Old 05-10-2005, 02:34 AM   #1
KILLARMY
Member#: 82326
Default Reflash for version 4
I'd like to get my jdm version 4 type-ra ecu flashed but i'd like to know what's the best reflash I could do because I think Ecutek cant do it for version 1 to 4...
Thank you for your help!
KILLARMY is offline   Reply With Quote
Old 05-10-2005, 11:24 AM   #2
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Good luck. Report back if you find someone because I have not heard of anyone who does V3 and V4.
What are you trying to accomplish? Lower octane? Speed limiter elimination?
I have heard there is a work around for the speed limiter on the UK boards.
linsavy is offline   Reply With Quote
Old 05-10-2005, 11:53 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
nope no ecutek for ver.4 only ver 5 and later
if it was me i would look at an autronic or link plug-n-play
in hind site i wish i had done the autronic instead of the tec -of course i would have blown several turbos running ALS by now
Old 05-10-2005, 09:03 PM   #4
revel
Member#: 62628
MY99 Ver6 Type R
aspen white
not to hijack thius thread......but.......
if i have a Ver6 RS with a Ver6 STi RA complete conversion (engine/working DCCD tranny/ecu/rear drivetrain) is it possible to get an EcuTek reflash?
if so where? anyone that does EcuTek reflashes ? or would i need to send my ECU to someplace in UK/Japan for a reflash of the JDM ECU?
sorry, the conversion is on the way and i am trying to figure out what i can do to get the engine to run HAPPILY on 93 octane.
thanks. sorry again for hijacking.
revel is offline   Reply With Quote
Old 05-10-2005, 09:26 PM   #5
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
i'll sell you my link plus but you'd have to wire it in
scubydrew is offline   Reply With Quote
Old 05-10-2005, 09:35 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yes but you have to find a ecutek dealer with flash99 vs flash2002
email ecutek
www.ecutek.co.uk
Old 05-10-2005, 10:01 PM   #7
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
the 1998 and older subarus were not reflashable..
you might be able to send it out and get work done to it, but i dont thin a OBD flash will work on it...
YaZahX is offline   Reply With Quote
Old 05-10-2005, 11:46 PM   #8
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Why not wire in a 02/03 WRX ECU? ECUtek, UTEC, way more options.
jamesfacts is offline   Reply With Quote
Old 05-10-2005, 11:59 PM   #9
revel
Member#: 62628
MY99 Ver6 Type R
aspen white
wont allow use of DCCD. maybe something else, but i know it wont work DCCD.
looks like i will be sending the STi RA ECU to the UK.
Old 05-11-2005, 02:06 AM   #10
KILLARMY
Member#: 82326
hey scubydrew you have a link plus for sale??
how much for this? and does it fit on my version 4 type-ra??
And before could you give me more info on the link plus because it interests me!!
Thank you
Jonathan
Old 05-11-2005, 02:10 AM   #11
KILLARMY
Member#: 82326
I'd only like to get better engine mapping and remove the FU****G speed limiter, if there's another way to remove it, could you tell me how please?
Thank you all for your help!!
Jonathan
Old 05-11-2005, 05:07 AM   #12
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
Apexi Power FC & PossumLink are the two standalone EMS set ups for the phase 1.5 motors (ver. III/IV STi)
I got a Power FC and have NO regrets on it.
There is no way to remove the OEM speed limiter unless you do a signal conversion which they sell in the UK for 110 GBP (~200+ USD) or get a Apexi PFC or PossumLink.
If you have any questions on the PFC, feel free to ask. It's a very comprehensive EMS set up and controls all the stock items.
-mykr.
mykrrrr is offline   Reply With Quote
Old 05-11-2005, 09:35 AM   #13
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Yoshi can re-flash your stock V4 ECU. Just have to take a trip, or send your ECU to his place in Canada.
http://www.japanese-auto.com
omahasubaru is offline   Reply With Quote
Old 05-11-2005, 09:52 AM   #14
linsavy
Member#: 11620
Thanks Omaha that's is good to know.
Mykr - what benefits did you get from the Power FC? More power? Supporting different turbo/injectors/exhaust? What are the advantages over the stock ECU?
Old 05-11-2005, 01:28 PM   #15
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
power FC is fully programable
Old 05-11-2005, 03:20 PM   #16
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
myrkrr, ive ben looking at the power fc for a version 4, i just need to know where to get one, and ill have to keep you in mind.
Hurley 2.5 WRS is offline   Reply With Quote
Old 05-11-2005, 04:37 PM   #17
Tizzle
Member#: 44472
Ver2 Legacy StiRA
88 RX, 87 RX, 07 FXT
Is link plus at all model/year specific?
