Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 05-10-2005, 03:29 PM   #1
bryan_johnson
Member#: 78987
Default Ok to Move Air/Fuel Sensor Further Downstream?
Hello All,
I'm doing a vanagon/subaru conversion with a 2003 WRX engine and I'd like to move my front air/fuel sensor further downstream into the uppipe for clearance reasons. Does anyone have any experience with a change like that? Do you think the exhaust temp will drop too much and effect my readings if the sensor is 8 inches or so further downstream?
Thanks for any ideas,
Bryan
2003 USDM ej20t
stock headers
stock ecu
catless uppipe
bryan_johnson is offline   Reply With Quote
Old 05-10-2005, 03:37 PM   #2
Performance Driven
Vendor
Member#: 75855
04 Dynapack
have seen up-pipes with o2 or tuning bungs.
heat wrap wouldn't hurt..
sometimes you do what you have to..
Performance Driven is offline   Reply With Quote
Old 05-10-2005, 04:12 PM   #3
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
iirc, there is a jdm variation that puts the MAIN o2 sensor in the downpipe. someone who knows more than i do about that may pipe in...
moving it a few more inches downstream won't make a difference, imo.
Old 05-10-2005, 04:44 PM   #4
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
the gp-moto 4-2-1 headers move the o2 bung to right before the turbo, where all the exhaust is finally merged. It really doesnt make a big difference where you put it, its for idle control and light-load conditions anyways.
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 05-10-2005, 04:49 PM   #5
MMBOOST
Member#: 24140
02 Impreza WRX
http://www.logmapper.com
Usually professional dyno tunes are done with a sniffer in the tail pipe. I have read about comparison tests of sensors immediately after the turbo, to mid-stream, to tailpipe with little to no difference. Also, I have never read any O2 manufacturer instructions that say anything about sensor placement other than that it must be after the turbo and within a low enough heat range so as to not damage the sensor. I have my WB very close to the stock read sensor. It is incredibly consistent with the stock sensor (within the reasonable use of the stock sensor).
I would give a strong vote for not worrying about placing it down stream.
jason
p.s. You will hear people say that down-stream sensors are skewed because gas continues to burn in the pipe. Tests I've read about show this not to be the case. However, I do suspect there is some truth to it, as it makes a lot of sense. I do not think, however, that this happens during consistent throttle but under on-to-off throttle conditions when you get very rich and often have after-fire.
MMBOOST is offline   Reply With Quote
Old 05-10-2005, 05:42 PM   #6
bryan_johnson
Member#: 78987
Thanks for the knowledge, folks. This will really help me out.
Old 05-10-2005, 06:16 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...as long as it is before any cat(s) and you have no leaks, it should be all good
...and the twin scroll JDM ones have the o2 in the dp 'cuz the exhaust dosen't 'come together' (1&3, 2&4) until the turbo inlet....
Front Oxygen sensor AKA air/fuel sensor swap out Peaty Tribeca Forum 0 02-20-2010 04:36 PM
oxygen sensor vs air/fuel sensor paintbing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-02-2008 01:09 PM
FS: 2005 STi Bank 1 Air/Fuel Sensor O2 Sensor srREXed Engine/Power/Exhaust 0 08-14-2008 07:34 PM
Which sensor/wire to connect to for air/fuel readout on Perfect Power 6? gjslick Engine Management & Tuning 0 10-21-2005 06:31 PM
Moving front air/fuel sensor further downstream bryan_johnson Subaru Conversions 3 05-10-2005 05:39 PM
