05-12-2005, 12:22 AM | #1 |
Member#: 79484
Vehicle:04 WRX silver |
cleared my headlights and now drivers side low beam doesn't work
ok so tonight i took the headlights out my 04 wrx and cleared them, everything went good, put them back in the car and the driver side low beam doesn't work, the bulb is good and not blow, i tested it on the other side. so then i look at the fuse and see the fuse is blown, so i'm like ok new fuse. put a new fuse in and it still doesn't work? anyone have any idea what could be going on?
thanks
05-12-2005, 01:36 AM | #2 |
Member#: 69343
South East
Vehicle:1998 TransAm cnvrtbl Black |
Pinch a wire against some metal? I'd pull the light assy. back out and check that. First just unplug the harness there and and check that there isn't some wire shaving in it or something weird. Something is shorted to ground.
05-12-2005, 01:54 AM | #3 |
Member#: 79484
yes i did that, i pulled it all out and everything and nothing is weird???
i don't get it? |
05-12-2005, 04:10 AM | #4 |
Member#: 79025
SCIC
Vehicle:2004 WRX WRB |
my passenger low beam did the same thing. i just messed with the bulb connection and eventually it turned on. i don't know wut was the problem but it works now. try messing with it until it turns on.
05-12-2005, 01:10 PM | #5 |
Member#: 37617
Vehicle:2007 |
If the fuse was not blown before you cleared your lights, then wouldn't that mean that it blew when you reinstalled them and tried to turn them on? Did you check the new fuse that you put in to make sure that it did not blow like the one before it?
05-12-2005, 01:46 PM | #6 |
Member#: 79484
yes the fuse is good and it's not blown, something weird is going on
with both fuses in only the passenger side works, with just the pass fuse in the pass side works but with just the driver fuse in the high beams turn on but are super dim?? |
clearing my headlights right now | prescottsti | Interior & Exterior Modification | 6 | 04-24-2005 07:19 PM |
Prodrive Headlights - Hi-beam doesn't work | SR-71WRX | Electrical & Lighting | 2 | 03-02-2005 11:51 PM |
MY97-98 Impreza headlights and RS drivers side fog | mpaone | Private 'Wanted' Classifieds | 1 | 01-25-2005 04:37 PM |
Just cleared my lights and now they wont turn on. HELP!! | wrx_2070 | Electrical & Lighting | 1 | 10-28-2004 09:14 PM |
High beam works, low beam doesn't. Fuse or bulb? | Keenan | Electrical & Lighting | 6 | 07-08-2003 11:55 PM |
