Old 05-10-2005, 11:12 PM   #1
Volksabu
Member#: 79135
'02 WRX
Blaze Yellow
Default EJ22T swap issues
I recently got my EJ22T swap running and I'm having a couple of problems. It is throughing a constant check engine light when running, so I went to check the code and instead of blinking the check engine light the fuel pump and radiator fan pulse (and do not stop pulsing til I turn the ignition back off). The fuel pump, radiator fan, and check eningine light seem to function properly other than that. Any idea what is wrong with this? When driving the car, I hit a fuel cut when it reaches 0 psi (it will not make positive pressure). Would it be a reasonable assumptions that the code is from a bad pressure exchange solinoid or map sensor? Thanks for any help.
~Josh
Volksabu is offline   Reply With Quote
Old 05-11-2005, 01:31 AM   #2
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
How did you go about checking the code? IIRC there are two plugs under the dash, one is green other is black. If you connect one of these plugs it will run a self check and pulse the fuel pump and fans just like you described. The other plug will give you a code readout. You need to find these plugs and unplug them.
Scoobie Steve is offline   Reply With Quote
Old 05-11-2005, 11:21 AM   #3
Volksabu
Member#: 79135
'02 WRX
Blaze Yellow
I guess I should have specified that this motor is no longer in a subaru. I got the whole harness from the junked car a cut everyhting that I thought was needed to run the motor out of the harness. I pluged the "test mode" ecu pin out plug (it is green) the the other green plug. Sounds like I got the wrong set of plugs....back the the wiring diagrams for me .... thanks for the help
~Josh
Old 05-11-2005, 11:47 AM   #4
Volksabu
Member#: 79135
'02 WRX
Blaze Yellow
Well I just wnet to look over what was left of the un-used portion of the harness and found that when my room mate cleaned the garage and threw it out. the green plugs plug the "test mode connector" to the "control system ground", I'm assuming that one end of the black plug goes to the "trouble code output", but what does the other end connect to? (also the control system ground?). Thanks for any help.
~Josh
Old 05-11-2005, 11:57 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Are you driving the car with the green and/or black plugs connected? If you are, that is your problem. Those connectors should only be connected when running diagnostics...
Old 05-11-2005, 12:58 PM   #6
Volksabu
Member#: 79135
'02 WRX
Blaze Yellow
no, I'm not driving with them connected. I just want to be able to figure out what code the check eninge light is throughing. I do not have the black plugs wired into the car....I'm trying to figure out what to connect the second one to. Thanks for any help.
How do you like that 914 with a suby? This motor is in a '73 Super Beetle.
Old 05-13-2005, 07:15 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
Haven't done the conversion yet. Just got the car last month. I am going to drive it stock (w/Webers) for the summer and do the conversion over the winter.
I will need to look up how to send it into read mode. I never remember which combination of them does reset or test or read...
Old 05-15-2005, 11:40 PM   #8
josepepe
Member#: 86342
well i did the conversion from the 1.8 to the 2.2 and im having the same problem the engine ligth is comong on and if is a little cold the car does not want to start. what do u think the problem is i put in on the scanner and it says no data abilable ist cause i dint put that is a 2.2. also i left the 1,8 comp.
josepepe is offline   Reply With Quote
Questions to those with EJ22T swap. Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 4 09-21-2011 07:23 PM
possible EJ22t swap huckedup16 Legacy Forum 3 09-13-2002 03:48 PM
EJ22T swap into RS, tranny question? ImprezedRS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 06-05-2002 09:16 AM
SC EJ22 or EJ22T swap Witckraft Normally Aspirated with bolt-on Forced Induction Powertrain 8 01-02-2002 01:44 PM
Finally finished the EJ22T swap. first driving impressions Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 30 11-14-2001 07:41 AM
