Welcome to the North American Subaru Impreza Owners Club Saturday September 20, 2014
Old 05-13-2005, 02:44 PM   #1
fastlane
Member#: 17470
2002 WRX Wagon 5 Spd
^^Nomo - 04 GT Stang now
Default Anyone ever have a Intake Cam bolt snap off while driving????
Last night, I was out driving when my car just died...it turned over but was making an awful sound from the timing belt cover area. The time interval leading upto the engine dying was uneventful and no weird sounds emanted from the engine compartment.
Anyway, after finally getting the car back to my house and pulling off the valve cover and timing cover, the only thing I found wrong was the bolt that holds the passenger side intake cam sprocket to the cam shaft was twisted in half. The cam still spins a full revolution without any unordinary binding, other than the obvious tension caused by the valves opening. Without the cam sprocket in place, the engine turns freely and everything seems to be in order...
So, it looks like I might be about ready to source some new cams and such. I just wanted to see if anyone else has had a similar experience.
fastlane is offline   Reply With Quote
Old 05-13-2005, 08:24 PM   #2
ncarn8
Member#: 71419
so the bold that holds the cam sprocket on sheared off? that is way odd. Never heard of that. What was causing the noise? the sprocket was still held on wy the keyway and tension, are you sure your valves are still closing properly?
im not sure im 100% clear on exactly what you mean
ncarn8 is offline   Reply With Quote
Old 05-14-2005, 08:36 PM   #3
fastlane
Member#: 17470
The intake cam sprocket was still being turned by the timing belt and chewed up the plastic backing cover, but the intake cam was not turning. We drilled and easy outted the old bolt and replaced the broken parts and all is well again. Just a very odd experience.....btw, the sprocket bolt had signs of rust at the shearing point. It looked like it maybe had a hairline fracture from the factory and 102K miles of beating finally took its toll.
Old 05-14-2005, 08:54 PM   #4
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
Did you buy the car new? I ask because the bumper beam doesn't protect the intake cam gear from impact in a minor front end collision. My car was in an accident and the timing belt cover was cracked and the belt skipped a few teeth.
eastcoastbumps is offline   Reply With Quote
Old 05-14-2005, 09:42 PM   #5
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
i'd do a leakdown on that.. good possibility that the valves are bent.
subbyspeed is offline   Reply With Quote
Old 05-16-2005, 10:58 AM   #6
fastlane
Member#: 17470
I bought the car new and it has never been in an accident...also, I did do a leakdown test and everything is fine. There was no valve to piston interference.
Old 05-16-2005, 05:18 PM   #7
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
sweet! quite lucky my friend!
HELP>>>>>Broken Intake Cam bolt...3rd time in 6 months fastlane Factory 2.0L Turbo Powertrain 6 03-05-2008 04:33 AM
Bolt snapped off in Manifold...help??? kkos06 Service & Maintenance 4 07-26-2007 12:57 PM
Anyone ever have a spasm while sleeping that woke you up? 35th Off-Topic 33 11-13-2006 12:25 PM
Wheel bolt snapped off SubaruImpreza_power Tire & Wheel 1 09-15-2004 09:09 PM
anyone here have a blue sedan and work off of hills tech drive in farmington? wrx182 Mid West Subaru Owners Club Forum -- MWSOC 0 02-01-2002 09:03 AM
