Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 05-14-2005, 07:33 PM   #1
masiolli
Member#: 35840
1999 Blue RS-t
22t & Hydra
Default Hydra connectivity...
Has ANYONE been sucessful in getting the hydra to connect to a laptop through USB? i got a new laptop and it doesnt have a serial port on it and im SO SICK of using the POS 90 mhz laptop... i bought a serial to USB converter.. and when i tried it out it said "ECU connected, but youre using the wrong software" or something of the like.. and i cannot upload a map or anything.. does anyone have any solutions?
masiolli is offline   Reply With Quote
Old 05-15-2005, 03:13 AM   #2
agnes
Member#: 75430
Default USB woes
Hey Masiolli,
I have no trouble using a 'Dolphin' XH6451 USB<->serial adapter. Try the dolphinfast website, the FASTUSB-9103 looks a lot like the one I am using (with a COMPAQ Presario 1GHz AMD-Duron running XP).
I am pretty sure HydraEMS America does not recommend ANY USB<->serial converter because getting things to work is a bit of trial an error.
I am told a more successful option is a PCMCIA serial port.
agnes is offline   Reply With Quote
Old 05-15-2005, 04:55 AM   #3
masiolli
Member#: 35840
1999 Blue RS-t
22t & Hydra
hmm.. i'll have to check those two options.. thanks a lot for the help!
Old 05-15-2005, 12:39 PM   #4
erggy
Member#: 51202
I've seen ppl getting it to work with various brands of USB <-> serial
however i can't get mine to work either... but will try another one
erggy is offline   Reply With Quote
Old 05-16-2005, 02:16 AM   #5
imp2.5
Member#: 11354
2009 LGT
BF3 tag: Snbrd4evr
I've had no problems, well problems at first but I figured it all out. Just make sure that you go into the device manager, properties of the serial to usb, and make sure it's on the same com port as the hydra, then slow it down a bunch and try it. Once it works speed it up until it fails, then you will know how fast the baud rate can be to get the best results.
imp2.5 is offline   Reply With Quote
2004 Sti Hydra EMS II 2.6 ECU SOLD tolishel Engine/Power/Exhaust 8 07-07-2010 04:50 PM
FS - Harness for Hydra (fits 05-06 Sti) 05pearl Engine/Power/Exhaust 2 06-16-2010 02:15 PM
Hydra 2.50 connectivity issues 48mpg Other Engine Management 16 07-03-2009 05:24 PM
what do u use to connect hydra to a your laptop moorebl Other Engine Management 4 03-25-2009 09:44 PM
Connecting to Hydra niemand_1 Other Engine Management 3 05-31-2007 02:34 PM
Message Board Statistics All times are GMT -4. The time now is 03:53 AM.
