Old 05-10-2005, 06:26 PM   #1
rabydanimal
Member#: 63126
'00 BMW 540i
Default Simple Oil Change Question
Hi all,
stupid question, I changed my oil today and once I put everything all back together and the oil in I realized that I forgot to put the washer back on the oil plug. Is this going to be a problem or can I just put it back on in another 3,000 miles?
~Jeff
rabydanimal is offline   Reply With Quote
Old 05-10-2005, 06:28 PM   #2
ScoobyBoy
Member#: 6418
you might have a leak.
ScoobyBoy is offline   Reply With Quote
Old 05-10-2005, 07:05 PM   #3
dcwrx2
Member#: 69005
'04 4EAT Wgn
I would say you better drain out the new oil, put back the washer and tighten the drain plug, and pour in new oil (not those "drained" new oil, but new from bottle, unless you are very very sure the container which holding the "drained" new oil is very very clean, but I doubt it because you probably use the same container for old oil before).
Spending <$10 for another 5 qts. of dino oil is way better then running low on oil and put your engine at risk.
dcwrx2 is offline   Reply With Quote
Old 05-10-2005, 07:30 PM   #4
Crawdads
Member#: 30907
SWP GDB-G
just drain the oil into a nice clean container, put on a new crush washer and put the oil back in.
-OR-
get this
Crawdads is offline   Reply With Quote
Old 05-10-2005, 07:35 PM   #5
fliz
Member#: 30342
I would just make sure you have an extra quart in the car and check it every time you fillup the gas tank. And it wouldn't hurt to check the ground under where you park every night for fresh oil.
You'll probably be fine.
fliz is offline   Reply With Quote
Old 05-10-2005, 10:59 PM   #6
Pomorski
Member#: 60313
2011 Impreza WRX STi
Talking
What you do is flip your car upside down, remove the drain plug, put crush washer on, reinstall drain plug and flip car right side up. Guarantee no oil will come out the drain plug!!!
Pomorski is offline   Reply With Quote
Old 05-11-2005, 12:06 AM   #7
03WREX
Member#: 38932
2003 WRX
WRB - Cobb Stg2
I agree... I would just keep an eye on it. You should be able to see if it's dripping or not. If so, then just drain it and put the crush ring on... if it's not, why waste your time. Just make sure to check it every once in a while and you'll be fine. If you're really worried about it then just drain it.
03WREX is offline   Reply With Quote
Old 05-11-2005, 12:08 AM   #8
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
Originally Posted by Crawdads
and be done w/it....
Bishop is offline   Reply With Quote
Old 05-11-2005, 12:12 AM   #9
Backsteer
Member#: 83304
03 WRX Sedan
WR Blue
Or....get a new drain plug and a washer, when the engine is cold yank the old one out, have the new plug ready, and put it in fast. Top off....done.
Backsteer is offline   Reply With Quote
Old 05-11-2005, 12:15 AM   #10
hotrod
Member#: 14141
2002 Impreza WRX
If its not leaking don't worry !
If it ain't broke -- don't fix it
Larry
hotrod is offline   Reply With Quote
Old 05-11-2005, 12:20 AM   #11
WRXskeet
Member#: 69435
2005 Aspen STi,rip02
Bugeye mafia 02 :(
you should be fine, iv done the same thing more than once,
-nate
WRXskeet is offline   Reply With Quote
Simple Oil cooler question? elsuicida Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-07-2010 12:04 AM
Simple oil pan question MS WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-07-2008 06:16 PM
Simple oil change interval doublecheck kmschwem Service & Maintenance 5 04-22-2004 12:01 AM
Simple Oil Change Question: Need confirmation mr_yellow Normally Aspirated Powertrain 3 01-13-2004 04:33 AM
A simple oil change paul42 Service & Maintenance 11 01-14-2002 10:15 PM
