is offline   Reply With Quote
Old 05-10-2005, 02:10 AM   #7
bboy
Member#: 56468
04 Improved STI
Dirty White
offset
You are away above the stock MAF, and probably above the Perrin BIG MAF. I just don't see a 600 whp car without using speed density tuning, in which case, the Hydra is your only current option that won't break the bank.
If your willing to spend the extra money are the Hydra, it will be well worth it. It's not that I feel the UTEC is bad, it's just that the Hydra has many more tuning features and a much more pleasant user interface. Tuning with the UTEC would seem like working in MS-DOS, which you are probably to young to remember.
Phil has tons written up on the Hydra on his web site at www.ElementTuning.com more than you'll ever see about tuning with UTEC. PDX Tuning www.pdxtuning.com has Powerpoint presentation on UTEC that goes through what's available with that system.
I bit*h about Andrew, but I like my Hydra, I'm spoiled by it, and don't think you can do better than Phil for tuning and assistance.
Old 05-10-2005, 11:13 PM   #8
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
Can you not edit the MAF calibration within Ecutek? I saw stick with Ecutek and get a bigger MAF. There are several options I am sure.
Hitokiri is offline   Reply With Quote
Old 05-11-2005, 11:53 AM   #9
manman99
Member#: 51343
Hi Guys,
does anyone has any details info on the features of hydra compare
to utec?
or any where I can find above?
Thks
manman99 is offline   Reply With Quote
Old 05-15-2005, 01:48 PM   #10
erggy
Member#: 51202
i haven't seen any vs. comparison...
u can find info on the hydra at www.elementtuning.com or www.hydraems.com
AP vs. UTEC vs. Hydra subaragnarok Newbies & FAQs 16 07-17-2009 04:00 PM
Hydra vs. Autronic vs. Tech III for SVX EG33 TomsSVX5mt Other Engine Management 1 07-07-2008 01:53 PM
hydra vs.. utec (anyone) reviews-please MIDNIGHTROCKET Other Engine Management 13 05-02-2007 10:57 PM
Poll: STi Hydra vs STi UTEC SupraScooby Engine Management & Tuning 8 08-11-2004 06:01 AM
98 RS guys! - Link vs Utec vs Exede vs flash buraddo Engine Management & Tuning 4 02-23-2003 01:59 PM
