View Poll Results: What if U
Ship over a STI motor & Trannie from AUS 1 3.70%
Rebuild UR 2.5 from the ground up 4 turbo 14 51.85%
+ Rebuild ur drive sys to handle turbo 5 18.52%
Wait for STI to come to USA 7 25.93%
Voters: 27. You may not vote on this poll
Old 07-30-2001, 10:16 PM   #1
wackit
Member#: 3200
2000 Impreza RS
BRP **RIP**
Default What If U......
Ok lets say u have a 2000 RS. U really want a turbo but want to do it right. Out of these choices what whould u do...and if money was not an object.
wackit is offline   Reply With Quote
Old 07-31-2001, 02:20 AM   #2
BongMan
Member#: 2399
2001 Impreza RS
I polled that I'd get the Sti later.
However if i really wanted to, I'd just get a WRX now. And That's what i'd opt for, because of California emissions and having an engine designed for Turbos makes it "safer."
But mostly a factory turbo is the key because money is always a factor.
BongMan is offline   Reply With Quote
Old 07-31-2001, 08:58 AM   #3
Cacophony
Member#: 213
2004 Mazda RX-8
Well, I wanted to "do it right", so I bought a new STi V engine to build around. It was just a matter of personal preference really.. and now that I've been gathering parts for a while, sometimes I wish I had just cheaped out and done a turbokit. I mean, to do a motor swap right takes a wheelbarrow full of cash AND patience. But I've come this far, and I'll be damned if I'll give up now.. I'm just hoping that my finished project will be fully capable of humbling the turbokitted masses. And if it's not, then it'll go back under the knife
Cacophony is offline   Reply With Quote
Old 07-31-2001, 09:56 AM   #4
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
I'd strengthen that EJ25 as much as possible then run 15-18psi daily and get massive amounts of torque and horsepower.
I would send my engine to Cobb and get them to do a closed deck conversion and in the mean time slap some forged lower compression pistons, a forged crank, and turbo cylinder heads with cams. It would then be off to Ralli Spec for a custom turbo/TEC-II and tranny install.
For what I paid for my Legacy, $16K, it just wouldn't be worth buying a brand new REX at $25K. For the extra $9000 I could easily have the turbo I want built, the TEC-II installed and tuned, and then have the Closed Deck conversion done. I would then run low boost until I have another couple thousand for Heads, Pistons, and Stronger Tranny. I would then be busy for the next couple years saving up for stronger diffs and other driveline components.
Obviously this would be a maximum street performance setup. You could shave of a lot of cost by shaving off a few components that you won't need if you decided to go less power.
Brad
MY99 2.5GT is offline   Reply With Quote
What if I couldn't get a WRX, what else? SurFNerv89 Newbies & FAQs 22 01-01-2002 12:01 PM
so what if it is flooding Subergoobr Texas Impreza Club Forum -- TXIC 4 06-06-2001 08:12 AM
What if we met at the AZ Car show? olsonjj South West Impreza Club Forum -- SWIC 3 11-21-2000 12:32 PM
