Old 05-10-2005, 02:19 PM   #1
rich728
Member#: 40328
2004 WRX STi
BSP #728
Default stand alone knock sensors
The only one ive found is knocklink. Any others on the market?
for those with a knocklink, how accurate are they?
rich728 is offline   Reply With Quote
Old 05-10-2005, 03:38 PM   #2
pyrex
Member#: 45757
2005 WRX STi
CGM/Silver
MSD makes "Engine Knock Alert" http://www.msdignition.com/tool_8.htm
I just installed a knocklink, although I haven't seen any det yet I think it is pretty sensitive. I can see low level (green light) activity when I really get on it and I'm not even sure that I installed the sensor correctly. I used the bolt that is right next to the stock sensor. There was a bracket already on the bolt so I put the sensor on top of the bracket, using a longer bolt. I don't know if the bracket affects the sensitivity of the sensor or not.
pyrex is offline   Reply With Quote
Old 05-10-2005, 05:47 PM   #3
wgknestrick
Member#: 32576
04 STI
Some company really needs to package this in a 52mm or 60 gauge format. All (well both of them) knock sensors are very crudely mounted and finished off in cheap plastic housings. I dare you to find a place to mount either where they are clearly visable and look like they belong. I would pay dearly for something that was complete, and came in a gauge housing that could be mounted just about anywhere.
Kind of like what AEM did with their UEGO A/F meter. Before them, no one even made something that was packaged so well.
wgknestrick is offline   Reply With Quote
Old 05-10-2005, 06:33 PM   #4
coolcougar
Member#: 19674
2006 Baja Turbo 4EAT
Brilliant Silver Metallic
You mean like this:
coolcougar is offline   Reply With Quote
Old 05-10-2005, 06:43 PM   #5
wgknestrick
Member#: 32576
04 STI
Not quite. While yes that is in a gauge format, knock is not something well represented by an analog dial. Unless it flashes and beeps past a certain level, it is mostly novelty to me.
I want a simple LED linear meter in a gauge that beeps and flashes past a user set point. I don't want to see or hear anything out of that thing unless there is trouble.
Try monitoring that gauge when at WOT. How do you discern between 40 and 60 (what is it in %?) You are in knock trouble for a split second.
Old 05-10-2005, 09:26 PM   #6
rich728
Member#: 40328
2004 WRX STi
BSP #728
Originally Posted by coolcougar
You mean like this:
It says digital but it looks analog. Anyone know how it works?
Old 05-10-2005, 10:01 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
j&s is probbly the best
Old 05-11-2005, 01:52 AM   #8
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
OK
Wombat North is offline   Reply With Quote
Old 05-11-2005, 06:03 AM   #9
rich728
Member#: 40328
2004 WRX STi
BSP #728
now that is a a really slick install. is that knocklink? i hope you made a how to guide
Old 05-11-2005, 10:44 AM   #10
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
How are you guys interfacing an audio mechanism (buzzer) with your knock monitors? I imagine the LED solution would be hard to see in some daylight circumstances. Not to mention while under heavy throttle with both eyes glued to the road…
xcntrk75 is offline   Reply With Quote
Old 05-11-2005, 12:26 PM   #11
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
I've been kicking around the idea of building my own "knock sensor" for a few months. Basically you have a microphone, a filter, and an led bar-graph display. How hard could it be?
fogdor is offline   Reply With Quote
Old 06-26-2005, 08:45 AM   #12
Playsatan
Member#: 89943
1999 STI5 Type R
Mica Black
This is a knocklink that I modified
I'm not any good with wiring so the entire box it tucked into the dash. I just took the cover off, used the holes in it as a template and drilled through to allow the leds to drop through. 30 minute job max.
Keeps it in your line of site as well although I was tempted to do it through the top of the dash and turn it into a HUD.
Playsatan is offline   Reply With Quote
Old 06-26-2005, 05:16 PM   #13
Jon [in CT]
Member#: 2992
02 WRX Sedan
A $50 product called "Knocksense" seems to be popular within the Volvo community. See http://www.viatrack.ca for what skimpy details exist about it.
