Old 05-15-2005, 09:30 PM   #1
dbryan
Member#: 7950
2002 WRX Wagon
platinum silver
Default sti pink springs and gr-2 struts
I have searched but it seems like everyone has prodrive springs with these struts. Will they work? I have a wagon and see a guy on ebay selling the gr-2 struts for $229. The description says, " box a set of 4 ( 2 334304-334305 front struts, 2 334306-334307 Rear ) KYB GR-2 shocks to fit 2002 AND 2003 Subaru WRX all models". I thought the wagon used different part numbers.
dbryan is offline   Reply With Quote
Old 05-15-2005, 10:02 PM   #2
dbryan
Member#: 7950
2002 WRX Wagon
platinum silver
Default help..........please
please help me...
Old 05-15-2005, 10:11 PM   #3
yobtah
Member#: 48939
I'm assuming you're asking about the "JDM" STi pink springs for '04 and newer STi (the ones with 257/217 spring rates). Because those are intended for '04 and newer Imprezas, the rear springs will only work with the '04 and newer strut top design.
If you want to use GR-2s for 2002-2003 Imprezas with the STi ping springs, you'll need '04+ rear strut tops (and some washers for the "notch" in the top of the older design strut rod). I'm not so sure it's worth the trouble for GR-2s though.
yobtah is offline   Reply With Quote
Old 05-15-2005, 10:19 PM   #4
poison
Member#: 37678
I would bet the spring rates will kill the GR-2's.
poison is offline   Reply With Quote
Old 05-15-2005, 10:20 PM   #5
peterex
Member#: 27021
2015 WRX
If you are talking about JDM STi pinks (252/217 spring rates, IIRC), there is no way that GR-2's will be able to handle that stiff of a spring for too long. GR-2s are mild upgrades to your stock struts, with about 10-15% more damping. STi pinks are a 50% or greater increase in spring rates over a stock WRX. At the very least, you need AGXes to handle that stiff of a spring.
If you are talking about the USDM pinks, which IIRC have spring rates north of 200 lbs/in in the front, I still think that the GR-2s would be outmatched.
Basically, the ride might be acceptable for a very short time, but as the struts wear, you'll be bouncing all over the place before long due to insufficient damping.
peterex is offline   Reply With Quote
Old 05-15-2005, 10:25 PM   #6
peterex
Member#: 27021
2015 WRX
BTW, you should watch the classifieds if you're looking for a good cheap upgrade. There was a guy selling almost new AGXes and Prodrives pretty recently for <$400. Better yet, maybe you could find some STi takeoffs.
Old 05-18-2005, 03:20 PM   #7
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I got kyb agx for $375 + another $7 I think it was from a guy in socal advertizing on ebay with free shipping. they are 4 spot adjustable. g2-s are ok but you might out grow them fast. I think he said something about gc front struts. just ask him. Because wrx sedan strut have bigger knuckle ears. That can be corrected with camber bolts I am told.
Old 05-18-2005, 10:21 PM   #8
dbryan
Member#: 7950
2002 WRX Wagon
platinum silver
Default thanks
Thanks for the imput. I also contacted a very knowledgable vendor and he said the GR-2 struts would have no problem with the pinks and would wear no faster than the AGX strut. He said Koni was the best and could have probably talked me into them but he listened to my needs and said I would be happy with the performance of the non adj gr2. That is what I bought.
Old 05-18-2005, 11:17 PM   #9
peterex
Member#: 27021
2015 WRX
I hope they work out for you, but I will maintain that a significant spring rate increase should be matched by a significant damping rate increase - not a mild damping rate increase. Let us know how things go, because if the knowledgable vendor is right, we'll all save hella cash around here.
STi pink springs on GR ohiotrojan Brakes, Steering & Suspension 0 01-22-2010 11:47 PM
FS Philly PA: 04-07 JDM STi Pink Springs and Group N Strut Tops bdi Suspension/Brakes/Handling 32 10-16-2009 11:55 PM
Santa Barbara: STi Pink Springs and JDM Pink Struts, trade for stock!! kimbo63 SCIC Private Classifieds 2 02-13-2007 01:09 AM
FS: NEW STi Pink Springs and Hardened Strut Tops WRXinEffect Bay Area Impreza Club Forum -- BAIC 5 06-05-2005 05:16 PM
FS: NEW STi Pink Springs and Hardened Strut Tops WRXinEffect Private 'For Sale' Classifieds 0 05-25-2005 03:24 PM
