Old 05-15-2005, 03:44 AM   #1
josh...just josh
Member#: 82273
97 impreza L
now with wrx brake love!!
Default stand alone management
My mechanical engineering degree is a ways off yet, as is the good paying jobs that will hopefully come with it. As for right know I am still just a poor college kid but I am currently planing a potential subaru build that would be spread out a few year period (hopefully with the expensive parts being later when i'm making a decent living). My question really is about engine management options with an engine swap. I know that a common (although costly) option is a stand alone management system. It is my understanding that the system fully takes the place of the ECU and includes an engine specific wiring harness (not car or car/engine specfic). I guess my real question is how this type of system incorporates the car's sensors (O2, mass air flow, etc..)? Do the sensors have to be wired into the system? Or does the system somehow fake the standred values for the sensors to allow for a trully stand alone where the motor functions independently of the sensors? Also, does an engine specfic wiring harness and piggy-back ecu have to be wired into the car's harness? I'm really just trying to get a grasp on what I am getting into.
josh...just josh is offline   Reply With Quote
Old 05-15-2005, 05:21 AM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
well, not all stand alone has to be wired in...for instance, I'm a poor college student also studying Mechanical Engineering...I did my 02 WRX engine swap and my Link 44s full standalone was actually plug and play with the WRX wiring harness....I now have utec, being the car is my daily driver and link was just too much of a pain for daily use...
the recommended engine management really depends on how in depth you want to be in control and how user friendly(not having to tune everyday) you want it to be..
-Micah
Homemade WRX is online now   Reply With Quote
Old 05-15-2005, 02:08 PM   #3
josh...just josh
Member#: 82273
97 impreza L
Hey thanks for the reply man...so does that mean that the sensors are wired on the engine's side of the harness (as it would seem now that I look into it)? I know that a fair amount of the sensors are actually physically mounted on the engine but what of the ones that are not, say the power steering pressure sensor? Do those sensors have to be wired into the new engine's harness after a swap? If so, is that hard to do? I am unquestionably a noob, but I'm trying to complile enough knowlegde of the process so that when I actually do it, I wont run into any surprises.
Old 05-15-2005, 02:28 PM   #4
josh...just josh
Member#: 82273
97 impreza L
Also... how did you go about sourcing that wrx powerplant; is it usdm, jsdm, or crate? My mechanic skills are not yet good enough to do major engine work, but I'm also considering just doing a build on a ej22t block or even my stock ej22e. Getting ahold of a wrx engine with a reputable background seems to be hard and expensive, and with time and plaining, i feel that an engine build is within the relm of possible. Did you use the tranny that was in your car (mines auto, not even something that I'm considering using, i figure that a wrx 5-speed will do fine, maybe even getting ahold of a spent one and trudging through dropping some higher tensile gears in it, i figure that even that route would be cheaper than a used sti tranny)? Remembering that I a navie noob.
Link G4 Xtreme PnP Stand Alone ECU 06-07 Sti akeric Engine/Power/Exhaust 6 06-05-2010 06:00 PM
Why the lack of stand alone management? jimb Engine Management & Tuning 17 07-18-2003 06:26 PM
Best stand alone engine management jetfan8178 Normally Aspirated with bolt-on Forced Induction Powertrain 7 03-29-2002 11:46 AM
Stand alone engine management options jetfan8178 Normally Aspirated Powertrain 3 03-26-2002 02:19 PM
For those looking for stand alone engine management... DanMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 02-02-2002 03:30 AM
