Old 05-10-2005, 11:05 PM   #1
hauvis
Member#: 50262
2000 Protege 90whp
Default Cams and cam sprocket for STI?
I was lurking around on a EVO forum and there are some posts about CAMS and CAM sprockets. This seems to be a good source of power for them.
My question is why the STI or WRX don't need upgraded cams? It must not give power increase I would assume the factory CAMS are not easily improved upon?
hauvis is offline   Reply With Quote
Old 05-10-2005, 11:25 PM   #2
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
They do give gains on Subaru, the problem is they cost twice as much as the EVO since there are 4 cams instead of 2, and they are much harder to change. To put it simply, the easiest way to change the cams on a STI is pull the engine out. As for adjustable cam sprockets, the STI uses its own electronic cam timing advance system, AVCS. (Active valve control system) So you can't use cam gears on it. The EVO guys are going to run into the same thing with the EVO IX which uses the MIVEC system.
The EVO also uses hydraulic valve lash adjusters. If you change cams on the STI it requires re-measuring the valve lash for each valve and possibly ordering new buckets. So even if you wanted to do it in a day, you may not be able to.
Old 05-11-2005, 07:05 PM   #3
hauvis
Member#: 50262
2000 Protege 90whp
Default coo
Thanks.
Old 05-11-2005, 10:43 PM   #4
02Toyowrx
Member#: 56520
http://store.dprracing.com/cams/subaru/dprbillet.htm
DPR makes cams for the STI, pretty reasonable I would say.
02Toyowrx is offline   Reply With Quote
F/S Sti oem cams and cam gears silversurfer99 Engine/Power/Exhaust 9 12-13-2008 11:01 PM
WTT:Aspen white wrx trunk for sti trunk, and rs hood for sti or wrx hood Magnum TXIC Private Classifieds 15 07-04-2006 03:35 PM
Cams and Cam Gears Swap? snowcrzy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-08-2006 07:56 PM
Tein Flex w/ EDFC, XDrilled and stock rotors for STi, Volk GT-N 18x8 (gold) for STi cdraayer Private 'For Sale' Classifieds 24 03-11-2004 06:04 PM
cams and cam gears Solomon Legacy Forum 1 05-28-2003 02:24 AM
