Old 05-09-2005, 12:32 PM   #1
scoobbee
Member#: 36247
2008 STI
SSM
Question Instructions for taking timing belt cover off to inpect the timing belt?
Sup?
Well my WRX almost has 30K miles and called the dealership for 30K mile maintenance price quote. $580 Can you believe that? Anyway I always change the oil and oil filter every 3K and inspect most of the fluids and belts everytime I do. So will not need that service. Just got an STI drop-in air filter so don't need that either. Also, had the clutch and transmission replaced at 18K so no need to inspect or replace the tranny or clutch. Going to replace the stock plugs with NGK PFR6G's .. so will not need that service.
Good news is I found a dealer that will do all the services but those for about 1/4 of the price. (Replacing brake fluid, cooant, fuel filter, etc...)
Want to check the Camshaft Drive Belt (Timing Belt) myself....would rather do all I can without someone else messing with things and not putting them back right ... if you know what I mean. Instructions? Pictures?
Thanks!
scoobbee is offline   Reply With Quote
Old 05-09-2005, 12:41 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Remove AC/alternator belts, remove crank pulley, remove covers. Pretty easy to do.
Brian
Old 05-09-2005, 03:00 PM   #3
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
AndyH is offline   Reply With Quote
Old 05-09-2005, 06:33 PM   #4
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Your timing belt is not required to be replaced until 105,000 miles. Taking the timing cover off and checking it will do no good. If, for some reason it does break, (very unlikely), it is covered under your powertrain warranty until 60,000 miles. Taking the timing cover off to inspect it will not show you anything and if you don't know what you are doing and put something back wrong, then you could risk causing damage or getting something caught in there. (don't ask, seen it happen). The covers are sealed, so unless you got a defective belt when the vehicle was built,(or your car has been in a frontal collision) you should be okay until 105,000 or longer.
RexyGirl is offline   Reply With Quote
Do you have to remove the timing belt to change water pump? elsuicida Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-27-2009 03:24 AM
Instructions for taking off drivers side door panel? Torch Interior & Exterior Modification 3 08-16-2005 12:50 PM
WTB: SOHC passenger side front timing belt cover off any EJ motor DeusExMachina New England Impreza Club Forum -- NESIC 6 08-29-2004 08:29 AM
When to change the timing belt? Songlady New England Impreza Club Forum -- NESIC 4 07-22-2002 06:40 AM
Who held up the instructions for a vishnu stage 0 kit to me at the light ? Maxtastic Bay Area Impreza Club Forum -- BAIC 4 07-02-2002 02:55 PM
