05-14-2005, 09:29 AM | #1 |
Member#: 17615
TXIC
Vehicle:2009 Toyota Tundra |
gauge wiring install
i have a 2 greddy gauges, egt, and boost. Where is the best place to tap into the wiring harness to do the install?
05-14-2005, 10:50 PM | #2 |
Member#: 10309
NWIC
Vehicle:'02 OBS 2-tone! White |
Depending on where you are installing them, there should be an OEM harness under the dash for the OEM boost gauge; there's also the audio wiring harness.
05-14-2005, 11:50 PM | #3 |
Member#: 5887
BAIC
Vehicle:2002 GDAA (bugeye) 797 (blaze yellow) |
To add what armand1 said:
There is a connector located somewhere under the OEM radio unit. Subaru's OEM turbo gauge unit should come with an installation manual that shows where this harness is. Subaruparts.com has a collection of installation manuals, including one for the OEM turbo gauge here: http://www.subaruparts.com/guides/ Alternately, you can tap wires off the radio harness (see picture below as an example). Ravensblade-impreza has the pin diagram for the radio harness. http://www.northursalia.com/m...ng/wiring.html One note is that for electric gauges that share a common ground for the lighting (bulb or LED) and the gauge electronics, it may not be possible to have the gauge lighting dim/brighten along with the OEM instrument panel. This is not a problem for mechanical gauges. |
05-15-2005, 10:32 AM | #4 |
Member#: 17615
TXIC
I got them installed. Took abit of time to trace out all the wires.
Thanks |
Wrapping up install need help with Prosport Gauge wiring | last lemming alive | Electrical & Lighting | 4 | 01-14-2008 03:52 PM |
air fuel gauge wire install!! | scoobaru_wagon | Electrical & Lighting | 4 | 05-02-2005 10:24 AM |
Help what wires on the clock do I tap for gauge wiring | BIG BEN | Electrical & Lighting | 2 | 11-09-2002 01:04 PM |
gauge wiring clock wire ? help | dark knight | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 10-14-2002 07:26 PM |
Wiring 101. How to do basic wiring instals | Mighty Mouse | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 05-28-2002 02:06 AM |
