Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 05-11-2005, 03:12 PM   #1
newsman
Member#: 25904
2003 WRX
WR Blue/Gold
OMGHi2U Couple of maintenance questions
1)Where should I take my car for wheel allignment? I hear that Firestone does one for a lifetime, and that Subaru of Dallas charges a lot for it.
2)When "rotating tires", do they rotate the wheels or actually take the tire off?
3)I'm due for 30k inspection - what does it include and what price am I looking at?
4)If I need to change out brake pads, should I go with the oem part or something else?
That is all.
newsman is offline   Reply With Quote
Old 05-11-2005, 04:49 PM   #2
BlkTS02
Member#: 50142
2002 2.5TS
MBP
1. Where are you? We can give suggestions based on your location.
2. most places will just move the tire / wheel combo from front to back (or back to front) for directional tires, for non-directional they might do some fancy diagonal switcharoo.
3. Umm, oil, coolant, tranny and rear diff fluids, brake fluid, fuel filter, 30 point inspection. There's probably one or two more things that I can't remember right now. As far as pricing, wait for one of the guys from SOD to chime in.
4. Go aftermarket, you'll get better performance at equal or less cost.
My suggestion, buy food and drinks for some people who are local to you and have a garage day. Do / help out with the work on your car and learn some very good maintenance procedures. Not to mention that the food / drinks will probably be less expensive than the service work if you take it in.
BlkTS02 is offline   Reply With Quote
Old 05-11-2005, 06:15 PM   #3
salaki
Member#: 10572
92X N62B44, ST 1050
CGK, LAX, & DFW
Lotta Pizza and lotta Shiners work for me
salaki is offline   Reply With Quote
Old 05-11-2005, 07:39 PM   #4
newsman
Member#: 25904
2003 WRX
WR Blue/Gold
Well Dallas, of course
Old 05-11-2005, 08:36 PM   #5
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Ok, stay away from firestone like the plague. They've "worked" (and I use that term loosely) on some of the trucks at work. They've all come back with more problems than they went in with.
Some people have had luck with NTB, find a branch with someone who'll let you in the service area and watch them get the numbers you want.
Salaki knows a guy who works at Sears in the auto department at 635 and Preston. Slvr Surfr is also investigating a place, hopefully it works out.
Either that or suck it up and go to SOD. Get it done once, correctly, and don't worry about it again.
Old 05-11-2005, 10:22 PM   #6
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
That is all.
1. Alignments at SoD are $99.95. If you've got camber plates, $129.99. If you want, I'll set the specs to what you want it at(as close as I possibly can).
2. A tire rotation includes adjusting tire pressure, rotating tires front to back. Not removing the tire from the wheel.
3. A 30k svc goes for $399.99. Most of it you can do yourself, or have friends do it for you for beer and pizza(as mentioned by Salaki). If you want Silkolene, it's an additional $70 for trans and diff)). If you want Mobil 1, the best thing to do(Read, save money) is to go to Wal-Mart and buy the 5 quart jug. It's less than $25.
4. If you've got an STi, your best bet would be to go aftermarket. The stock STi pads are ridiculously expensive. Ferodo is a good choice from what I've understood. WRX, I'm not sure what's good for them.
Mika(SoD tech ) <---not pushy, just informative
finnRex is offline   Reply With Quote
Old 05-11-2005, 10:36 PM   #7
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
I guess it's a differnent price depending on the region of the country. In NJ the 30K service is 429.95 (4 cyl), and 595.95 (6 cyl and turbo cars)
The list below is word for word what the service menu (from the dealer [Wayne Subaru NJ]) is for the 30K service:
Tune engine
replace spark plugs (if needed)
replace air and fuel filters
replace engine coolant
pressure test cooling system
inpect belts and hoses
change oil, & filter
check all fluid levels
rotate tires
service and adjust brakes
replace trans. fluid (if necessary to replace filter and gasket= additional parts and labor charge)
check exterior lights
service emmisions system
inspect suspension, and exhaust system
perform top engine cleaner service
check motor and trans mounts
(timing and drive belt replacement at 60,000 miles= additional charge)
jetfan2207 is offline   Reply With Quote
Old 05-12-2005, 12:54 AM   #8
KevinHeist
Member#: 50667
2000 Impreza Coupe
Enginuity Tuned
Tune engine
rotate tires
"Tune Engine"? I'd love to know what that entails what do we run? carbureted engines?
Oh... Subaru's Timing Belt is servicable at 105,000; not 60,000
KevinHeist is offline   Reply With Quote
Old 05-12-2005, 06:23 AM   #9
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Hey, I'm from Wayne, NJ.
Old 05-12-2005, 06:23 AM   #10
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Cool, I'm from Wayne, NJ.
Old 05-12-2005, 02:30 PM   #11
TheRipler
Member#: 34010
04 LandShark STi
198.1mph
Fancy diagonal switcharoo is for FWD or RWD with non-directional tires. AWD likes fancy LF<->LR, RF<->RR switcheroo even with non-directional tires. Because all are drive wheels, a diagonal switch would increase the chance of tread seperation due to the change in direction of forces applied to the tire.
TheRipler is offline   Reply With Quote
Old 05-13-2005, 02:48 PM   #12
newsman
Member#: 25904
2003 WRX
WR Blue/Gold
Thanks for all the advice guys, greatly appreciated.
Hmm, Mobil 1. How much will SoD charge for labor if I bring my own oil? I gather I need 5quarts for 03 WRX engine?
Hmm, always though about going Mobil 1 but having it done all in the shop was always cost prohibitive. $25 doesn't sound so bad.
Old 05-13-2005, 03:29 PM   #13
2k4STi
Member#: 80532
2014 BRZ
My name is Wayne, I'm from texas
2k4STi is offline   Reply With Quote
Old 05-13-2005, 04:51 PM   #14
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
If you bring your own oil, I think the labor is $14 and change. Add an oil filter, and you're set. As a heads up, Mobil 1 5 qt. jug=$23(give or take) at Wally World.
Mika
couple of maintenance questions shum_87 Vancouver Impreza Club Forum -- VIC 25 03-27-2008 12:39 PM
couple of maintenance questions sixthgear Vancouver Impreza Club Forum -- VIC 15 10-23-2007 06:13 PM
Couple of maintenance questions. Hagbard Service & Maintenance 16 01-23-2003 10:02 PM
couple of misc. questions imprezive General Forum Archive 5 08-07-2000 11:53 AM
Couple of wheel questions...what fits? offset? Overtime General Forum Archive 10 06-02-2000 11:02 AM
