#1 |
Member#: 77677
Vehicle:1997 OBS '07 KLR 650 |
Well, I made the trip down to NJ to pick up a 2.5, exhuast, and some other stuff. Couple of questions now:
The motor is a 2001, with 52k on it. I know that I want to put some reground cams in. Should I do any other repairs, since it's out of the car? ie; gaskets, seals, timing belts It came with a clutch. OK to re-use? It also came with a hacked up engine harness. Will this effect me adversely? Seth BTW, those RS seats are WAY better than old 93' L seats ![]()
#2 |
Member#: 37558
South East
Vehicle:2003 TS wagon JDM bukkake white |
I would say that at 52k miles, if the main (crank) seals are not leaking, don't bother changing them. They tend to last 100k or more. Change the cam seals if you will replace the cams, though. Timing belt, yes change it. On the last thing, I have known of others to run a 2.5 motor on their 1.8 ECU and harness successfully... search it on the N/A forum.
#3 |
Member#: 2263
Vehicle:2012 Impreza Sport |
If you can, do yourself a favor (peace of mind) and refresh everything you can so you know the engine is sound.
I would say the clutch is ok to reuse, but measure the surface material left on it to see if it's basically new or basically dead. Engine wiring....I don't know enough about wiring to give you a good response, however, I do know that electrical problems in any car can be a pain to figure out. If your budget didn't allow you to source out a engine wiring harness in one piece, I would at least go over the hacked up one very oh so very carefully and make sure everything is connected where it should be and stuff like that. Have fun ![]() |
#4 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
Don't bother with the timing belt at that mileage. Just mark it properly on removal and reuse it. Clutch should be fine to reuse as well, especially if it is still bolted to a flywheel and attached to the engine.
The only thing I would bother with is the cam seals when you change cams. Shoot me a PM if you need help with the wiring. It is pretty straightforward to move your 1.8l wiring harness over to the new engine. You just do it while the manifold is off of it. There are a couple of things that need to be changed and spliced, and as long as the connectors themselves are good on the cut harness, you are good to go... |
#5 |
Member#: 77677
I'll post pics of everything this afternoon. The harness is a pretty sorry state of affairs, though.....I think....I've never really seen one before, so I may be wrong.
The engine has know noticeable leaks, though. However, I transported it laying on it's back (flywheel side) and I noticed that when I got home, the inside of the throttle body had a bit of oil in it. I was in such a hurry to get home that I failed to check it. Are they related? The whole intake plumbing (air filter and ducting) is clean as a whistle, though. Seth |
#6 |
Member#: 37558
South East
Since you tipped the motor up that way, it is likely that oil seeped into the intake manifold from the PCV hose inlet. The motor should always sit oil pan side down...
#7 |
Member#: 77677
Yeah, I kinda figured that was the problem. Would it ruin anything? I wanted to transport it standing up, but I didn't have a good way of securing it in the back of my wifes minivan (pontiac montanna, which by the way, is a very comfortable ride)
Here are the pics: One end of harness: Other end of harness: Engine: yes, I know I'll get flack for leaving it on a tire, but who cares. Here's the throttle body: Here's the clutch: Seth |
#8 |
Member#: 77677
Also, do I want to use a RRFPR, or a S-AFC?
#9 |
Member#: 37558
South East
The motor will be okay... just replace the plugs and change the oil. Unless you plan to turbo it, your stock fuel pump is plenty. Clutch and P/P look okay BTW.
#10 |
Member#: 77677
Well, since it's being run by a 1.8 ecu, I've read that the stock fuel sytem will not be "adequate".
edit: Also, the clutch measures .280" thickness. I have no idea what they are stock..... |
#11 | |
Member#: 37558
South East
I have not personally done this swap, but read alot on it.... I have read that it will work using the stock system. The guy transplanted a 2nd gen EJ25 into his EJ18 Brighton and had no probs. From what I know, it still runs fine to this day. The swap was done more than a year ago.
Check here: http://forums.nasioc.com/forums/show...EJ18+EJ25+swap Here is a quote from the guy I was talking about: Quote:
| Thread Tools | |
| Display Modes | |
| Just picked up a 2.5RS Coupe | Noisyninja | Newbies & FAQs | 8 | 08-28-2007 06:40 PM |
| Finally part of the Subaru Family! Just picked up one of these.. *PICS* | STi Boy | New England Impreza Club Forum -- NESIC | 14 | 05-23-2006 07:49 PM |
| I picked up my 05 WRX on sat. couple of questions | onyx445 | Newbies & FAQs | 6 | 05-17-2005 07:39 PM |
| just picked up Sylvania SilverStars but have question | milenko11 | Interior & Exterior Modification | 4 | 05-16-2003 11:45 PM |
| Just Picked up my 2001 2.5RS | P023869 | Newbies & FAQs | 17 | 02-14-2001 05:13 PM |
