Old 05-10-2005, 05:06 PM   #1
V6
Member#: 2703
Y2K GC8
Silver forever
Default Big question for all GC8 with JDM engine swap specialists
Hello all
first I am driving a MY00 2.5 RS with automatic transmission (don't laugh), and I would like to know if I like to get an JDM V7 STI engine and transmission swap (swap from my current auto to a six speed manual, but actually I don't really know how to drive a manual well), is it very complicated / is that worth?
Coz some of my friends has already found the engine and transmission and I would like to know is that better to do the swap?
Or is that better to sell the car as well as the engine and transmission and buy a brand new 05/06 WRX wagon instead?
Thanks
V6 is offline   Reply With Quote
Old 05-10-2005, 05:45 PM   #2
AzNStiImpreza
Member#: 17181
2013 Scion FRS
Whiteout
to be able to use the STi transmission, you need to have the whole rear end as well, including driveshafts and diffs.
be careful with the engine/trannys you see selling online because most of them only come with engine/tranny w/o the rear end. also, the wiring is often inclomplete.
i made a ton of phone calls the last few weeks, so i know.
keep the GC8 and do a swap.
AzNStiImpreza is offline   Reply With Quote
Old 11-30-2006, 06:18 PM   #3
synernut
Member#: 79475
2008 STi
I was wondering if you did your swap?
synernut is offline   Reply With Quote
Old 11-30-2006, 07:38 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Damn! It sucks the PM system goes down...
Old 11-30-2006, 08:07 PM   #5
subenick
Member#: 48968
1999 impreza 2.5RS
You dont necessarily need the R180 rear end. You can use R160 rear ends, either find ones from legacy/forrester turbo's with vlsd's or swap in the 3.9 gears into a wrx 160. But make sure you dont keep an open diff... its not going to be nice with all that power! Many people use the r160 rear without driveshaft problems either... cant remember off hand which one they use.
Going with the 180 means going brembo's all around and that means limited wheel choice and of course more $$$$. I went that route and I like it but i thinking of other options now as the bimbo's are mega expensive to change rotors and pads.
As for the question, mechanically its a very easy swap to do. Wiring is a completely different story. Easiest version 7 swap is done into a 02-03 wrx... 8 wires to add for the AVCS, the rest plugs right in! So if youre electronically inept then I would go that route!
Just a small note, the ej207 is a beautiful piece of engineering, its one of nicest engines ive driven. They are blueprinted from factory and rev much smoother and higher than the USDM wrx or STi engines. Mine doesnt consume a drop of oil between changes. My friends with USDM engines go through about 1/2 a litres.... goes to show the tolerancing!
Good luck
subenick is offline   Reply With Quote
Old 12-03-2006, 02:05 PM   #6
kheff46
Member#: 66739
2002 WRX wagon
my V4 STi consumes nothing as well. it revs past 8k easily and pulls like a freight train! using the R160 currently with zero issues. i just tore a boot om my front pass shaft, but happens to the best of em.
i say swap the GC(surprise!) unless you're diggin the wagon. then go get a wagon(GF) and swap that. GC/GF looks better than WRX imho. and price is the other issue(too high resale for nothing) why i won't buy a WRX. STi is the same. i'd rather go forester since they has the TR WRX drivetrain and room for bikes, etc.
--keith
kheff46 is offline   Reply With Quote
Old 12-03-2006, 09:33 PM   #7
2.5rsTurbo
Member#: 99741
2005 Wrx Sti
CGM
keep the gc8 and swap it, also u need to learn to drive a stick or u might as well buy a luxury auto cus auto and speed dont mix well unless u got a sports shifter like those rally cars, think about going into a turn in an auto, u dont have as much control over the vehicle as if u where downshifting in a stick...learn to drive a stick or dont go fast at all...gl
2.5rsTurbo is offline   Reply With Quote
Complete ECU pinouts for all GC8 JDM EJ20; ej20g, ej20k, ej207 swapstar Subaru Conversions 88 02-07-2016 05:45 PM
Intercooler splitter for GC8 with STi engine/intercooler? garface Subaru Conversions 11 07-16-2009 12:10 PM
Question For all you with the Hks Ssqv jacob80 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 56 11-26-2008 01:56 AM
Question for all engine swapped guys V6 Subaru Conversions 3 05-13-2005 01:22 PM
questions for wrx owners with jdm sti gauges Benjamin Tang Interior & Exterior Modification 7 04-15-2003 01:20 AM
