05-08-2005, 11:13 PM | #1 |
Member#: 64243
04 Fog Light Issue
I don't know why I keep having this problem with my fog lights. About every other week I have to change the bulbs in my fog lights, the left or the right bulb will blow never both of them just one at a time. I'll change one and the a day or two later the other will blow. Don't understand why its doing it and wondering if anyone has seen this problem before. I use factory spec bulbs everytime and I install them properly, ie not touch the bulb and seal the light properly. Any suggestions would be great also wondering if anyone knows if the warranty will take care of this problem.
05-08-2005, 11:31 PM | #2 |
Member#: 58477
Vehicle:. Member #1 of the witty MS Crew |
have you done any mods to your car? any new electronics or electrical mods?
05-08-2005, 11:36 PM | #3 |
Member#: 64243
AP stage 2 and HKS turbo Timer, I don't think they are the problem, not sure why they would cause a problem with the bulbs blowing but u do never know. I also have a set of springs not sure if the bulbs are blowing ie when I hit a pothole? Not sure whats going on, it just happens alot and is a pain.
05-10-2005, 12:37 PM | #4 |
Member#: 44168
SCIC
Vehicle:2017 Silver Forester with not enough lights... |
Wow, never heard of this one before...
Do you have your headlamps/foglamps turned on when you're starting the car? |
05-10-2005, 02:23 PM | #5 |
Member#: 8023
Vehicle:2019 Crosstrek white |
Other than corrosion at the fog light connectors (not likly in a new car) I would suspect a fault in the fog light switch or relay. The relay is located in the relay bank directly to the right of the passenger compartment fuses.
05-10-2005, 05:42 PM | #6 | |
Member#: 64243
05-11-2005, 08:55 PM | #7 |
Member#: 50699
TXIC
Vehicle:2004 WRX Platinum Silver |
no, starting the car with the lights on give them only aout 10 volts and drastically reduces the life of the bulbs. just turn off you lights and see if that changes anything.
p.s. there is no reason to be a smart a$$ when someone is just trying to help. <mumbles> Joe |
05-11-2005, 11:34 PM | #8 | |
Member#: 64243
05-12-2005, 09:31 PM | #9 |
Member#: 64243
So now my freakin Driver Side headlight is blown too. Im def goin to the dealer now, Anybody know how to test if a relay is good or not?
05-12-2005, 11:44 PM | #10 | |
Member#: 50699
TXIC
If you still want some type of drls, then hook up your fog lights to the parking lights and just turn those on when ever you drive. let em know if you need a link. i think there is still one on compact car magazine online somewhere. good luck either way. if still do take it over to the dealer, have them check the alternator. if it is putting out to much voltage the same symptoms would occure as this causes the bulbs to burn hotter which causes the filament turn "fall apart" quicker. this is also what happens when you start the car with the lights on, but instead its more like turning the bulb on and off several times a second. Joe |
05-13-2005, 05:09 PM | #11 |
Member#: 64243
If you have the link to undo the drls and how to hook the fog lights up let me know i think i will give that a try, but first i am gonna take it to the dealer to have a look at things before the warranty runs out
Thanks Rich |
05-13-2005, 11:56 PM | #12 |
Member#: 50699
TXIC
drls are a blue plug on the right side behind the glovebox. gonna haave to look for the other one on the fog lights. remind me tomorrow
Joe |
05-14-2005, 01:32 AM | #13 |
Member#: 41561
Vehicle:04 GT3076 2.1 Stroker = Broken 3rd |
I had the same problem, and the problem was that i kept replacing it with a 100 watt h3 instead of a 55 watt h3. make sure your replacing it with the 55watt. the 55watt h3 doesnt have a nipple.
fog light issue | rallyracersti | Electrical & Lighting | 1 | 08-13-2008 10:24 PM |
Fog light issue, 02 wrx. | gimmewar | Electrical & Lighting | 3 | 10-25-2007 05:00 PM |
Fog light issues | brooklyngenius | Legacy Forum | 2 | 08-16-2005 11:27 AM |
WTT: 04 Fog lights for 04+ PSM sti fog covers | 04 Rex in DE | Private 'Wanted' Classifieds | 0 | 09-10-2004 05:30 PM |
fog light issues | scottsubarus | Interior & Exterior Modification | 2 | 09-06-2001 09:11 PM |