Tizzle is offline   Reply With Quote
Old 05-11-2005, 04:58 PM   #18
dmross
Member#: 2818
2000 2.5RS
Apexi PFC is the way to go, trust me. It is fully programmable and works very very well. It plugs right in replacing you ECU. It has 20x20 fuel and ign maps, plus a ton more. There is a third party laptop interface. I run one with my Version 6 RA motor and a TD05H-20G. There are quite a few 10 and 11 second Subarus in the UK running them. You can get 93-00 PowerFC's from Andy Forrest in the UK. http://andyforrestperformance.co.uk/16253.html
revel - Your DCCD doesn't use the ECU, it uses the DCCD controller. I have the exact same setup as you do. You can use a different ECU, you don't need a Subaru ECU. Sending an ECU to the UK for a reflash just isn't worth it. Also, Ben from Lachute in Canada has Flash99 and can reflash the older ECU if decide to reflash it anyway. Let me know if you need a spare, I have an AF041 (STI 6 RA) sitting in a box collecting dust.
As for the speed limiter - you can get them from Graham Goode in the UK. It's just a converter that you wire into the speed signal from the tranny. Actually, since I am running a PowerFC now, I can get probably get rid of mine... PM me if interested (but beware, I will try to convince you that the PFC is your best bet!)
dmross is offline   Reply With Quote
Old 05-11-2005, 09:49 PM   #19
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
high quality post
Old 05-11-2005, 11:36 PM   #20
revel
Member#: 62628
MY99 Ver6 Type R
aspen white
dmross- thanks for the info! really good to know i can simply change out the ECU and have it tuned with the car.
how long have you been running the Apexi PFC in your RA?
anyone know anything about MINE'S ECUs? might be able to get a hold of one and was just curious as i know very little about the MINE'S ECUs.
Old 05-11-2005, 11:56 PM   #21
dmross
Member#: 2818
2000 2.5RS
I have been running the PFC since I upgraded to the FMIC/20G/740 injectors/etc, about a year now. I was using the stock ECU with an STI 8 topmount and turboback exhaust with the stock VF29. I was initially going to just get a reflash, but I decided to go big and I did a ton of research on the different options. The PowerFC was the most practical. I can retune it for any changes to my setup. I use an AVC-R for boost control; It's a great combination. I really wish they would make the PowerFC for the new-age WRX/STI. They are still available for the Mitsubishi EVO and a few other newer cars right now.
I have found some of the best info covering the Version 5/6 STI's on the UK bulletin boards, especially http://bbs.22b.com and http://bbs.scoobynet.co.uk The search on 22b.com is really slow so you may want to limit it to the tech forums, but there is a wealth of really good information 2.0 WRX/STI motors and other similar Subarus that were available there long before Subaru offered a turbocharged Impreza in the US. The Brits and Scots have been modifying them for quite some time and a lot of different setups & projects are well documented, it just takes a little while to get used to their sense of humor.
I don't know much about the MINES ECU, but I assume it is an off-the-shelf customized ECU that is meant to be used with a particular combination of parts.
Old 05-12-2005, 12:04 AM   #22
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
in the most recent impreza magazine #26 they show a pfc for the new age
unless you speak japaneese adjusting the mines (if its adjustable) will be tough .. i think its just a reflashed ecu -not really good to you
Old 05-12-2005, 12:12 AM   #23
revel
Member#: 62628
MY99 Ver6 Type R
aspen white
thanks for the sites. have now registered under "revel".
i am fairly used to old british humor. grew up watching monty python and the flying circus along with the movies.
tis only a flesh wound. still one of my favorite skits.....along with the ministry of silly walks.
recently found out Mr Bean (rowan atkinson) is actually a professional racer and a comic. or was a professional racer then a comic.....cant remember now. just thought i would share.
Old 05-12-2005, 12:53 AM   #24
silentbob343
Member#: 57307
he also crashed a mclaren, but bought another
silentbob343 is offline   Reply With Quote
Old 05-13-2005, 04:04 PM   #25
revel
Member#: 62628
MY99 Ver6 Type R
aspen white
that bean is crazy. i am guessing he totaled it?
EJ20k STi Version 3 Version 4 V3 V 4 ECU roboace Private 'Wanted' Classifieds 2 02-14-2008 06:39 PM
WTB: GC JUN Style Lip for version 4 bumper kingsubi Private 'Wanted' Classifieds 4 03-29-2006 04:09 PM
Sti version 4.11 box, vs Version 2 RA 3.9 supermoose Transmission (AT/MT) & Driveline 14 08-04-2005 09:20 AM
Sti Version 4.11 Gearset with 4.11 LSD - full drop in conversion to 4.11 short ratio! supermoose Private 'For Sale' Classifieds 11 07-06-2005 02:14 PM
version 4 vs. version 5 Lachlan Subaru Conversions 3 01-03-2005 01:24 PM
