Old 05-15-2005, 01:38 AM   #1
swift2fly
Member#: 70810
07 impreza STi
Jizz White.facial anyone?
Default JDM v.7 w/ sti USDM head swap
i finally came with a set plan for a swap to replace my broken stock motor. i am going with the JDM v.7 block with the USDM stock head(AVCS). i will be using the version 8 JDM ECU and a tune by prodrive. along with this setup i will be running sti pink injectors and a vf34 with a 255walbro fuel pump. is this a pretty good setup?
swift2fly is offline   Reply With Quote
Old 05-15-2005, 06:40 AM   #2
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
you need a USDM ecu to go with those heads. Either that or get jdm v7/v8 heads to go with that ecu. Sounds good otherwise
petawabit is offline   Reply With Quote
Old 05-15-2005, 07:08 AM   #3
AKGC8
Member#: 1305
2000 Impreza
I don't get it, why all the mixing and matching. If you're going the JDM route, why don't you just get a full JDM engine? Those heads are better.
AKGC8 is offline   Reply With Quote
Old 05-15-2005, 10:57 AM   #4
swift2fly
Member#: 70810
07 impreza STi
the mixing and matching is kinda of a long story...basically i can get the USDM STI heads cheaper than the v7/v8 heads. i am getting the v7 block for roughly 1100.00. but steve at aerosim says i am fine with using the sti USDM heads on the v7 while using the JDM ECU. the JDM ECU already has wiring for the ACVS. i'll try my luck with steve's advise since he does this stuff for a living and has history of great swaps.
petawabit thanks for assuring that this is a good setup.
Old 05-15-2005, 05:25 PM   #5
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
np man. the usdm sti heads do work with the jdm ecu if you use the intake manifold not meant for the us sti that has the throttle body attached to it. my mistake.
or you can just use your stock ecu and get ia performance's avcs wiring kit. might save some trouble and some money as I think they're 150.
Old 05-16-2005, 03:21 AM   #6
kaos200
Member#: 2692
thats not correct, the JDM heads will NOT work properly with the USDM ecu even if you have the intake manifold with DBW. The cam position sensors are different (sensors and the cams themselves, which they trigger off of)
Steve at Aerosim is incorrect in that respect.
I'd recommend just using the jdm ecu/harness/full engine if you're going to do it that way, much easier then going usdm with the dbw and extra emissions control devices.
kaos200 is online now   Reply With Quote
Old 05-16-2005, 03:55 AM   #7
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
stand corrected by Kian :P
Old 05-16-2005, 02:39 PM   #8
nwdriftking
Member#: 70820
2004 WRX STi
Sell me your USDM heads!
nwdriftking is offline   Reply With Quote
Old 05-16-2005, 08:41 PM   #9
swift2fly
Member#: 70810
07 impreza STi
would the USDM sti heads work with the JDM ECU?
Old 05-16-2005, 08:41 PM   #10
swift2fly
Member#: 70810
07 impreza STi
which ones? STI or WRX? as of now my WRX heads belong to steve at aerosim.
Old 05-16-2005, 08:51 PM   #11
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
No... well if you rewired everything you may beable to get it to work. You could run it with out avcs.
Old 05-16-2005, 11:22 PM   #12
swift2fly
Member#: 70810
07 impreza STi
well..looks like my options have changed. after a few searches for the jdm v7, steve could not land one. so as i need my car back from an engine failure incident with the USDM EJ20, he found me a new USDM EJ25 block to swap in..so with the USDM heads..it now shouldn't be an issue. thanks for the replies guys, it's great when you learn something new.
Old 05-17-2005, 12:14 AM   #13
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
its a difference of cam senor setups, (avcs does not have to work for a car to run)
the JDM head needs a JDM ecu to work... it can work with a USDM WRX..
the USDM sti head is totally different it needs a USDM STI ecu(forester ecu might work too?)
not only is that an issue, but what compression ratio would that make??
the USDM 2.5 with wrx/jdm heads is a high compression ratio... so i guess with what u plan it would be very low
YaZahX is offline   Reply With Quote
Old 05-17-2005, 08:28 PM   #14
Aerosim Research Ltd
Member#: 45648
GC8 CF 22B widebody
Lancia Stratos Replica
I'd be incorrect if that was what we were going to do, but it isn't. We're trying to keep the cost down for him and we're mixing and matching available parts to do so. So, It was going to be a USDM STi block, USDM STi heads with JDM cams and cam sensors and a JDM ECU to control the AVCS. There's a little milling involved to fit the cam sensors in the heads, but nothing too extreme. There are a couple of other options, but this was the cheapest and easiest one to get the AVCS working in his car without major hassles.
So, there you go ... it will work. And it's a hell of a lot easier than a jdm ecu/harness/full engine. Lots cheaper too.
-Steve
Stephen.Ramm@aerosim-research.com
Aerosim Research Ltd is offline   Reply With Quote
Complete STi USDM Engine Swaps & More Tigre Tuning Engine/Power/Exhaust 3 07-11-2008 10:57 AM
JDM v.7 WRB STI Hood Scoop t3rror SCIC Private Classifieds 6 07-13-2007 08:46 AM
FS: JDM V.7 Gold STi rims w/ tires ImprezaRSfan! Mid Atlantic Impreza Club -- MAIC 36 05-13-2004 11:56 AM
jdm ver 7 tmic vs. usdm sti tmic showcasewrx Factory 2.0L Turbo Powertrain 1 05-09-2004 08:45 PM
STi cylinder head swap. KillerRex Factory 2.0L Turbo Powertrain 9 06-14-2002 12:06 PM
Message Board Statistics All times are GMT -4. The time now is 11:51 PM.
