05-15-2005, 04:09 AM | #1 |
Member#: 4597
TXIC
Vehicle:2011 Mitsu Outlander Sport (Ex-Suby owner X3) |
Bulb Size Info for all models
there was a thread in interior modification that was asking for a list of bulb sizes. i figured maybe we should make a sticky out of it....i dont know how many times the thread - " i want to upgrade ___ bulbs, but dont know the size" - has come up....so any contributions? or changes?
2001 - earlier Imprezas (GC8) High & low beam headlamp - 9003 AKA H4 65w/55w Parking light - 194 Front turn signal - 1156 Rear turn signal - 1156 Tail light - 1157 Stop light - 1157 High mount stop light - 912, 921 Fog/Driving light - H3-55W License plate - 194 Back up light - 1156 Front sidemarker - 194 Rear sidemarker - 1157 Ash tray - 74 Map light - DE3175 Dome light - 168, DE3175 Trunk/Cargo area - 168 Instrument-general - 158, 74 2002 - 2003 SUBARU Impreza (Except wagon) High & low beam headlamp - 9007 65w/55w Parking light - 168 Front turn signal - 1156 Tail light - 7443 Stop light - 7440, 7443 High mount stop light - 921 Fog/Driving light - H3-55W License plate - 168 Back up light - 7440 Front sidemarker - 168 Rear sidemarker - 168 Ash tray - 74 Map light - 168 Dome light - DE3175 Trunk/Cargo area - 912 2004 - 2005 SUBARU Impreza (Except wagon) Low beam headlamp - H1-55W, STi - D2R High beam headlamp - 9005 Parking light - 168 Front turn signal - 7440 Tail light - 7443 Stop light - 7440, 7443 High mount stop light - 921 Fog/Driving light - H3-55W License plate - 168 Back up light - 7440 Front sidemarker - 168 Rear sidemarker - 168 Ash tray - 74 Map light - DE3175 Dome light - DE3175 Trunk/Cargo area - 921 2006 - 2007 SUBARU Impreza (Sedan) Low beam headlamp - H7 High beam headlamp - 9005 Fog/Driving lightH3-55W Parking light - 168 Front turn signal -992 (7440A) Rear turn signal 992 (7440A) Tail light - 7443 Stop light - 7443 High mount stop light -7440 License plate - 168 Back up light - 7440 Front sidemarker - 168 Ash tray - 74 Glove box - 74 Map light - DE3175 Dome light - DE3175 Trunk/Cargo area - 2825 all sizes were taken from http://www.sylvania.com/ConsumerProd...lacementGuide/ so dont get mad at me if they are different just let me know if you know from experience.
05-15-2005, 04:12 AM | #2 |
Member#: 4597
TXIC
also
bulbs 194 = 158 = 168 in size at least 1156 single filament 1157 dual filament 7440 single filament 7443 dual filament |
05-07-2008, 11:40 AM | #3 |
Member#: 166947
SCIC
Vehicle:2006 WRX Sedan Crystal Gray Metallic |
can you post info for 06-07 models?
05-07-2008, 02:24 PM | #4 |
Member#: 4597
TXIC
consider it done. check the top post.
05-07-2008, 03:41 PM | #5 |
Member#: 166947
SCIC
Great!
02-20-2009, 02:05 PM | #6 |
Member#: 202982
How about the new info for 08+ sedan and wagon?
03-28-2009, 02:51 PM | #7 |
Member#: 176692
03-28-2009, 02:53 PM | #8 |
Member#: 176692
12-13-2016, 11:58 PM | #9 |
Member#: 90539
South East
Vehicle:My BOV goes COVFEFE! |
Small update, not sure if wrx and normal impreza are the same bulb types but my 2007 2.5i uses a 1156 bulb in the high mount stop light instead of the 7440 mentioned. It does have 7440 bulbs for the reverse and rear turn signal though. I retrofitted it to an led bar but people should remove the light and check the bulb type before buying a replacement.
12-20-2016, 01:52 PM | #10 |
Member#: 443017
South East
Vehicle:2011 Impreza WRX STI Grey |
Could someone update the original post with the 2008 + specs? my 2011 owners manual lists WY21W as the rear turn signal bulb but it looks the same as the 7440? I'm guessing they're the same.
02-12-2019, 11:35 PM | #11 |
Member#: 34931
Vehicle:. Super bowl LII Champions! |
what bulb would i use for the shifter bulb replacement
Bolt size/info for WRX oil feed | SW00P_G | Built Motor Discussion | 7 | 08-04-2006 11:48 AM |
Any more info for a model change in 2003 (impreza)?? | mike270 | News & Rumors | 13 | 01-29-2002 08:22 PM |
dash dress up - for all models | Subie Gal | Interior & Exterior Modification | 5 | 01-21-2002 11:51 PM |
Whats the wedge bulb size/number for 2001 side marker? | AndyM | Newbies & FAQs | 4 | 03-19-2001 08:56 AM |
Pulley sizes for all models and the UD pulley | MPREZYA | Technical Forum Archive | 0 | 08-14-2000 12:06 AM |
