Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 05-12-2005, 01:01 PM   #1
Member#: 48218
2000 2.5 RS
Dark Blue
Default 2.5 RS Brake problem
I've been having trouble with the brakes on my 2000 2.5 RS Coupe and as yet all the "common" fixes I've tried have not solved it. Basically, I have to depress the brake pedal 1/4 to 1/2 inch before the brakes even begin to slow the car down. When applying them harder (hard enough to stop, say) the pedal is lower than normal and isn't as firm as it should be. Pumping the pedal does not seem to build line pressure, as it would if there were air in the lines.
The brake system is all stock (save for OE replacement pads/rotors). The calipers seem to work correctly (not siezed, etc.) and everything else looks as it should be. The master cylinder is not losing fluid.
So far I have attempted to fix the problem by:
Bleeding brakes
Replacing master cylinder
Replacing pads/rotors
Replacing vaccum line and check valve (rubber hose from manifold to power booster)
Replacing power brake booster
Adjusting brake pedal height
Anyone ever have a similar problem? I've tried just about everything I can think of so if I can't get it sorted myself, I'll end up taking the car to the dealer. Any help is appreciated.
acrescen is offline   Reply With Quote
Old 05-12-2005, 02:20 PM   #2
Member#: 1594
1995 WRX
2002 Legacy
Bleed the brakes again... Make sure you are doing them in the right order and buy some different colored fluid and bleed out any/all of the old stuff in there.
Still sounds like a bleeding issue to me.
omahasubaru is offline   Reply With Quote
Old 05-12-2005, 04:04 PM   #3
Craig W
Member#: 643
1999 2.5RS
WRX powered
The 1st gen RS's have always had a soft brake pedal. I've installed stainless steel brake lines, different pads and rotors, Motul fluid, etc. and none really fix the problem.
Here's info on the soft pedal problem. http://www.spdusa.com/soft.htm
Craig W is offline   Reply With Quote
Old 05-12-2005, 04:51 PM   #4
Member#: 60116
1999 RS Coupe
Silver Thorn
Putting in the single stage booster is a PITA. But the end result is worth it.
cjfike is offline   Reply With Quote
Old 05-12-2005, 05:04 PM   #5
Member#: 15696
2015 WRX 6 speed
I think the booster you're got is a good one to match with the WRX master cylinder. You should have the 1" m/c right now and the smaller tandem 7"/8" booster. The WRX uses a 1 1/16" m/c. I've got this setup on my car and it feels pretty good (with WRX front and the H6 rear rotors). Here's some more info if you're interested. http://forums.nasioc.com/forums/showthread.php?t=466880
I don't think I'm really answering your question since you seem to indicate your brakes used to work better than they do now. It looks like you've already changed a bunch of stuff. I'd suggest bleding the brakes again too, especially since you replaced the m/c, some of those bubbles can be a pain to get through the system.
-my 0.02
jlevy is offline   Reply With Quote
Old 05-12-2005, 05:48 PM   #6
Member#: 48218
2000 2.5 RS
Dark Blue
I've actually bled the brakes several times between changing all the other parts. Once just to see if that was the problem, again with the master cylinder, a third time with the pads rotors and also when I replaced the booster.
As far as bleed sequence I'm not sure if it was 100% according to the reccomendation, but I did do, say RF/LR and then LF/RR...can't remember exactly, but I did start at one front corner then bleed the opposite rear and repeated for the remaining two wheels.
As far as pedal feel, I'm just looking to get it back to what it was originally.
Thanks for the suggestions!
Old 05-12-2005, 08:29 PM   #7
Member#: 34545
1999 GC8
I have this same problem too. It sucks hardcore. I was getting ready to start replacing all the little parts that you have so now I think I will just buy the spd upgrade for 400 bucks.
Can some please explain the reason behind the install of the single stage booster being a PITA.
99WRXEJ20 is online now   Reply With Quote
Old 05-12-2005, 09:42 PM   #8
Member#: 38120
1991 Rio Red
Legacy Turbo
<--------- Helped swap one into a WRX
It's difficult to get to the mounting stuff inside the cabin, and it is difficult to get out once you do.
IronMonkeyL255 is offline   Reply With Quote
Wanted GC8 2.5 rs Brake system and SVX brake System stevos758 Private 'Wanted' Classifieds 1 07-26-2006 02:03 PM
WTB: '99-'01 2.5 RS Brake Master Cylinder nunyo Private 'Wanted' Classifieds 0 08-09-2004 01:41 PM
MY00 2.5 RS brake assemblies same as Legacy brakes from the same year? Mauricio Brakes, Steering & Suspension 4 06-01-2004 05:55 PM
2000 2.5 Rs Idle Problem CONBON101 Service & Maintenance 6 03-06-2004 04:24 PM
2002 2.5 RS Brake Questions DrBoy01 Brakes, Steering & Suspension 19 04-28-2003 08:32 PM