Jon [in CT] is offline   Reply With Quote
Old 06-27-2005, 02:13 PM   #14
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Good luck making a filter thats accurate.
cdvma is offline   Reply With Quote
Old 06-29-2005, 06:53 PM   #15
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
You mean like this:
where can i buy one of these
Old 06-30-2005, 12:38 PM   #16
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Links to some other detonation monitoring options:
http://www.jandssafeguard.com/
KnockLink
Casper knock sensor
Snap-On Electronic Ear Part Number: YA6500 AKA det cans
Old 07-03-2005, 01:39 AM   #17
bboy
Member#: 56468
04 Improved STI
Dirty White
I've made mine own knock listening device.
$20 Bosch knock sensor (used at a Volvo junk yard, excuse me, salvage yard)
$10 cable with aligator clips and a minijack audio plug from Radio Shack
Plug the microphone (knock sensor) right into the computer.
I filter out all frequencys except 5-10 kHz with equalizer in sound software (I use a Mac specific program Final Vinyl but I've used other effectively--30 band equalizer, but it's overkill). Sound is processed and played through on the computer speakers or via head phones. Det sounds are very distinct as everyone knows.
It's just for tuning, but it works as well as TXS Tuner.
Old 07-03-2005, 01:46 AM   #18
SleepinRex
Member#: 12449
thanks for the link unabomber. Anyone happen to know any good vendors selling knocklinks. Found a coupel that were out of business or overseas.
SleepinRex is offline   Reply With Quote
Old 07-04-2005, 12:57 PM   #19
Tgui
Member#: 44771
Sort of on topic... where the heck are you people mounting your knock sensors? I tore my intercooler off looking for some great place to mount mine, but no luck.
Tgui is offline   Reply With Quote
Old 07-26-2005, 01:22 AM   #20
InfamousDX
Member#: 25413
Same here... back when I DID use my tuner pro's knock sensor I couldn't find a place to mount it. I wanna start using it again but I still have no idea where to put it.
Old 07-26-2005, 04:19 AM   #21
WolfPlayer
Member#: 65054
2005 STI (CGM)
Descooped / Dewinged
Info on which specific knock sensor along with how you wired it up would be awesome. Great idea. A++ in my book.
t
WolfPlayer is offline   Reply With Quote
Old 08-13-2005, 02:34 PM   #22
singletrack
Member#: 42440
04 Impreza WRX STi
Platinum Silver
I just wanted to revive this thread to show the location of the knock sensor I installed on my STi. This is the bosch sensor commonly sold with the knocklink. It's installed at the same angle as the stock sensor which is not visible in the pictures; I'm not sure if it makes a difference really.
In order to get the bracket to fit on top of the sensor, you can insert a 1/4" extension into the hole in the bracket and bend it slightly. I can't recall the length, thread, etc of the bolt, but I just pulled the stock one, drove to the parts store, and came back with one that was longer.
A quick tip - when replacing the intercooler (assuming you have a TM) use a touch of soap on the outside of the compressor outlet to make sure the rubber boot slides on easy : )
singletrack is offline   Reply With Quote
Old 08-13-2005, 07:20 PM   #23
coolcougar
Member#: 19674
Default Another possibility?
There appears that there may be another option for a possible stand alone knock sensor... I'm not 100% that this is stand alone though...
http://forums.nasioc.com/forums/show...php?p=10718893
Old 03-09-2007, 02:41 PM   #24
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i though i would bump this as its linked in the ecu faq and add an important thing is not mentioned
most knock "lights" will only display the knock, the JandS will actually retard advance up to 20 deg /cyl when it senses knock ..
this is very useful when tuning with an ecu that has insufficient knock sensing/retard like a powerfc or autronic
Old 03-09-2007, 08:58 PM   #25
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
so whats the best one for the money? where can I purcahse them ?
IllNastyImpreza is offline   Reply With Quote
Link G4 Xtreme PnP Stand Alone ECU 06-07 Sti akeric Engine/Power/Exhaust 6 06-05-2010 05:00 PM
2nd Knock Sensor Location, 2nd Knock Sensor Locatoin! SentinelSison UTEC 3 05-24-2006 10:06 PM
Stand alone scan tools LVSUBARU Normally Aspirated with bolt-on Forced Induction Powertrain 12 02-15-2002 10:31 PM
For those looking for stand alone engine management... DanMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 02-02-2002 02:30 AM
Unichip offered as a stand alone unit? Diz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-30-2001 11:12 AM
